BLF-348 was never as nice a tint as the original A01. The 348 tint and CCT was all over the place, depending on the unit (I have several). The A01 tint was very consistent, and a very pleasant 4000K high CRI (I have several of those too).
My only gripe with the A01’s is the weak lens. I’ve had a few crack/break on me and it isn’t easy to find inexpensive replacements. With my latest replacement for my copper A01, I’ve used Sellotape on either side of the lens to give a little protection to it.
More in the other thread at Astrolux A01 about fixing the mode bouncing
(fished out the spring, put conductive lube on its wide end, pushed it back down the tube)
I think it only goes to “next mode” if you’re in a hurry to turn it back on.
Otherwise mine consistently start in low mode.
Haven’t timed it to figure out the delay, which would be set by that capacitor the pencil mod discharges.
But I haven’t tried getting the driver out of mine.
Several hours or overnight. And I didn’t get “next mode” I got “some other mode” - quite unpredictable, jumping from low to high or low to strobe to medium. As someone else described a few pages back in this thread.
Definitely needs the “pencil mod”or a resistor added over the capacitor.
I’d like to speak to the purchasing agent who saved a couple of pennies per light by dumping the good Manker driver and replacing it with a cheaper one.
Yep, both the original Manker driver and the current crappy “some other mode” driver for the Astrolux A01 has you cycle through L-M-H twice before it starts strobing.
It’s the added low-level before it starts strobing that strikes me as peculiar. It’s not supposed to do that.
I’ve got several of both BLF 348’s and AO1,
plus some others to compare.
The BLF is a fine light. Does it’s job. ON/OFF. with plenty of light.
BUT NO SOUL.
Just a smooth stainless tube with the “Singfire” model having more output.
The AO1 has “not so much” light. with differing levels,
But. both looks and feels good in the hand. Bonus.
The little Convoy (Stainless) I carry on keyring. 85ish lum.
On/OFF.
But you can’t hurt or scratch it.
Also. My little Copper O’light, 2 levels. Beaut light.
Second level, on bedroom wall. Equal to MID on AO1.
It’s NOT the strongest but the nicest light.
I just turn it back (or forward) to Low. Before turning off.
Problem solvered.
PS.
What the hell would anybody want a flashing cycle for on a toy torch.
I don’t even use it on the big ones.
In case you accidentally fall out of an airplane and end up on the side of a mountain, you can cycle thru all the modes to realize you got the driver without the strobe after cycling twice ...then you get eaten by a bear
I use strobe in crosswalks when crossing any street — even if I don’t see a car coming because one may pull out and race in my direction faster than my reaction time to pull out the flashlight.
So the little A01 is handy for that in case I’ve forgotten a bigger light.
The idea is to distract the drivers from their cell phones.
Yeah, pretty much…. so far so good. But I can’t let down my guard.
Trying to settle on one I like. The one now (Crystal Mill / Crystal, CO) is neat… but not for an avatar. Gonna change it again soon.
