thanks ordered one 5000k.
I have the black version…wonder why the silver one is never up for a bargain price…if it were, I’d snag another.
stupid firefox does have again security block everywhere
trying to buy on IE it went 17:00 and price changed to noarmal
Looks like it’s over.
Code AC18 should bring it down to $46
Got one with with SMO shipped.
i guess it doesnt sell as much as the black looking at reviews it has alot more then silver.
Does this have to take “button top” 26650? or both?
well, the cells do need to have contact with each other, my Liitokala’s didn’t work, so i solder blobbed them
The light uses springs on both sides, so button tops are not necessarily needed
Either will work on the driver end, it has a spring. But the cells must contact each other in the battery tube to create the series connection.
Personally, I use flattops & one of these Jaxman battery connectors….
HERE is a link to the ‘Battery Connector’ if you need it.
nice, awesome thanks. I might order me some. So, what’s the big difference between button top and flat top, other than the obvious. Is it the added resistance??? when do you know when you need either or?
@ mgracia85….
1. As long as the driver has a spring either should work.
2. If the batteries have to make a series connection they must touch positive to negative. If they don’t, either use buttontops, solder b(. )( .)b, or use the connector. Some people use magnets, I do not. To me that method sux.
3. Some battery carriers are designed to accept ‘button top’ batteries only due to reverse polarity protection constructed in the carrier. So you must use buttontops, correctly sized solder b(. )( .)bs, or remove the reverse polarity protection designed in the carrier.
4. Resistance between flat tops & button tops is negligible for my purposes.
5. The Battery Connector probably adds a bit of resistance too, but to me it is not enough to matter one way or the other.
Hope this helps……
@ mgracia85….
Hope this helps……
Yes it does. Thanks teacher. no pun intended
use good cells like keeppower which are protected and raised flat tops they will make contact, or unprotected like efest both works its up to you, i wouldnt use that connector really might aswell buy the batteries with built in top instead.
Good, glad it did help gracia85 & your welcome, it was my pleasure!! . :+1:
I have a bunch of Liitokala 26650’s I use. I did not want to use magnets (that sux… ) and really did not want to solder b(. )( .)b them because about half of them just happen to work in series.
Soooo, I just use the Jaxman Battery Connector when need be.
It works great!!! . :+1:
How easy is it to swap out the OP reflector on the L6 for a SMO? If so, what are the steps? Can someone who has never modded a light do this?
Well, that is very easy.
Just unscrew the bezel, take out the reflector, (check if you dont accidently remove the gasket around the led), insert new reflector, screw on the bezel, done!
ok awesome! thanks a bunch
My order is still at the “processing stage”, after 6 days.
Anyone else having this issue?
what tint did u buy ? it says on 2 “Processing time:Expected on January 28, 2019”…
