Maybe I’m the one who missed it, but IIRC, the driver design is limited to 7 chips per channel, total of 14, for 4.9A (unless the 380mA chips are used, then 5.32A would be possible). Several of the long-time members have done stacking in the past to get more, and they could presumably do that with this driver. But most of us current members wouldn’t.
For this lantern, 7 chips per channel is much more than is needed. And the charger is limited to a low rate, despite many members wishing otherwise, because many solar chargers can’t handle too high a current load and will shut off, failing to charge anything at all. So yeah, that concept (using a solar charger for this light) is very much still there.
The present PWB has two 7135s hard wired to drive the two banks of lights. Up to 7 can be connected by applying a solder bridge to the pads on the battery contact side of the driver. Yes, if you do this then you will need to address thermal concerns also. The battery side also has programming pads, and some other bells and whistles I don’t recall presently.
Yes, but it’s 2 channels of 4. Not 2 channels of 2. At least that’s what it was supposed to be. You can see the picture of the board in the OP, or click the img in my last post (not sure why it isn’t showing).
Correct on that… things have been very rough as of lately for me with life issues, financial issues, stresses, & preparations to sell my house and sell off a lot of things to move to a different province, but i still will make time to work on this lantern project here with the team here to do what i can to make it a reality as much as i possibly can.
I think they should be able to get good parts. If not though, the effect would be a bit of change in brightness while changing tint:
With ideal parts, brightness should stay rock-steady while adjusting tint, like a flat board placed across two support beams.
With lower-quality parts, particularly with slower activation times, brightness would sag a bit at middle tints, like a cable strung between two telephone poles.
Given how visual perception of brightness works though, even the non-linear version would probably be a pretty subtle effect. And if it shows up in testing, perhaps the firmware could try to correct for it.
I'm finding the light manufacturers (Sofirn, Emisar, FireFlies, Amutorch) seem to be getting the good 7135's, but I can't seem to find them to buy stand alone. Usually it's the opposite case - go figure...
Id love a good source of 7135s. The ones recommended by Lexel from LCSC turned out to be the low quality ones, the raptor claw ones. For what ever reason Richard’s seem to be a good supply but aren’t bulk friendly. And they are out of stock (fast 350mA).
I can give my experience from my candle project. Having tried a few varieties the tint mixing firmware is more sensitive to poor 7135, as it stands now. with PWM values at the floor of 1 the poor 7135 do not turn the LEDs on. Setting the floor to say 5 and changing every other value below 5 would result in the light turning on at 5 then dimming and turning off before turning on again. The tint mixing is causing it to go somewhere below 5 even when it is running on one tint channel entirely.
