Oh, I do... And it's a beautiful beam, too.
Body: Nitecore HC33
LED: XHP50 90CRI 4500K
Driver: Caerus 1.7h
Lens: Carclo 10140
Nice mod Tamagotchi. Do you have any more info on the driver?
Sorry I do not speak English.
Output 6V 2A
6 modes including moonlight and turbo
1 short click - on/off
press and hold to switch modes
2 short click for Turbo
PID thermal regulated outputs (turbo and max)
Battery capacity indicator and battery protection
Some very high end mods up there from Kawi and Tamagotchi !
A similar driver is the H1-A: http://kaidomain.com/S026606-H1-A-20mm-3A-1-cell-1-Mode-or-5-Mode-Boost-Driver-Circuit-Board-for-Cree-XHP50-6V-MT-G2-MK-R2
I have seen somewhere a tutorial to use it as eSwitch driver. You have to remove the Capacitor and solder the switch wires on that points, i think.
How did you get that so perfectly centered? I have a C8 with a white flat and I can’t get it that good, and you’re even using an XM-L2 centering ring.
Probably glued the centering ring
Nice Chad!
Thank you for your help.
Nicely done, chad!
Thank You. It needs some tweeks. Drivers from lexel (1- –3+fet)showed up today and my MTelectronics order. Got in hurry and flashed it with the wrong version of Anduril.
Needs a few tweaks, I am having fun
I properly focused a thrower for the first time.
Convoy C8
SMO reflector
Osram “white flat” 1mm²
MOSLED 3030 MCPCB
L4P LD-B4 driver set to 4.5A CC
I 3D printed some gasket with different base thickness to adjust the height of the reflector.
After a few try, I got about 155kCd @10m but I have to make some more precise measurement with a laser meter.
The gaskets are made of PLA which is not ideal given the high temperature but I already planned to print some ABS ones for the next batch.
Now that I saw a 25% increase in intensity I want to do the same for my Amutorch JM70 (FET driver, 2mm² White Flat but only 470kCd ATM)
Hi all.
I want to present the custom. I made it together with Tamagotchi.
Driver Caerus(2,4A)
XHP50.2 (3000K 90cri)
aluminium polished
button with indication(blue)
That is great design k_4 ! An oldschool look with great details, different from everything else. Nice.
And welcome to BLF :party:
Thank you.
i hope , that it just the beginning))
Looks like a lot of work on that body. Very nice
