However, the tail button helps a lot for avoiding accidental activation. And the momentary function of lockout mode is designed specifically for “those short few second jobs”.
Looks good! I finally got round to playing with Anduril last night and figured most of it out from looking at the diagram and reading anduril.txt. I got stuck in muggle mode for a while because I thought I was in momentary mode but that’s definitely user error :person_facepalming: . The only things I would’ve added are brief explanations and default/min/max values, which you’ve done! :+1:
Thank you! Do you mind if I translate it into German? I'm not sure if joechina is already up to creating something comparable (printable pdf in a nice layout).
Therein lies the problem though Jason, she DID state default was set at 1/150, so any REASONABLY intelligent individual would see that the term default showed 1 out of a possible 150 steps, so how do you idiot proof for all the different idiots? I know my own idiocy can, many times, be quite different from the normal… just saying. Once you start configuring the light it becomes pretty evident.
And with this adjustability it becomes easy to set the momentary in lockout to whatever level suits your fancy. It is also easy to set the stepped mode for however many levels one wants, one or three or whatever. So it can suit the needs of a lot of different appetites.
Stepped mode can’t be configured for one mode. See here but you could probably set the ramp min and max values to the same level and effectively have a 1 mode light.
As to optical sensing….
Oveready Boss / Lux-RC use this feature to accomplish more than programming.
When the light accidentally activates, it’s usually in a confined space (i.e. pocket) and that space reflects a lot of light back towards the head. They sense this light and act upon this knowledge ( I don’t remember how, but I remember they do it wrong ).
Anyway, it’s the best solution to the problems with accidental activation that I’ve seen.
Now….would it be possible to port it to FW3A?
I don’t think so, you can’t drive a LED and make it sense at the same time. It works on Lux-RC because they have an auxiliary LED that they use as a sensor.
But we have more and more lights which feature aux LEDs as well…
Can we just stick with programming pins + USB for the foreseeable future? We aren’t going to make a Lux-RC clone with $0 budget at a random Chinese factory
OTOH, I’ve heard it’s difficult to configure the sensitivity in a way which doesn’t get false positives or false negatives. I’ve heard the reflection sensor has a tendency to either fail to detect reflections from dark surfaces, which are the most likely to start fires… or a tendency to trigger itself when it shouldn’t. It’s neat, but due to the light-absorbing and heat-absorbing properties of black matte materials, the types of surfaces it really needs to respond to are exactly the ones it has difficulty with.
I’m not sure the default values really fit in a generic manual though, since they are different for each model of flashlight. A lot of options really depend on which light it’s being used on. So I mostly tried to write it in a way which can be copy/pasted into the middle of a printed user manual with only minimal need for editing.
