teacher
(teacher)
March 16, 2019, 2:48am
1449
Unless I missed someone, I count 19 people to date who have posted about switch problems. They are….
djozz // Reported RESOLVED
mortuus // RESOLVED
teacher // RESOLVED
RobertB // Reported RESOLVED
gabo // RESOLVED
Cereal_killer /
Jhicks2018 // RESOLVED
P33 / // RESOLVED (“partial refund” reported)
Coyotehawk
X3 / // RESOLVED (PayPal dispute refund)
illuminos
Silent_Star /
Juheebus / // RESOLVED (Replacement head)
mb200k
Pulstar // RESOLVED
A92AA0B03E / // RESOLVED (Replacement head)
komeko // RESOLVED <span class=“+ “HERE ”:(prototype) the GT Mini - #1417 by komeko +explained refund… & dispute PayPal”>
Th558 /
Icarus / //
Anyone else having any type GT Mini switch problems besides the people I mentioned above??
List updated . Icarus Added, 9 January 2019
teacher
(teacher)
January 9, 2019, 2:51pm
1450
I added you to the list Icarus, keep us posted. Good luck……
Igor
(Igor)
January 11, 2019, 4:16am
1451
Can anybody confirm me if the top of the ramp is 50 or 80% brightness? The manual says 50, but I’ve read in some places that it’s 80%.
JasonWW
(JasonWW)
January 11, 2019, 6:14am
1452
It depends on how you measure it. It’s probably 80% of the ramp steps which is about 50% the lumens.
I got 700 (2.8A) lumen at top of ramp and 1200 (5.5A) lumen on turbo. So make of it what you will.
Igor
(Igor)
January 11, 2019, 12:04pm
1453
So it means if we use the ramping UI, we can’t access between 50 and 100% lumens? That’s not cool.
Igor
(Igor)
January 11, 2019, 1:33pm
1454
I also found what appears to be a firmware bug. See if anyone can reproduce it.
In ramping UI, with strobes disabled, if the ramping is at maximum (50%), double click turns on turbo, but double click again turns off the flashlight.
If ramping is at any other brightness other than maximum, double click turns on turno and double click again returns to the previous ramped brightness.
I’m pretty sure yesterday it worked well, today it’s not working. I performed a factory reset and nothing changed. My firmware is 1.3.
Any tips?
JasonWW
(JasonWW)
January 11, 2019, 2:23pm
1455
It’s only like 1 step. There is not a lot of difference.
JasonWW
(JasonWW)
January 11, 2019, 2:26pm
1456
Igor:
Any tips?
This has been discussed before. Was it not in this thread? Maybe it was another GT Mini thread. It’s just a quirk.
M4D_M4X
(M4D M4X)
January 11, 2019, 2:29pm
1457
Thank you Jason for your help!
JasonWW
(JasonWW)
January 11, 2019, 3:30pm
1459
Igor:
Any tips?
It was talked about in this very thread 2 weeks ago.
I see what you mean. The fact of the matter is that a dbl clk is not designed to return to the previous level. I think it’s just a glitch that it does (assuming you have blinkies disabled and are below the ramp top).
The solution is to just slow down your button presses. Don’t try to dbl click. Just let the light turn off and back on. This is how all my other Narsil based lights works.
Or, if you like that ability, don’t run it at the top of the ramp. Run it just below the top.
Igor
(Igor)
January 11, 2019, 5:03pm
1460
Thanks for your patience Jason. I read the whole thread before I had the light in my hands and somehow I forgot it was mentioned here. Guess I’m getting old. And like chadvone said, I too find it annoying this glitch.
JasonWW
(JasonWW)
January 11, 2019, 5:48pm
1461
No sweat, I forget stuff all the time.
scr79423
(scr79423)
January 15, 2019, 6:24pm
1462
does anyone know what size mcpcb the GT mini uses?
Icarus
(Icarus)
January 15, 2019, 7:00pm
1463
Thanks! Another message sent to Neal. I'll keep you updated.
M4D_M4X
(M4D M4X)
January 15, 2019, 8:13pm
1464
my early sample was 16mm, buzt ZozzV6 had several open and says they are 20mm
scr79423
(scr79423)
January 16, 2019, 3:13pm
1465
i bought a SST-40 led for my GTmino but i can’t seem to remove the bezel, how did you guys do it?
wellerus
(wellerus)
January 18, 2019, 3:30pm
1466
Hi, Is it possible somehow fix or rotate rubber switch cover, because it's rottated too much to the left?
"foto":https://imgur.com/a/qIwBw3i
teacher
(teacher)
January 18, 2019, 3:48pm
1467
You can pry the press fit retaining ring up & rotate the switch cover / switch to your liking. That might be more trouble than it is worth though…. but that depends on how much it bothers you.
wellerus
(wellerus)
January 18, 2019, 3:53pm
1468
You mean i need to rotate a silver ring with some tweezers and not a rubber cover?
