All images shot with 5600K WB
I voted 4.
My reasoning:
1 = very blue.
2= shadow is to brownish
3= shadow is to brownish
23 hours to guess….
Good night everybody Zzzz….Zzzz…
- Clemence
Aargh !! The suspense is killing me !
I have monitor so bad I won’t even guess…
If we’re guessing specific emitters…
1. Cree something. Probably whatever the Jetbeam comes with. CW, green, and low-CRI.
2. Neutral, but not especially high CRI. Under 90 - could be 80. 119D or 319A.
3. High-CRI, but not the highest here. Rosy tint. 219B or E21A, most likely. Could be E17A.
4. Highest-CRI. Optisolis.
My guess is that
1 is some cree, maybe >70CRI though
2 is 219C 90CRI
3 is E21A
4 is Optisolis
I voted 1 for highest CRI, but perhaps above the BBL.
It’s really hard to see the difference on a LCD because the color reproduction is so horrible, especially on a TN panel.
I think 2 is the highest CRI. However the CCT is not the same on the 4 emitters so that makes it harder to compare. In reality, when our eyes are adjusted to the CCT, it makes less difference than what we see on the monitor.
same here … and still going on while my Apples are laying beside … nothing is better than scrolling the old style (but with Logiech’s Infinite thing) …
so, #2 for TN :person_facepalming:
Not being a CRI “connaisseur” I voted the same #1!
I don’t know in which order I would line them up after that (maybe 1 > 2 > 4 > 3 ?), but that was my vote too!
Looking forward to see the results
Hmm… The red of the crayon in pic 1 looks like typical low CRI / red deficit lighting.
But i doubted too, because the glass in pic 1 looks green as glass often does.
Hum, you may be right too!
I was looking more towards the pink crayon, not the red, and it seems more “natural” to me. Hence my vote.
Looking now at the yellow crayon on picture #1, it seems to have less yellow colour.
But my monitor may be influencing my perspective, as I noticed differences between the computer and the cellphone :confounded:
Also, I guess the tint of the light is (the) tricky thing here, leading to see the colours differently. I noticed than when I put the Sofirn CO1 (both colour temp) against Nichias and NW XP-G2. The first impact was the same, but going into detail the differences could be seen.
Despite, I will keep my vote on #1 and let the right correct the wrong
How sure can we be this test, with side by side comparisons, isn’t also a demonstration of the aforementioned Slider effect ?
OK, for those downloaded the quiz answer, here’s the password: thepasswordisthepassword
ANSWER:
1. Maukka Calibrated Convoy S2 @medium mode(Cree XML2)
CCT = 6497K
CRI = 74,8
R9 = –11,2
Duv = 0,0012
2. Maukka Calibrated BLF-348 (Nichia 219C)
CCT = 5025K
CRI = 92,5
R9 = 84,4
Duv = 0,0038
3. Jetue21a at 230mA (Nichia E21A sm503 R9080)
CCT = 5333K at 700mA
CRI = 97
R9 = 85
Duv = –0,0011 at 700mA
4. Jetusolis at 230mA (Nichia Optisolis sm503 Rfc00)
CCT = 4852K at 65mA
CRI = 99
R9 = 93
Duv = 0,002 at 65mA
My Observation:
As predicted, it’s harder than comparing R70 to R8000 or R70 to R9080. Because I used 3 LED with measured value above R9080. To make things worse I believe most people here still limited to LCD, LED, or AMOLED screen with RGB light source. Until there’s a full spectrum screen, reliable CRI proofs can’t be shared as images. Quantitative data such as Maukka’s test is the only valid reference point. In image 4, we can’t see how Optisolis makes green, blue, purple, and violet “glows” as E21A does on all red pigmented crayons (pink, orange, yellow, red, brown) because most monitors still can’t reproduce wide range cyan.
Most, including me, judge the CRI by the vividness of each colors. But it’s harder because the tint masks them all. Number 4 which was Optisolis has the most neutral tint (background) yet keeps the entire color vivid, the majority will choose it. Tint is dominant shades that covers the entire scene. Any colors will be affected by the shades.
High CRI LED will makes each color has their own personality no matter what tint/shades added on them. Easier to distinguish. This can be seen under very warm CCT such as Nichia E21A 2000K and low pressure sodium. In both cases, you will not find any white but you can easily distinguish which is which under E21A 2000K. Under LPS everything looks almost the same, sometimes false. The same goes for pink/rosy tint. You can see how everything looks reddish under E21A, blue looks darker and somewhat purple-ish.
Here’s my old picture under LPS lights. Can you tell the colors?
And this is a fresh picture using Maukka’s Jetue21a 2000K R9080:
Of course you can’t see blue violet purple etc… properly as under cool white because warm white light source even ultra high CRI such as very warm incandescent has very limited spectrum towards those colors.
Green and yellow shades relates to sickness and dizzyness for most people. Red - Orange shades relates to safety and comfort. Red/pink shades relates to cheerfulness, energy, happines, and….arousal. How about shades of blue/magenta? I find most people find it as cold and mysterious. IMHO, our brain evolved to welcome/accept positive and safe traits more readily.
We can easily adapts to different shades after a while (30+ minutes?) and find everything looks normal with time. But sudden change will confuse our brain. Test yourself by entering a room lighted in 3000K in the middle of a sunny day and you’ll get what I mean.
In above quiz E21A and XML2 were the tricksters while Optisolis was the honest one. Get a Nichia or Lumileds catalog and you will find how they tailor made LEDs to help lighting designer to trick their customers by offering different kind of spectrum sets for every needs. 219B sw45k and the likes was designed for specific target such as fresh meat in the grocery stores. But some also found it extremely good to increase baby population.
Check this link: Special CRI
- Clemence
Woop, what do I win? A bill for your Jetusolis? Ok Ok, i’ll pay it…
Hey, i had it right !
What did i win???
You, Jerommel, and Zak answered it like a champion. You guys can share the crayons. Where shoild I ship it?
- Clemence
For my acceptance speech I would like to thank: my IPS monitor and my 2 year old
