Fireflies ROT66 Flashlight
My ROT66 219B is unfortunately already a month in transit.
But Jack did add a spare lens, swapped the driver for a 13*7135 one and turned the aux leds off with a screwdriver all for free which is nice.
Which batteries are the most suitable to power it? I’d rather not fry the leds by too high current. Are the VTC6 safe or is the NCRGA better?
Both are safe. The VTC6 should give higher measured lumens than the Panny GA 3500, if that’s what you want.
All packages from China have a good chance of delay from Nov-Feb due to high sale volumes and holidays.
It bothers me too, and I’ve advised against having any LEDs which can’t be turned off, but … that’s how it was made.
They’re hard-wired to power. To turn them off, unsolder the wires and optionally connect them to a different part of the driver.
I suppose you could remove the switch boot and then insert a circle of black paper into the top of the boot. the Switch may still light, but the paper should block the light so the button won’t light up.
Not good news. I did not know that blue leds are always ON. This is incredible. Realy bad decision from FF. :frowning: :cry:
I do not use flashligh everyday. Do you maybe know how much power consume these leds?
Now I will have to unwind tailcap each time I will stop using this FL. Crazy, such a nice FL with big problem (in my opinion).
Kind regards
I believe toykeeper did the math before on the aux leds, and said it would take more than a year or two to drain the batteries.
She got the parasitic drain down pretty low, and just having the 2 of 4 switch LED's on doesn't take much juice. No surprise, but someone could actually measure the drain and post, if not done so already. I'd guess the results would be a year or two. Of course a higher capacity cell would be the best.
EDIT: For a PL47, just measured 0.08 mA (Fluke 175 model measures to 1/100th's of mA), which is 80 uA. So for a 4000 mAh cell, 4000/0.08 = 50000, which is in hours, 2083 days, 5.7 years. Not sure how accurate this is, it's not my usual meter, but it could be in the ballpark. If the drain is the same on a ROT66, triple that to 17 years for 3 4000 mAh cells.
If you want to do some sanity test of your own, let it sit for 10 days or so and measure the cell before/after. Swap cells if you are gonna use it.
Are we talking about the 4 switch leds only or also the 12 main auxiliary leds in the front? I would imagine 16 leds total would be a pretty good drain.
Of course they also act like a battery indicator and can also shut themselves off if the battery voltage gets too low. Still, it seems like a twist for mechanical lockout is a good idea. I always mechanically lock out my lights when I’m not using them for more than a couple hours.
Oooops! On a PL47, 7 clicks, followed by 7 clicks turns off 2 of the 4 switch LED's and all the front AUX LED's - think the ROT66 works the same? My ROT66 was before the added AUX LED's.
Updated prior post for a PL47...
My ROT66 with AUX LED’s, cant switch off the AUX LED on the emitters.
Only difference 7-clicks does, is switch between two or four switch LED’s ON
I think it’s because of the low voltage warning the main auxiliary leds can give that they are wired up directly to the battery. The side switch lights are wired to the mcu which has regulated voltage (regulated on the 2S and 4S drivers, I’m not sure about the 3v drivers).
If you don’t mind losing the low voltage warning, I believe you can wire the aux led board to the side switch lights in parallel. Then the 7 clicks will control them both. I think 2 of the 4 side switch lights are still wired direct. Those can be disconnected or wired in to the others.
Just for the hell of it, I just measured my PL47 and some others. And hit exactly the same current. on the PL47 :smiley: :beer:
PL47:
AUX ON: 0.566mA (4 switch leds on)
AUX OFF: 0.08mA (2 switch leds on)
ROT66:
AUX LOW: 0.28mA
AUX HI: 0.575mA
D4S:
AUX OFF: 0.04mA
AUX LOW: 0.085mA
AUX HI: 1,24mA
So for each of these 3 lights, 3 different AUX LED options, and on the ROT66, can't turn them off at the head? Oh boy...
You can always turn them off with a twist. Mechanical style. All e-switch lights have some amount of parasitic drain. The Thorfire S70S has a crazy high 4,430 micro amp drain and it only has a single green led switch light. Compare that to the Q8 at 123 microamps. So it’s best to always cut the power.
I don’t think the MCU is regulated.
Here’s a previous comment by Toykeeper about making it so you can shut off the aux LED board and all 4 button LED’s:
One possible option for turning off aux LED’s is a component called a bistable or latching reed switch. Some of those I’m finding spec sheets for are very small - about the size of a 1/4W resistor - but I’m not sure where to buy them.
It might be possible to wire one in series with the aux LED board, and if it can be located close to the lens, trigger it with a neodymium magnet.
Normal reed switches are momentary. Latching reed switches switch on or off depending on the direction of the magnetic field.
On Fireflies lights so far, the buttons have 4 LEDs:
  • 2 LEDs: always on, hardwired to power
  • 2 LEDs: wired to a MCU pin so the MCU can turn them on and off
… and the aux LED boards have more variety:
  • Always on, hardwired to power
  • Wired to a MCU pin so the MCU can turn them on and off
  • Wired to power and a MCU pin, so the MCU can tell it to turn on and off but it still gets power direct from the battery
The 2 controllable button LEDs could have low and high modes, but this option isn’t compiled into the firmware because Fireflies didn’t want it. It doesn’t really make much sense when the other 2 are always on.
The aux LED boards typically have potentiometers to manually adjust the brightness, and the adjustment range tends to go from ~200 uA to ~800 uA. However, the pots are physically inaccessible on some lights, like the PL47.
The aux LED boards also typically have their own built-in LVP:
  • Above ~3.3V: outer rings are lit up
  • ~3.0V to ~3.3V: inner ring it up
  • Below ~3.0V: aux LEDs off
Because of the way this LVP function is implemented, and the way it attempts to regulate aux LED brightness, the aux LED boards cannot do low and high modes controlled by the MCU.
There is no LVP on the 2 hardwired button LEDs. Also, there is not yet any LVP in Anduril while it’s asleep, so if voltage drops too far during standby it won’t respond until after the user wakes it up. But the aux LED board LVP is always active, which helps a lot since it draws about 98% of the power during standby.
I must say that I’m very disappointed with ROT66. If I bought it in local store, I will return it.
The problem is that returning FL to China is too expensive. So I’m stuck with this FL.
Can you calculate, measure how much power do all blue leds and swich leds consume together?
Thank you
Kind regarads
It can be measured with a common DMM / multimeter.
However, that may not be necessary because measurements have already been posted. It should have a standby time of 1.5 years to 9 years with the aux LEDs on all the time, depending on how you configure them. It can also be turned off entirely by using physical lock-out.
Why does this change your evaluation from “I love it” to “I’m very disappointed and want to return it”? It seems like a large reaction to a small problem.
I still love it but after I found out that small leds can not be turned OFF, I’m not so happy anymore.
This is my frist FL which has leds always ON and I don’t like this feature.
What is physical lock-out?
Can you please explain?
I now unwind tailcap to turn it OFF.
Thank you
Kind regards
