If you want 26650 size, a reflector type of beam pattern, and high output (over 2,000 lumen, you would need to look at the many xhp50.2 and xhp70.2 lights that use a boost driver. There are like 20 of them or more. They are getting popular. In my sig I talk about the ODF30 and SP33 (I really like the SP33).
If you donāt care about a reflector style beam pattern, you have a lot more choices with lights using a TIR lens. Some use boost drivers, some donāt. The many leds can be wired in different ways.
I know there was a problem with the driver from the first c8f 21700 that didnāt reach the claimed lumens, and sofirn released a second version of the driver
Maybe this light is using the first underpowered driver?
I donāt think there was ever any problem with the driver. There might be a lack of current flow through the retaining ring. Maybe glue on the threads? Adjusting it gave me a boost in output. Also changing the led wires can give a boost.
It will not hit 3500lm stock. I think they over rated it. About 3,000lm stock seems right.
Being a FET driver, the output can vary a lot based on the battery. What battery are you using? How are you measuring the lumens?
Both Sofirn and GearBest have confirmed that Utorch C8F will not have previous Sofirn issue. My C8F from very first batch did produce 3300lm with my VT5A.
I was the one who told Sofirn I suspected there was a problem with their original driver since output was low and it would not pull many amps. Possibly a FET with too high resistance. Their second driver version using a new FET had the same performance.
I then told them that there seemed to be something about the retaining ring that was not getting good contact. I never heard back from them other than they would tell their engineers. Maybe they tweaked the retaining rings to get a better connection? I donāt really know.
What type of integrating sphere do you have? Do you think itās accurate?
Have you tried measuring the amp draw across the tail cap?
