The present PWB has two 7135s hard wired to drive the two banks of lights. Up to 7 can be connected by applying a solder bridge to the pads on the battery contact side of the driver. Yes, if you do this then you will need to address thermal concerns also. The battery side also has programming pads, and some other bells and whistles I don’t recall presently.
If I want a second one, do I need to submit two entries? IF that is the case, please put me down for another (I am already #152)
Thanks, I am wicked excited to see it so close!!!
When did it change from two channels of four? I haven’t seen anything where it changed from 4 x 5000K and 4 x 3000k (maybe 2700K).
Edit:
Two channels only. I think the 4 Tom Tom was referring two was 4 LEDs. (Two LEDs of each color temp, 2 color temps, 4 LEDs)
Yes, but it’s 2 channels of 4. Not 2 channels of 2. At least that’s what it was supposed to be. You can see the picture of the board in the OP, or click the img in my last post (not sure why it isn’t showing).
It shows 2 channels of 4 LEDs, 8 in total.
I’m interested in one or two.
Update to the interest list:
1171 Moe_Suki
1172 Revlio
1173 Sento
1174 paosms
1175 chathamh
1176 Phaserburn
1177 The_crx
1178 woodyt
1179 dotBLF
1180 Bullmajor
I am interested in one, two if possible.
Definitely possible, you are on the interest list for two.
Welcome to BLF!!
Updated the OP list
Correct on that… things have been very rough as of lately for me with life issues, financial issues, stresses, & preparations to sell my house and sell off a lot of things to move to a different province, but i still will make time to work on this lantern project here with the team here to do what i can to make it a reality as much as i possibly can.
I worry about the quality of the 7135s. The tint mixing firmware really requires high quality parts compatible with all PWM values
Add me to the interested list.
Long time lurker, finally created an account to sign up for this one.
Added to the list, and welcome to BLF
Add me to the interested list, thanks!
1184 Ramius
Added to the list at 1184, and welcome to BLF Ramius!
I think they should be able to get good parts. If not though, the effect would be a bit of change in brightness while changing tint:
- With ideal parts, brightness should stay rock-steady while adjusting tint, like a flat board placed across two support beams.
- With lower-quality parts, particularly with slower activation times, brightness would sag a bit at middle tints, like a cable strung between two telephone poles.
Given how visual perception of brightness works though, even the non-linear version would probably be a pretty subtle effect. And if it shows up in testing, perhaps the firmware could try to correct for it.
I'm finding the light manufacturers (Sofirn, Emisar, FireFlies, Amutorch) seem to be getting the good 7135's, but I can't seem to find them to buy stand alone. Usually it's the opposite case - go figure...
Id love a good source of 7135s. The ones recommended by Lexel from LCSC turned out to be the low quality ones, the raptor claw ones. For what ever reason Richard’s seem to be a good supply but aren’t bulk friendly. And they are out of stock (fast 350mA).
I can give my experience from my candle project. Having tried a few varieties the tint mixing firmware is more sensitive to poor 7135, as it stands now. with PWM values at the floor of 1 the poor 7135 do not turn the LEDs on. Setting the floor to say 5 and changing every other value below 5 would result in the light turning on at 5 then dimming and turning off before turning on again. The tint mixing is causing it to go somewhere below 5 even when it is running on one tint channel entirely.
I am interested in 2 please.
I just saw this project mentioned in a post on r/flashlight today. I recently bought a q8 and have been searching for a lantern, this looks amazing!
