You see, this is my first time to use a coupon code in Amazon, though I have made several orders before. What I donāt exactly remember is after clicking the ādeliver to this addressā, will that be the next step where you can āapply coupon codeā? And if the code is used, will that bring down the price to $4.60 for the pack of twenty CR123s? Seems like a too cheap to be good deal.
My address comes up automatically, so Iām not sure about that. But, as long as you āApply Couponā before you āPlace Orderā it should work fine.
EDIT: When I do it I have the opportunity to apply the coupon at any time before I actually place the orderā¦ IIRC.
Hang on a few minutes & Iāll run through the whole process & report back.
Well, I was doing as instructed, clicked on the āpromotion codeā and pasted the given code, (it was after the āchoose your addressā) but didnāt see any price in the page, just a box to continueā¦I was hesitant to continue for IIRC, Amazon just can be fast in announcing āorder placedāā¦in contrast to using Paypal where there many ways to check the final amount before the āpayā stage.
I will sacrifice one to do a capacity test, I have a RC hobby charger, on what settings should I do the discharge test? What is the industry standard? 500mah? to what voltage? 2.5v?
If itās a 1450mAh cell, then 500ma is .3cā¦thatās good enough.
I donāt know the industry standard for testing uniform capacity but discharging down to 2.8 volts, the usual termination voltage of several chargers is I believe appropriate enough for āourā standards at least!
Itās now gone up to $ 7.20 !ā¦.13min to go as of this writingā¦for a new code at 7.20ā¦quick, what do you think of the quality of this Morpilot brand?
ā¦ā¦ Okā¦. I just checked Vipon & it does seem the code has expired. Butā¦ if you already had it in your cart & had applied the code, it might still work. It canāt hurt to try.
I just got 20 batts for $5.09 shipped
Use the check box on items page for additional 10% off before you put it into cart. Proceed to checkout and use the Vipon code.
