Utilize CREE XML2 U4 LED with lifespan up to 50,000 hours burn time;
Powered by one 18650 battery and two CR123A/16340 batteries;
Avant-garde design of main light and secondary lights for widely use(Patented);
Mechanical rotating bezel design for multi-colored LEDs changing(Patented);
Digitally regulated output maintains constant brightness, reverse polarity protection;
Maximum 600lumens with beam distance up to 100 meters and 38 hours runtime;
Secondary multi-colored LEDs are for widely use with maximum runtime over 45 hours;
Additional warning and strobe light function to meet your outdoor safetly requirement;
Quiet noise click button switch for power on/off and light level output control;
Made of durable high-grade aluminum, Type III hard-anodized anti-abrasive finish;
Lightest-weight (108g battery excluded) and compact appearance design(size 76x43x32mm).
The mode spacing is not bad for a headlamp with 3 modes. I rarely use moonlight on a headlamp its not really enough light for most task while fishing. Imagine hooking up a jig on moonlight mode?
