I didn’t change anything else. Well, except for thermal paste. Seems mine had very little to no thermal paste… the copper MCPCB came out dry and untouched by anything. Not so anymore.
When I receive my units, I’ll be able to test that. I am expecting an E07 Nichia 219B, an E07 XPL Hi 4000K, a 40T and a 50E. I will only have my phone to measure the output though.
Did anyone measure the output of the SST-20 6500K option?
Manufacturer rating of 4500 Lumens seem kinda low when the the XPL-Hi 6500 is rated (and can do) 6900. That would be ~35% less output.
In comparison: Emisar rates the D4s with XPL-Hi 6500K with 4300 lumens, the SST-20 6500K with 4200 lumens. That’s only ~2.3% less output.
Wait what? Where did you buy those emitters and did you measure the trow compared to the sst-20 as well at turbo? Does the higher output make up for a less focussed beam?
The SST-20’s are small dies, which is why they tend to be more throwy in an optic than a larger die. The LH351D has a larger die surface, so yes of course it has a larger hot spot. Totally unrealistic to expect a 10mm TIR to actually produce throw. 7 of them don’t tighten a beam, but make it even larger.
As an aside, did you know that the DQG Tiny 7 emitter 26650 light uses an optic that seems to match this one’s? But the DQG uses a 3 legged pattern instead of 4, so the holes in the pcb don’t line up. Or, not that I can tell from the outside, will remove the stock one and see if the DQG one fits in the E07…
Edit: The DQG optic doesn’t fit. The TIR’s match but the legs are not on the same circumference layout… they ALMOST fit 2 optic holes and one screw hole but not quite.
LOL, it’s not THAT much broader a beam profile. To me it’s well worth the beam growing larger for the better more uniform color. And, well, extra lumens don’t hurt either.
Thanks for the recommendation. Samsung 40T it is. Now … where is the best source for genuine Samsung 40T’s. I would prefer to purchase a few without the cheese filling …
Li-ion Wholesale is reputable, as is IMRBatteries. The prices vary between them but they both have sales quite often. (IMR has the 40T for $9.99 at the moment, they’re in Houston so not locked in with weather)
You may even check at illumn.com, they’re over there with you on the West Coast… don’t know if they have that cell though.
