I will sacrifice one to do a capacity test, I have a RC hobby charger, on what settings should I do the discharge test? What is the industry standard? 500mah? to what voltage? 2.5v?
If it’s a 1450mAh cell, then 500ma is .3c…that’s good enough.
I don’t know the industry standard for testing uniform capacity but discharging down to 2.8 volts, the usual termination voltage of several chargers is I believe appropriate enough for ‘our’ standards at least!
…… Ok…. I just checked Vipon & it does seem the code has expired. But… if you already had it in your cart & had applied the code, it might still work. It can’t hurt to try.
I just got 20 batts for $5.09 shipped
Use the check box on items page for additional 10% off before you put it into cart. Proceed to checkout and use the Vipon code.
The 20 pack 123A batts were $0.24each @ $4.80
You can only ad 1 item to cart…
Anyone still wanting more of these batts you can still get a 16 pack @ $4.00 or $0.25ea (plus tax if applicable)
with another 10% coupon code and vipon coupon at checkout.
@ Pennzy…… I can’t find the Vipon link for the one I got. . BUT… I think I found an even better deal while I was looking. It says the Code will be available in about 2 & a half hours.
I’ll keep looking for a Vipon link to the one I got & post it if I find it.
Here is the link to what appears will be a better deal……
