How did you get that so perfectly centered? I have a C8 with a white flat and I can’t get it that good, and you’re even using an XM-L2 centering ring.
Probably glued the centering ring
Nice Chad!
Thank you for your help.
Nicely done, chad!
Thank You. It needs some tweeks. Drivers from lexel (1- –3+fet)showed up today and my MTelectronics order. Got in hurry and flashed it with the wrong version of Anduril.
Needs a few tweaks, I am having fun
I properly focused a thrower for the first time.
Convoy C8
SMO reflector
Osram “white flat” 1mm²
MOSLED 3030 MCPCB
L4P LD-B4 driver set to 4.5A CC
I 3D printed some gasket with different base thickness to adjust the height of the reflector.
After a few try, I got about 155kCd @10m but I have to make some more precise measurement with a laser meter.
The gaskets are made of PLA which is not ideal given the high temperature but I already planned to print some ABS ones for the next batch.
Now that I saw a 25% increase in intensity I want to do the same for my Amutorch JM70 (FET driver, 2mm² White Flat but only 470kCd ATM)
Hi all.
I want to present the custom. I made it together with Tamagotchi.
Driver Caerus(2,4A)
XHP50.2 (3000K 90cri)
aluminium polished
button with indication(blue)
That is great design k_4 ! An oldschool look with great details, different from everything else. Nice.
And welcome to BLF :party:
Thank you.
i hope , that it just the beginning))
Looks like a lot of work on that body. Very nice
+1 on what the others have said. Lovely light and welcome to BLF k_4.
I took 3 rather plain looking Idaho potatoes and turned them into a golden pile of crisp heavenly French Fries, with Sea Salt on them. My son did the high pitched Nirvana sound….
Ooh, gimme.
I told Daniel that next time I need to just double up on the fries and forget the hamburger. Simply cannot believe how good these things are!
Literally modded a bunch of sh*t I picked up off of the floor into something that should turn out pretty awesome I hope. Behold the can of mystery…
Loosen the bezel a little just when I smack the head side the reflector is able to move a little. Not complete rattling just it can slip a little. I powered the light on and raised above my head pointing to the floor with loosened bezel and looked the beam and smacked the head lightly and tightened down a few times the bezel until I was happy with the result. I didn’t used glue and it only took a minute.
A teaser for now until I can write a proper post. I managed to short 2 BeCu springs so I dont have enough energy after “repairs” to go into details tonight!
