chadvone
(chadvone)
January 10, 2019, 11:47pm
6278
Can be done. I set mine to memorized level. So it acts like another momentary mode but 4 clicks will exit
iamlucky13
(iamlucky13)
January 11, 2019, 12:07am
6279
Yep. That’s the “discrete ramp” feature you may see talked about for the Anduril firmware. When the light is on, 3 clicks switches between the smooth and discrete ramping. It’s a bit difficult to say what the exact output levels will be, but you can get roughly those ballparks.
By default, the discrete mode has 7 levels, and for the FW3A, the lowest discrete level will probably be around 5-10 lumens and the highest discrete level 800-1000 lumens*, but both the number of levels and the brightness of the minimum and maximum levels can be configured.
\ Assuming I understand the relationship between the 8 bit PWM values and resulting 7135 current correctly.
hodor
(hodor)
January 11, 2019, 12:10am
6280
Yes, this is part of Anduril. Basically you change it to stepped mode and configure the levels yourself. Checkout the UI graphic or the anduril-manual.txt mentioned a few posts earlier.
iamlucky13
(iamlucky13)
January 11, 2019, 12:19am
6281
ToyKeeper:
I recently found a way to eliminate a bunch of code, to make room for new things. I’m hoping to do some fancy stuff with aux LEDs in that space, but no hardware exists for it yet.
Anyway, putting other-ramp floor on “click, hold” costs about 60 bytes and makes the light act a little weird when doing 4 clicks to unlock. Instead of “moon moon moon moon”, it goes “moon LOW moon moon” or “LOW moon LOW LOW”. So for now I think I’ll leave it as a compile-time option which isn’t enabled by default.
Nice to hear. My ROT66 is one of the earlier aux LED versions with an entirely stand alone aux board, but maybe in the future I’ll see about a swap if the firmware offers more advanced functionality.
joechina
(joechina)
January 11, 2019, 2:59am
6282
joechina:
joechina:
Guys what are you thinking about this:
In LOCKOUT MODE:
- hold : momentary moon (= floor from current ramp)
click, release, hold : momentary 10 lm (= floor from other ramp)
Good or bad?
(but I don’t know if this possible to program)
Idea is:
In general I want the ramp start at moonlight.
And for normal carry I lock high power lights out.
It is for the same use case as Lockout momentary, but when you use it and realize you need more light, like: Oh, 1 lm is not enough I need ten times more.
ToyKeeper:
So, it is added? And it is only for the guys with a flash adapter!
Tank you Toykeeper! :+1:
Beside the “random” blink at unlock, does it feel useful?
mgracia85
(mgracia85)
January 11, 2019, 3:29am
6283
I am already down for one, but can you add me for one more please
NWoodsman
(NWoodsman)
January 11, 2019, 3:49am
6284
Toykeeper, it seems there are earlier posts in which you mentioned you have a prototype.
Can you make an Imgur album and give us the second best thing to an FW3A (a bunch of photos of an FW3A)?
Disassembled, assembled, next to other lights, sitting in snow, etc. Whatever you feel generous to provide.
aeon
(aeon)
January 11, 2019, 2:39pm
6286
One with LH351D for me, please.
Thank you!
Jodok
(Jodok)
January 11, 2019, 7:23pm
6287
I‘m usually active in the tlf but now it looks like both threads there are closed. Does someone here know more about that?
leo_l
(leo l.)
January 11, 2019, 7:27pm
6288
new links,now in “TLF-Fanartikel”
Hallo,
nachdem viele von euch schon seit langem auf ein Update zu Fritz‘ 3000 Lumen EDC warten, freut es mich umso mehr, euch nun die Ergebnisse unserer bisherigen Arbeit vorstellen zu dürfen. Obgleich es in eine andere Richtung geht, als die...
DavidEF
(DavidEF)
January 11, 2019, 7:29pm
6289
You have to be logged in to see this? :person_facepalming:
leo_l
(leo l.)
January 11, 2019, 7:33pm
6290
sorry, I only answered Joduk’s question.
cabfrank
(cabfrank)
January 11, 2019, 7:34pm
6291
Do we assume that means we are getting very close and they are not adding any more to the interest list? Or something worse?
Bob_McBob
(Bob_McBob)
January 11, 2019, 7:44pm
6292
I have an account at TLF and I also can’t view any of the FW3A threads anymore. What’s going on?
Please add me for 1x LH351D
Many thanks.
teacher
(teacher)
January 11, 2019, 8:08pm
6294
Hmmm… probably best to assume nothing either way . TK or someone will let us know what is happening when they know.
Bluzie
(Bluzie)
January 11, 2019, 8:27pm
6295
Sorry my mistake, i moved yesterday in our ‘Marketplace’.
Now you can find the german FW3A Thread here:
Sammler- & Customlampen
Regards from TLF
Bluzie
cabfrank
(cabfrank)
January 11, 2019, 8:44pm
6296
Good idea, teacher. I think I remember learning somewhere what happens when we assume.
