I experienced something similar. It’s what gave me the incentive to make my flip-up cover.
3 weeks ago, burned a 1” circular hole in pocket. No damage to exterior of pants or my leg, but giant hole in pocket. Then a couple days ago burned a hole in a brand new pair of pants. This new hole isn’t a full circle and it’s near the edge. Maybe I can sew it up and save the pants.
I think one of the problems is the electronic lockout is way too inconvenient. 6 clicks for lockout is waaaaaay too awkward. 3 clicks would have been much more sensible.
Try to reflash your light with Anduril. Lockout is 4 clicks, 1 more than you would like, but less than 6. I agree 6 is way to many for lockout. 4 is manageable IMO. Also get the bonus of when you press the button in lockout you can get some light, which IIRC is the bottom of the ramp. So if you are locked out, and need a little light, you can get it quickly. If the button is pushed accidentally during lockout you won’t run down the battery.
3 clicks is battery check, temp check sunset, and beacon mode.
I like Anduril. Just got my E07 yesterday and I find the 4-click lockout acceptable. Still much slower than flipping up my cover and pressing once for turbo though.
I’ve never reflashed a driver, but how hard can it be? … maybe I should get the equipment and give it a shot.
It’s not that hard, but if you don’t have all the stuff already it’s not that easy either. If you wanted to mail me the driver I could do it for you. PM if if you are interested. I have already done a couple correctly.
Filed down a nickel plated brass #14 finishing washer today. The plan is to mount it on a D4 around the switch boot to give more of a raised rim and make accidental pocket activation less likely. I haven’t decided which D4 to put it on, so it isn’t glued down yet. Once I decide, I’ll glue it on with arctic alumina.
Here’s the filed down #14 washer sitting next to an unmodded #14 washer from the same box:
Here it is sitting on a cyan D4:
And on a bare Titanium-copper D4:
Also did a little more work on my flip-up cover. I glued in a bit of paper clip bent into a “U” on the inside of the cover. This fully encloses the bottom of the boot when the cover is closed and provides a hard-stop so the cover doesn’t depress too much.
My conclusion:
The finishing washer looks excellent. When glued on it will look like the light came that way. However, it doesn’t completely eliminate the risk of accidental pocket activation. It just reduces it.
The flip up cover looks ok, especially when in the closed position. I took more care polishing and making a clean appearance than I did with the inside of the cover. Unfortunately, that means the inside of the cover doesn’t look good. I could try cleaning up excess glue inside it and polishing it or I could make a new cover with more care taken so that both the inside and outside look good.
Functionally, the flip cover seems more effective. When it is closed it locks into place from to the sides of the cover clamping down around the switch housing. To unlock it I have to slide my thumbnail under the back of the cover and press until the tension releases. There’s pretty much zero chance the light will ever accidentally activate in the pocket with the cover down. It gives me the confidence to EDC it when turned off in Turbo mode… something I wouldn’t dare do even with the ring or switchboot mod.
Really simple. Cut the trace on the single 7135, cut trace and isolate a single led on the quad, replace with a red xpe. I did it on a Emisar driver first, then ordered a TA driver from Lexel that he drilled a hole and separated the single 7135.
I adjusted Anduril ramping tables.
The way the ramping works, single 7135 for the lows now runs the red led.
