【convoy】17mm SST40 driver with biscotti firmware and temperature protection will be available
2120 posts / 0 new
adam7027
Last seen: 1 day 18 hours ago
For the OP reflector, if replacement of XM-L2 emitters is considered, I would like to recommend Samsung LH351D, because that is an emitter with larger light emitting surface, and while it does not have 95 CRI options, it still has 90 CRI options for almost all preferable CCTs (6000K as well!)
For throwier lights, LH351C and LH351B is smaller and cheaper (but also can be less powerful).
adam7027
Simon Mao wrote:
SKV89 wrote:
Simon, hope you did not order a large batch of the SST-20 FB4 tint bin. Once you get some Cree 5D tint emitters and compare it with the SST-20 FB4 tint bin, you will understand why the FB4 is not very good looking.
Dont worry ,friend,not everyone hates FB4,
and i will add FA1 or FA4 in my store ,i just supply one more choice for buyer
Personally, I would be fine with SST-20 (page 6) FA2 tint as well, as it is closer to the black body line, but still a little bit under it. Also, I would like to request a GD2 tint, as it could be a very nice mildly warm white – and a JD3 tint could be also interesting for people who seek very low blue light emission (even more eye friendly), but still high CRI.
zak.wilson
Last seen: 13 min 49 sec ago
Fireflies has been using FA2, and it still tests above the BBL. FA2 isn’t bad. Even FB4 isn’t bad, but to be reliably not green, it has to be FA1/FA4.
Ceilingbounce – flashlight testing and runtime graphs for Android
adam7027
Interesting, I have a clear ano S2+ flashlight with a 1750mA (5×7135) driver, and I use the ‘kaidomain FB4’ SST-20 emitter. I get visibly more rosy tint with it than with a Fireflies ROT-66 FA2 on even turbo setting.
I just hope, they didn’t receive FB2 instead of FA2 Smile
Probably for SST-20, the tint is very much dependent on the driving current, and as it goes higher, it turns more rosy.
Maybe then it would worth to get FA1 tint. I would still like GD2 and JD3 very much Smile
BlueSwordM
BlueSwordM's picture
Last seen: 23 min 4 sec ago
@zak, Fireflies has been using the FA3 chromacity tint bin.
SKV89
Last seen: 10 hours 58 min ago
adam7027 wrote:
SKV89 wrote:
Almost all the available Cree 5D tint are 70 CRI. I wish they had some 90 CRI version. The E21A 4000k and 219b 4000k 9080 looks similar to Cree 5D tint but with better color rendering and lower output. I suspect the SST20 FA1 tint bin will look about the same as Cree 5A or 5D tint.
Cree XP-L HI and XM-L2 5D tint should be available in 80 CRI as well, go and check the manufacturer documents Smile
Most of what is listed in the spec sheet are unfortunately unavailable for purchase in small quantities. There are very few Cree 5A 5D tint hi CRI emitters that can be bought by small consumers. I did buy a XHP70.2 5D 80CRI from Kaidomain and it has a nice rosy tint but such emitters are rare to come by.
Simon Mao
Simon Mao's picture
Last seen: 12 hours 43 min ago
Ryzbor wrote:
Why do you want to remove the knurling Simon? It’s beautiful as it it’s and the appearance of the S2+ has always been your trademark.
Using chrome material to process knurling, the defect rate is very high. If I don’t process knurling, I may reduce the cost by 1/3.
Simon Mao
Simon Mao's picture
SKV89 wrote:
Thumbs Up copper pill!
Please dont remove knurling. Its good for grip and adds surface area for heat dissipation.
removing knurling doesnt mean smooth surface , i will consider “grip” ,too
Simon Mao
Simon Mao's picture
P33 wrote:
Will it be offered in the clear ano version?
Yes, I can supply clear version
Simon Mao
Simon Mao's picture
zak.wilson wrote:
Thanks for offering the new emitter options. The S2+ was always a good budget light, but XM-L2s aren’t exactly pretty. I maintain a popular recommendation list and I was happy to be able to add the S2+/SST-20.
FA1/4 bins for the SST-20 would be most welcome. I’ve been using FB4 from Kaidomain, and the tint is OK, but could be improved. I can add to what others have said about the 219C as well: it’s fine at 2.8A. It’s fine much higher than that, actually and can take more current without failing than the SST-20 can. (7A is fatal to an SST-20.)
I’d really like to see an official listing for the C8+ with the SST-20 and 7135×8 driver. I know it’s possible to custom order it that way, but I want to add it to my list, and it’s much easier to provide a direct link than explain a custom ordering process.
Thanks ,buddy, i will add 7135*8 option for C8+ and S2+ nicha 219C flashlights soon Blushing
Ryzbor
Ryzbor's picture
Last seen: 2 hours 46 min ago
If you have problems making enough profit it would be a better idea to slightly rise the price of your products or stop implementing rising cost improvements such as new copper pills etc. in favour of maintaining the current build quality and knurling.
See your lights are popular because they offer very high quality for a decent price, not because they offer low quality for a low price.
virence.com rosy 3500K R9080 Wizard Pro, MF01 Mini 4000K R9080 (needs more 219B), super rosy 3000K E21A mix Skilhunt H04 on it's way
P33
Last seen: 6 days 17 hours ago
I personally would like to see project of S2+ with no knurling. There are various manufacturers that don’t use it (Zebralight, Armytek) and people are not complaining about low build quality or lack of grip on their products.
I’d much rather have copper pill than knurling if I could choose.
offline
Will a cool white luminus LED be available for this someday? Or would that be an SST-40?
Yokiamy
Yokiamy's picture
Last seen: 6 hours 35 min ago
OK, this is going to be a post which will probably heat up some discussion…
Copper is overrated, brass or aluminium wil do just fine
Especially for a S2+, it doesn’t matter much, since the flashlight is just to small to dissipate the heat very well, so it will gain maybe a couple of seconds in heat transfer.
The power of Convoy is that the quality of your products is always good and the design doesn’t change suddenly, (like what happens with other Chinese sellers, to reduce cost and get a higher profit rate) so all available spare parts always fit. (as is not always the fact with other Chinese sellers)
So, to reduce the price, please only remove knurling and keep using the existing pill, which is good enough.
Please get rid of the 3/5 mode driver and ONLY use biscotti
A smooth S2+, i can live with that.
  BLF
Ryzbor
Ryzbor's picture
Zebralight does use knurling on the SC600 handheld models, which are still way smaller then the S2+. Armytek doesn’t even know how to proper assemble their lights so adding knurling is probably too difficult. And objectively a plain tube without knurling will be more slippery in wet conditions then a knurled one, or when used with gloves.
SKV89
Yokiamy wrote:
Copper is overrated, brass or aluminium wil do just fine Especially for a S2+, it doesn’t matter much, since the flashlight is just to small to dissipate the heat very well, so it will gain maybe a couple of seconds in heat transfer.
Have you done any testing to compare it? Do you have data to back this up? I timed my copper host S2+ compared to aluminum regular and high mode can be maintained at least twice as long without burning. Output also drops slower when measuring lumens with copper pills compared with brass pills when using triples.
Simon Mao
Simon Mao's picture
yes ,i have SST40 LED in stock now ,but driver is not ready,yet
Simon Mao
Simon Mao's picture
I think I misrepresented what I meant.
First of all, I will not reduce the quality of the product. The current knurling is difficult to process, and one third of the products will be scrapped directly.
I don’t meant to make a smooth surface.
I just want to change a style, on the one hand, it will improve the product yield, on the other hand, keep the original feel of grip.
For example, I can change it to the following
offline
Thanks Simon, I’ll check back when driver is ready. Also the new rendition looks very nice!
kanton
Last seen: 1 week 2 days ago
Is the S2+ Nichia 219C in 5700K 95% CRI too? Or just the 4000K version?
BlueSwordM
No, the S2+ 219C is only in 90CRI.
Just the SST-20 is available in 95CRI.
lumiere
Last seen: 20 hours 16 min ago
!http://farm5.staticflickr.com/4874/39780644763_9754faf2bb_b.jpg!
Nice! I like it.
kanton
Whoops. But that’s also for the 5700K option? And is 90CRI still considered HighCRI? I want to get a glimpse into the HighCRI goodness so many people seem to enjoy – would this be a good specimen?
Simon Mao
Simon Mao's picture
219C 90CRI ,friend
Simon Mao
Simon Mao's picture
i have 1000pcs XML2 T6-5A1 and 1000pcs XML2 T6-5D4 in stock now
and anyone interested in XHP35 4000K and 5000K ? i got 2pcs samples
i will upload a video to show the original packing intact goods
@SKV89
SKV89
Looks good! I like it alot.
XXX-Man
XXX-Man's picture
Last seen: 1 hour 11 min ago
How about this kind of knurling?
Can it be done easy?
I really like this look.
"With the first link, the chain is forged. The first speech censured...the first thought forbidden...the first freedom denied – chains us all, irrevocably."
My reviews:
Sofirn SF36 /// Thorfire VG10S /// Sofirn C8F /// Zanflare F1
Simon Mao
Simon Mao's picture
In my opinion, I don’t like this style.
ZozzV6
ZozzV6's picture
Last seen: 27 min 50 sec ago
Thank you! Facepalm Big Smile
XXX-Man
XXX-Man's picture
Interested Smile
Ok Thumbs Up
My reviews:
