Well, I was doing as instructed, clicked on the ‘promotion code’ and pasted the given code, (it was after the ‘choose your address’) but didn’t see any price in the page, just a box to continue…I was hesitant to continue for IIRC, Amazon just can be fast in announcing ‘order placed’…in contrast to using Paypal where there many ways to check the final amount before the ‘pay’ stage.
I will sacrifice one to do a capacity test, I have a RC hobby charger, on what settings should I do the discharge test? What is the industry standard? 500mah? to what voltage? 2.5v?
If it’s a 1450mAh cell, then 500ma is .3c…that’s good enough.
I don’t know the industry standard for testing uniform capacity but discharging down to 2.8 volts, the usual termination voltage of several chargers is I believe appropriate enough for ‘our’ standards at least!
…… Ok…. I just checked Vipon & it does seem the code has expired. But… if you already had it in your cart & had applied the code, it might still work. It can’t hurt to try.
I just got 20 batts for $5.09 shipped
Use the check box on items page for additional 10% off before you put it into cart. Proceed to checkout and use the Vipon code.
The 20 pack 123A batts were $0.24each @ $4.80
You can only ad 1 item to cart…
Anyone still wanting more of these batts you can still get a 16 pack @ $4.00 or $0.25ea (plus tax if applicable)
with another 10% coupon code and vipon coupon at checkout.
@ Pennzy…… I can’t find the Vipon link for the one I got. . BUT… I think I found an even better deal while I was looking. It says the Code will be available in about 2 & a half hours.
I’ll keep looking for a Vipon link to the one I got & post it if I find it.
Here is the link to what appears will be a better deal……
