M4D_M4X
(M4D M4X)
January 11, 2019, 2:54pm
4177
clearance!
some stuff that must go...
https://m4dm4x.com/clearance-deals/
since my deals get stolen from BLF to be published on commercial pages í cannot post "exclusive" deals here atm
i hope you understand
also nice:
15% OFF a lot of items!
WHOLE SITE! - comment your best catch!
use this link: https://goo.gl/8p92MU
M4D_M4X
(M4D M4X)
January 12, 2019, 10:43pm
4178
Hello my dear friends!
Neal sells a very nice light for a very nice price:
Specification:
Emitter: SST20 (1250Lm available in: 3000K 95CRI / 4000K 95CRI / 5000K 75CRI)
SST40 (2100Lm)
XHP50.2 (3200Lm)
Battery: 18650 (not include)
If you want to use 21700 battery,pls add the option 21700 tube
Reflector: 38 mm,aluminum,smooth finish
Lens: Glass with anti-reflective coating
Body: Aluminum with Type III hard-coat anodizing
Swtich: 20mm,10A reverse switch
Ingress rating: IP68, underwater 2 meters
Weight: 184g without cells
Dimensions: 41 mm head x141 mm length
please use my SHOPLINK and the Code: NDNS22 to get 17% discount
also available:
NITECORE MH23
CREE XHP35 HD 1800 LUMENS RECHARGEABLE LED FLASHLIGHT
Deal: https://m4dm4x.com/m4d-m4x-deals/
mihlit
(mihlit)
January 13, 2019, 11:32am
4180
Klarus Mi1C and Astrolux MH10 codes expired, could you get new ones?
M4D_M4X
(M4D M4X)
January 14, 2019, 8:34pm
4181
i just received another list with deals:
please note: do not share my deals on other places!
Item
Code
Coupon price
IMALENT DT70
CHBF1
165,00
Folomov A1
HBGLK
5,69
FOLOMOV 18650S
drop directly
20,50
IMALENT HR70
JKLH1
53,00
LUMINTOP EDC05
BGED5
22,00
Ultrafire 7W Zoomable
drop directly
2,69
Nitecore EC4S
BGEC4S
58,99
Convoy L6
BGCL6
44,84
XTAR VC4
drop directly
14,80
NEW Convoy L2
drop directly
35,49
Astrolux MF02 CW
BGMF02
75,00
Astrolux MF02 NW
BGMF02
75,00
DQG Lighter 2.0
BGDQG1
18,22
DQG 4th
BGDQG2
24,50
DQG Hobi 10180
BGDQG3
16,99
DQG Fairy Brass
BGDQG4
16,99
DQG Slim
BGDQG5
23,75
DQG XP-G2
BGDQG6
31,99
DQG Capsule Mini
BGDQG7
6,69
ThorFire VG10S
BGS70
15,99
ThorFire TG06S Upgraded Version
BGT6S
11,90
ThorFire TK05
BGTK05
14,99
ThorFire C8s Suit
BGC8S
19,99
ThorFire 360
BG360
6,99
5Pcs USB Mini Night Light
drop directly
1,10
M4D_M4X
(M4D M4X)
January 14, 2019, 8:36pm
4182
due to code stealing and brainless publishing of some 4$$holes i cannot get new Klarus deals atm
teacher
(teacher)
January 14, 2019, 8:44pm
4183
/\ … …. Utterly amazing what dipshytes a very few people can be…. but messing things up for Martin & everyone else.
korkfoto
(korkfoto)
January 14, 2019, 8:55pm
4184
Excuse my ignorance, but how the “drop directly” works?
Thanks!
M4D_M4X
(M4D M4X)
January 14, 2019, 9:04pm
4185
i hope they fix those tomorrow - sorry
mihlit
(mihlit)
January 14, 2019, 9:50pm
4186
M4X: And what about that Astrolux MH10?
M4D_M4X
(M4D M4X)
January 14, 2019, 9:59pm
4188
Many of you asked me where to get the RovyVon brand with "Member Benefits" - so i pulled some strings...
banggood listed at first 2 modells (the link in the pictures take you to the shop for detailed infos)
do not forget to check my list for the deals
Features:
Rectangle EDC Angle LED Flashlights
Made of aluminum alloy with Hard Anodization III finish
Utilizes 3 x CREE XP-G3 S5 LEDs, max output 2000 lumens
Uses replaceable rechargeable Li-polymer 2200mAh battery
Max 5C discharge rate
Micro USB charging and quick charge
Breathing charging indicator and low battery indicator
Overcharge and over discharge protection
An internal thermal control sensor
Ergonomic design for a comfortable
Heat dissipation and anti-slippery grooves
Strong detachable reversible pocket clip
Stand capability
Parameters:
Body Material: 6063 aerospace aluminum alloy
Clip & bezel material: Stainless steel
Dimensions: L101mm x W36.7mm x H17.3mm
Package Included:
Accessories: 1 x 1m paracord, 1 x Clip, 1 x Micro USB cable, 1 x extra USB port cover
Features
Semi-transparent luminous body glows in the dark
CREE XP-G3 LED, max output 550 lumens
Sidelight: White, Red, Red flash
Built-in Micro USB charging port
130mAh lithium polymer battery
Charging indicator & quick charged in 45 minutes
Side switch prevents accidental activation
Ergonomic design, one-hand operation
Tail paracord hole
A lanyard and two-way clip included
IP65 water resistance
What's in the box
1*A5 flashlight
1*User manual
1*Beaded chain
1*Clip
1*USB cable
1*Lanyard
*The max output 550 lumens at High mode will step down to 65 lumens in 2 minutes to protect the user and the core components of the light from the heat produced by the light working at High mode.
lotrbfme
(lotrbfme)
January 14, 2019, 10:42pm
4189
Not a huge discount considering that banggood price is higher than MSRP and charges shipping
M4D_M4X
(M4D M4X)
January 15, 2019, 7:03am
4190
I was told they charge banggood rather high
M4D_M4X
(M4D M4X)
January 15, 2019, 9:48pm
4191
banggood created a collection for the most wanted items paired with a nice discount :
also they added some additional promotions and deals for you!
Let me know what you scored ;)
edit:
the mobile webpage (m.banggood....) has a problem today
the link above does work
banggood tries to fix that asap
in the mean time use a pc or set your mobile browser to "desktop mode"
teacher
(teacher)
January 15, 2019, 2:53pm
4192
The link does not work Martin…. for me anyway .
M4D_M4X
(M4D M4X)
January 15, 2019, 3:48pm
4193
just the mobile webpage (m.banggood....)
the link above does work ;)
neBstress
(neBstress)
January 15, 2019, 3:55pm
4194
Doesn’t work on my phone but works on my laptop.
[Edit]
Oops M4D M4X beat me to it and posted explanation
By the way, thank you for all the great deals M4D M4X!!
teacher
(teacher)
January 15, 2019, 4:22pm
4195
just the mobile webpage (m.banggood….)
in the mean time use a pc or set your mobile browser to “desktop mode”
Oh… OK, thanks Martin. Sorry about the ‘false alarm’. .
Tom_E
(Tom E)
January 15, 2019, 5:48pm
4196
BG is killing me with their great discounts on non-stock items though, then like what happened to my over the holidays, ordered 2 lights at a great deal, not in stock, asked to split the order, I did and chose to keep the order alive, then they cancelled it on me with no explanation, and of course, coupon codes expired, can't be re-ordered at the same price...
I'm seeing the same thing in those collections of non-stocks. Is it a teaser? Well, probably not intentionally but effectively...
I still get the big XMAS code discount on a couple lights though that are shipped, so it's not everything for sure, just some.
