LuminTop EDC05 AA(14500) Flashlight
112 posts / 0 new
duvallite
Last seen: 4 months 3 days ago
liteupmynite wrote:
Lumintop wrote:
Hi, we regret to keep you guys waiting for long for this torch. Just got the news that the EDC05 problems have been solved, and it will be available on Amazon soon.
What is the expected availability on Amazon?
I just checked Amazon and they show it will be in stock on June 5th, for $30.99. Too pricey for me at that price, especially without knowing for sure if the driver problems are resolved or not. Buying cheaper elsewhere like GB or BG may get you leftover old stock that would be questionable.
toddcshoe
toddcshoe's picture
Last seen: 3 hours 40 min ago
I doubt it would be leftover old stock seeing as everyone was sold out of them. What is in stock now should be the properly working model. I got one. Works just fine.
"Everywhere I go, there I am"
duvallite
That’s why I said MAY get you old stock. Glad yours is working well, hopefully with 14500 batteries also. Sounds like you just got it, and if it’s been OOS everywhere, then it’s likely from the new batch that supposedly has the problems solved, if other stores are receiving them before Amazon does. I emailed Lumintop for some clarification regarding the driver issue and am waiting to hear back from from them.
vt2nv
Last seen: 2 years 1 month ago
Are there other things to consider?
Regulator IN/OUT differential loading for one thing. depending on the requirements for the LED whatever battery (14500 or AA) comes closest to giving the emitter what it wants, that would be the battery that the regulator would like the best. The lower the In/Out differential voltage, the more efficient power transfer from the battery through the regulator and on to the emitter.
Assume that an AA stores the same amount of the 14500. Wattage being wattage, the 14500, being more than twice the voltage of the AA, will provide a similar amount of power, but at less than half the current of the AA. Less current = less heat = greater efficiency.
I’m not disputing your data. What I am saying is that there are electronics in between the battery and emitter, the electronics are not 100% efficient, and those losses should be factored into battery life calculations.
Cheers
djozz wrote:
AA Cycler wrote:
Hugh Johnson wrote:
The stated runtime seems amazing.
The stated runtime seems amazing unrealistic. Let’s do some math Smile
  • Cree XP-L max efficacy = 161 lm/W
  • 400 lm for 1.2 hours = 400/161 W * 1.2h = 2.98 Wh
  • 200 lm for 2.2 hours = 200/161 W * 2.2h = 2.73 Wh
  • 60 lm for 11 hours = 60/161 W * 11h = 4.10 Wh
A brand new Eneloop Pro stores 3.0 Wh.
Conclusion
  • the 400lm runtime is possible only with 100% efficient LED driver – this is unrealistic
  • the 200lm runtime, if it was true, would be really amazing
  • the 60lm runtime is simply impossible with nowadays AA cells
I am going to put this flashlight on my aaflashlights.com todo list…
Nice and useful website! Thumbs Up
interval
Last seen: 1 year 4 months ago
Hello, I was looking at this flashlight for edc, since there are no ut01 safe 100%
  Are there still defective units in edc05 stock?
those of BG and GB are those with problems solved?
fluke
Last seen: 1 day 4 hours ago
Anyone aware of a diffuser for this ?
d_t_a
Last seen: 9 hours 21 min ago
The picture for the EDC05 in the original post appears to show it uses an XPL-Hi LED.
However, I just ordered an EDC05 and it comes with XPL-HD LED.
Are there different variations of the EDC05?
Also, is there some way of checking that the EDC05 uses the new/fixed driver that won’t develop the “break contact to turn on issue” that plagues the UTorch UT01?
Lumintop
Lumintop's picture
Hello, the present EDC05 are all utilizes XPL HD LED, and those are all using the new fixed driver.
LUMINTOP – Reliable! Playable!
264
264's picture
Last seen: 7 months 2 weeks ago
I will be receiving an Edc05 from Banggood in the next 5 or 6 days. Planning to post a image of the led. I have two NW copies with the original XPL-HI emitters.
264
264's picture
DSCF3925P_20190112_184916_LLReceived the new flashlight today. The tint is much cooler than the HI emitter. I have not had any issues with the original version of this light.
Threadneedle
Threadneedle's picture
This would be good to know, if anyone has an answer to it.
264
264's picture
P_20190112_232628_LL Found a hat of sorts.
264
264's picture
The diffuser that came with my Wuben E05.
g_damian
g_damian's picture
Last seen: 6 hours 47 min ago
Does updated version have glued bezel/driver?
Venom
Venom's picture
Last seen: 1 year 1 month ago
I bought a EDC05 and it had a nasty greenish tint to the beam. Did anyone else notice a greenish tint?
264
264's picture
Mine has a slight green tint.
264
264's picture
My new Edc05 unscrews into three pieces just like my old ones.
g_damian
g_damian's picture
What three pieces? Head, battery tube, tail?
Is it easy to swap emitter or is there some kind of thread locker?
264
264's picture
It unscrews into head, battery tube, tail. Sorry but I have no idea how to take the head apart.
g_damian
g_damian's picture
Thank you Smile
Venom
Venom's picture
Thanks for the reply!
