Opinions on Elzetta lights
46 posts / 0 new
CREEXHP70LED
CREEXHP70LED's picture
Last seen: 4 days 23 hours ago
I am looking for opinions on Elzetta lights, as the next two lights I plan on buying are the Charlie and the Bravo models. ( Then I will get back to the cheaper lights after I have a couple tough potted lights ) I know the cons to the light might be Cost, Non-rechargeable cells except the Bones model, although Overready bores them to a 18650 size. Other cons might be output 900 lumens. They are however true lumens for almost 1 hour . Then there is the fact that you get one or two levels of light.
I do not mind the CR123A only factor. (I have over 100 SF123A cells. ) I can live with the cost of these lights for them being tough ( fully potted electronics ) 100% waterproof and simple operation UI as simple as click on/click off. I have the Surefire P2X Tactical and the P3X Tactical lights , but they are not the quality of Elzetta though, also the optics on the Elzettas will make them different too as will the tint.
Opinions on these lights is appreciated!
contactcr
Last seen: 23 hours 19 min ago
Disclaimer: I’m not the target market for these types of lights
With that said I think I would rather go with a PFlexPRO which takes standard 18650’s, has more configurable firmware and emitters, and is still potted. Sure their website doesn’t have a bunch of tacticool AR’s on it but I think the lights should hold up just the same, with better configurations (IMO) for half as much money.
Random Dan
Last seen: 2 days 23 hours ago
I have an AVS Bravo that was bored for 18650 by Oveready. Only reason I bought it is I found a good deal on it used. It is a fine light but if I were in your position and wanting a simple operation, potted, and highly reliable light I would look at Malkoff first.They have a similar, if not better, reputation for quality and customer service, but offer many more options for beam type, output, tint, voltage range, etc. plus 18mm bore as standard.
will34
will34's picture
Last seen: 3 days 3 hours ago
I don’t doubt their reliability, but you’d be getting 2014 tech at 2014 prices
toddcshoe
toddcshoe's picture
Last seen: 15 hours 50 min ago
I looked at their website. There is no mention of driver specs or even what emitter and tint are used. That would be a bit of information I would expect to get with a $200 dollar flashlight regardless of how well it’s made. If we had driver specs we would be able to tell if we could run 2 16340’s in the light instead of CR123’s. I imagine it would accept a 16650 without a problem. Those cells are a bit harder to find but they are still running around. I agree, I would look toward the Malkoff or even a Armytek.
ChrisGarrett
ChrisGarrett's picture
Last seen: 4 min 5 sec ago
They’re a top notch weapons’ light for critical applications, like SureFire.
If you’re not into the ‘shooty’ stuff, or have firearms, there are probably better/cheaper choices out there.
Chris
toddcshoe
toddcshoe's picture
I have lights on quite a few of my firearms. I have had a few surefires. had a streamlight or two as well. They lasted for a year or so. They broke. Got tired of sending them back. I started buying lights that had what I wanted and making them work for me. They have been going strong for years now. I am not one to leave anything well enough alone. Smile
texas shooter
Last seen: 18 hours 8 min ago
A few of my fellow deputies carry them and regard them highly. For work or duty use these are in the top pick list. CR123A’s aren’t an issue as they can be found for a buck a piece or less and have a 30 year self life. The Bones model is 18650 ready.
sesgum
sesgum's picture
Last seen: 1 week 1 day ago
I still have a bravo with avs head, and a m60 based 2 cell light. Meant to sell them though.
I do not like the beam from avs optics. The m60 light has a beam similar to that of a surefire e2d 200 lumen, still inferior though, beam has a ring, and less throwy.
I will not recommend bravo avs to my friend for $200. Maybe they have their values in terms of extreme reliability, I just don’t have a use for that. Similar situation for my hds, I agree it is a nice light, but not $200 nice to me. Again just too lazy to put them for sale.
ChrisGarrett
Most of the quality Panasonic CR123As made in the USA and Japan, as well as the Sanyo~Japan sourced cells, have an expiry date of 10 years, not 30 years, but yeah…they should be a monetary problem for ‘departments,’ or people buying Elzettas.
It’s like the Ferrari owner worrying about tires, or an oil change.
Chris
CREEXHP70LED
Thanks everyone !
I found a lot of valuable information to consider. Also, it is so refreshing not to see fanboys in the posts. Just honest opinions. Exactly what I was looking for.
I like so many different lights from so many different manufacturers and for so many different reasons it is impossible to keep up with them. I think I will end up buying just the Charlie first or a Malkoff which I have also been looking at, however still can’t find the right one for me. I do have weapons and this light might go on an AR or AK. Thanks again everyone.
CREEXHP70LED
I am not looking for light that takes an 18650 unless it also takes 2 CR123A’s. I need a light that has cells that are CR123A’s. I only have one light that does not fit this criteria the Olight X7.
Without going into specifics too much, certain people are training now in sub zero temps for our next war. While I will not be in said war to my knowledge, I need to be prepared for anything. As should every single person right now on earth. I mean that.
I know some of you know just how bad things are about to get, and you better be prepared for NO one helping you and EVERYONE trying to kill you. I am sorry but the grim truth is if you are not prepared for no water, no food, no electricity, no emergency services, no medicines you might need, no communications except ham radio, no vehicles that will work unless they are older than 1995 (to be sure) you need to check your current conditions. I am sorry to get off topic here but if you think the markets are strong and the economy is strong, you are wrong. PERIOD!!! We are modern day Rome. Heads up people. I only say this to help my friends.
CREEXHP70LED
The AVS head can take 6-9 volts in regulation. AVS stands for Auto Voltage Sensing. At 6 volts you get 650 lumens on the 2 cell Bravo body and 900-930 really on the 3 cell Charlie body.
I am pretty sure the emitters are XM-L2 still.
xevious
xevious's picture
Last seen: 5 hours 38 min ago
I gave Elzetta lights serious consideration for a while, but eventually realized that while they are incredibly rugged, they’re far too over-built for my needs. I do not have any firearms so I don’t need weapon mounted lights that can deal with that kind of shock. My lights are not exposed to frequent hard knocks, submersion in mud, etc. If they were, I’d likely consider an Elzetta.
CREEXHP70LED
Which lights worked for you may I ask? If you are breaking Surefires even diving into rocks I can tell you been there done that and swam across rivers afterwards firearm submerged with the WML dozens and dozens of times my friend.
Please let me know what is better because I will be first in line to buy one.
CREEXHP70LED
Thank you for your input. I have only several LEO friends, but none of them have heard of Malkoff or Elzetta. Such is life.
CREEXHP70LED
Thank you very much for you opinion. Yes , I completely agree that not everyone needs a top tier weapon light and for those people the over built light is most likely not price justified. I understand that, In fact I have my next two light purchases narrowed down to a D18 and an Elzetta Charlie. If the Charlie works for me, I will be getting several. If the Emisar D18 works for me I will be getting more of them as well.
Thank you for your thoughts.
CREEXHP70LED
I completely respect your opinions and reasons why you have not sold them. I have Hinderer knives I should sell, and a lot of Benchmade highly limited runs (as in 50 made total) I should sell them as they are not being used, but I am not paying Bladeforums another dime just to sell my knives. I have been a member there since 1999 one year after they opened in Oct 1998. I am not paying 30 USD a year anymore to make someone rich to do nothing.
EDITED* Can you please explain why you do not like the optics from the AVS head sir ? Do you think the Charlie with the extra lumen would help or not?
BurningPlayd0h
BurningPlayd0h's picture
Last seen: 1 hour 29 min ago
Of course with no food, water or electricity we will all have a plentiful supply of CR123 batteries…
“Without going into specifics too much, certain people are training now in sub zero temps for our next war.”
IDK if Antarctica is really prime real estate. If that becomes arable land we have WAY bigger problems to worry about. Sad
CREEXHP70LED
We are training for Russia. And yes some of us have thousands of 123a cells. Facepalm
But don’t worry Iran is next on our list according to people who planned every war since 1991.
mmalive
The lights seem pretty steep. Considering most use CR123A vs 18650. The outputs are somewhat low as well. These would be in Surefire class. Due to being over priced with low outputs.
junkyardbiker
I have my old duty ASP Triad CR bored for 18650 as my home weapon light and its has held up well on a deployment and now on my ARX. I also just had a Nailbender P60 in a Solarforce host and it serves well except I dont care for it being 2 mode. The ASP light it perfect because it is a single mode with a twist tailcap to select momentary only or FWD clicky on. Sturdy light and not badly priced.
Lurking flashaholic, Ive bought all my flashlights through lurking here, BLF A6, Sofirn C8F, Soforn Q8, Emisar D4, and a few not so budget lights but I mod them all the same! Been waiting for the FW3A to come out for years now.......
delusional
delusional's picture
Last seen: 2 weeks 4 days ago
I got two bravos and a charlie. All with my name and phone number engraved on them. I always tell people “If you get an Elzetta, you won’t be sorry… Until the day you lose it., at which point you will be quite sorry indeed.” That’s why I put my number on them, one of my bravos was returned to me after being lost for two weeks. There’s still a few decent people still out there.
I had had some bad experiences with nitecore, and went searching for better reliability just at the time the bravo/charlie thing first happened. This means my elzettas are pretty close to as old as they get, going on six years now. At least one of them has been with me, all day, every single day since I got them. I believe the construction job I do is just about as punishing an environment they could be in. The amount of water and dust they have to put up with is extreme. I do a lot of plumbing, and it’s more than adequate for the purpose.
The flood lens (LENS, not reflector) is completely awesome for close up work. It surpasses ANY other system of reflector or diffuser. I cannot say enough good things about the flood lens. It must be experienced to see just how good it is. The throw lens on my Charlie is also extremely nice. In my opinion it’s these lenses that keep Elzetta a hair above Surefires of the same brightness.
Forget waterproof, you can take any Elzetta apart and put it back together WHILE IT’S UNDER WATER. One time an idiot dropped one of my bravos into a bucket of latex paint, I didn’t even think twice, I just hosed it off and put it back in my pocket. It pays to keep the threads screwed down tight, but the head tends to not light if it’s even a little loose… so it’s always tight. But it wouldn’t matter if it was a little loose.
Tough? I used to tell people, “Go ahead, throw it down the street as far as you can.” AND THEY DID. Five times it was thrown, I had to file off a small burr once. No damage to the light but it does hurt the batteries, so i had to stop throwing it.
No, they are not the brightest, but that’s really the point. You are not overdriving the battery, the LED, or the electronics. Long runtime! How often do you really need more than 650 lumens? Take it easy, cowboy. Just today I left it running under a dishwasher and went out to the truck for half an hour. It was barely warm. Still had enough battery to finish the install. I get about 75 minutes on a 3400 ma/h battery, and 60 of those minutes are at near full brightness.
The only thing that’s a little wonky is the high-low switch. It’s not perfect but it does hold low well, after you fidget with it for a second or two. The only time i use low is when the battery is low, and i need stretch time.
About this time you’re wondering if I’m getting paid, and the answer is no. I’m just an extremely satisfied customer. After six years, what’s not to love?
If you’re collecting, I could see passing it by. But if you’re going to trust your life to a light…
I say again: If you get an Elzetta, you will not be sorry… until you lose it.
More:
I got all of mine bored by Overready, but going forward I’m not so sure they’ll be doing it forever. You might be stuck with the Bones light if you don’t want 123’s.
Never really cared exactly what the emitter is, it’s 650 lumens of great tint and just about the highest CRI there is, You can rest assured that Elzetta is not using jenkem emitters.
Elzetta’s spokesman, Dave Barnett, is also just about as good as it gets. Highly recommend going to Elzetta’s blog page and he will clarify any concern you have. The two “beam” vids are must-see.
BurningPlayd0h
Outputs are low because these lights stay within the safe current draw for CR123 cells. Most of the “normal” brightness rating you see for these emitters are them being over-driven too, so the lower max outputs are to ensure long lifespan and reliability.
Lightbringer
Lightbringer's picture
Last seen: 21 min 16 sec ago
Wellp, thanks to vipon, I got a 16pak and 20pak of ’123s not that long ago…
delusional
Overready does not appear to be doing bore runs any longer. The thread was locked nine months ago, and they linked here as a possibility… https://precisionelectrical.us
CREEXHP70LED
Correct, as one of their blogs shows the Amp draw difference from the P3X to the Charlie, Bravo and Malkoff model.
The Surefire’s were drawing more the the cells rated max Amps at first, although I believe that was to get 1,300 lumens out of the light turn on and still get 1,000 lumens out of the light at 30 seconds. To me, I do not like that. Yes, I own P2X Tactical, P3X Tactical Titan and Titan plus , PLUS all my Surefire WML’s.
Mean while I currently own ZERO Elzettas but will soon and I love their Constant output of at or above 900 lumens for about one whole hour.
Meanwhile, Surefire starts about 1,300 lumens and then decides to run a quick drop to about 650 lumens after just a few minutes. I will try to look up their graph
CREEXHP70LED
Use them sparingly, or not at all if their dates are good.
CREEXHP70LED
100% correct my friend!!!
CREEXHP70LED
More:
I think you and I are like minded. I agree with everything you have mentioned. Remember everyone, sometimes it is not about sheer lumens but coming home alive. With a quality built illumination tool that is rarely rivaled.
Then there is the other side of the coin, BLF. Yes like a 100 USD D18 light that does 14,000 lumens for 20-30 seconds then goes to 2,000 lumens . Bright and fun yes, But give me that Elzetta OR Surefire to get me back home in one piece.
CREEXHP70LED
This explains it well. I can’t even imagine what many of the Chinese manufacturers are doing. Pushing LED’s past max, making them smoke or burn out, or maybe I can. Since the reliability is like flipping a coin on some brands. They are toys though so I understand it, and trust me the D18 I will buy it, but Emisar is one of the finer Chinese companies no question .
