ANDURIL USER MANUAL & LIST OF LIGHTS
203 posts / 0 new
noboneshotdog
Last seen: 7 hours 47 min ago
This is a great resource for step by step instructions on how to program your Anduril flashlight.
ANDURIL USER MANUAL
https://bazaar.launchpad.net/~toykeeper/flashlight-firmware/fsm/view/hea...
ANDURIL LIGHTS
http://budgetlightforum.com/node/67518
Thier ain’t no bones in a hot dog. F. York
Edited by: noboneshotdog on 11/30/2019 - 15:25
ToyKeeper
ToyKeeper's picture
Last seen: 3 min 20 sec ago
… okay.
It might be a good idea to include the UI diagram too.
Bob_McBob
Last seen: 4 hours 24 min ago
noboneshotdog
The lights that currently use this UI are:
Fireflies ROT66
Fireflies PL47
Fireflies E07
ToyKeeper
ToyKeeper's picture
I don’t think I’d call it the Fireflies UI. It was created before Fireflies was, and supports several different lights:
  • BLF/Lumintop GT
  • BLF/Lumintop GT-Mini
  • BLF/Thorfire/Sofirn Q8
  • BLF/Sofirn LT1 Lantern
  • BLF/TLF/Lumintop FW3A
  • Emisar D4
  • Emisar D1
  • Emisar D1S
  • Emisar D4S
  • Emisar D18
  • Fireflies PL47 (and E07)
  • Fireflies ROT66
  • Fireflies E01
  • Mateminco/Astrolux MF01S
  • Sofirn SP36
… and there are more being added over time. Look at the cfg-*.h files to get an up-to-date list at any time.
The FF E07 isn’t actually a supported build target, but the PL47 version is used on the E07. Its thermal behavior would probably be a bit better if there was an E07 version though, calibrated for the E07’s larger thermal mass.
Note: Not all of these lights ship with Anduril. Being supported doesn’t mean being configured that way by the manufacturer.
TexasToasted
TexasToasted's picture
Last seen: 1 week 1 day ago
In Anduril, how do I disable all strobe/blinkie modes?
ToyKeeper
ToyKeeper's picture
To avoid the strobe and blinky modes, don’t click 3 times from off.
Lexel
Lexel's picture
Last seen: 4 weeks 1 day ago
Could you upgrade the UI picture with Aux LED support?
ToyKeeper
ToyKeeper's picture
Eventually.
hank
hank's picture
Last seen: 2 hours 18 min ago
It’s time for the manufacturers to start providing little sticky “Anduril Inside” labels on lights — and suchlike for other software.
Like the old familiar ones from the CPU/operating system war days
For those of us not up to programming our flashlights.
Or maybe the light could blink out the name of its operating system in Morse Code …
ZozzV6
ZozzV6's picture
Last seen: 18 hours 5 min ago
If somebody like a visual form better:
lawallac
lawallac's picture
Last seen: 1 day 12 hours ago
On my newest DS4 sst20 3000k version, I do not detect a difference between ceiling of the ramping and 2xclick turbo. Is this due to maxing out the led or it it a setting or electrical issue? I’ve tested IMRs that work perfectly in the xpl hi version. I’ve also tested it on the lux meter which showed possibly marginally lower output.
ZozzV6
ZozzV6's picture
If you have stock D4S it doesn’t have Andúril firmware.
ToyKeeper
ToyKeeper's picture
hank wrote:
It’s time for the manufacturers to start providing little sticky “Anduril Inside” labels on lights …
Meh. I’d rather they didn’t. Freeme does that sometimes in promotional materials, and it’s cringey. I don’t like marketing, and don’t like being treated as a brand instead of a person.
It’s quite possible that the ceiling-to-turbo transition could jump from one side of the hill to the other. The emitter’s output curve (lumen output according to amperage) has a peak, and going past that peak is unhealthy for the emitter. After the peak is reached, increasing the power actually decreases the lumens while dramatically increasing the heat. So if turbo makes the lumens go down, don’t use turbo. It could easily be shortening the life span of the emitters.
However, RampingIOS V3 is literally a copy of Anduril with some things removed and rearranged. The basic ramping functions are identical.
lawallac
lawallac's picture
So ramp ceiling was visually the same as turbo so I changed to the stepped ramping. Now there is a pretty big difference between top step and the turbo. It was almost like the ramp was going all the way up to turbo. But I think you may be correct and turbo was jumping the current just over the curve. I think for this one I will keep it this way since it appears to adhere to expected operation. It’s nice to have options, thanks TK. Is the top step usually less output than the factory setting for the ramping ceiling?
shinysideup
Last seen: 4 months 11 hours ago
I’m observing identical behaviour with my, just delivered, Emisar D18 with brand new button top VTC6 cells. In the default smooth ramped mode, there was no difference between the top of the ramp and turbo, while there is a noticeable difference in stepped mode. I prefer my ramp to go from moonlight to turbo, anyway, so I since configured it that way; but is there a chance these are coming delivered with the top of the smooth ramp being set to 150/150? Not a big deal. Just curious as I like to understand my lights’ configs as much as possible! Anduril is amazing, BTW!
ToyKeeper
ToyKeeper's picture
The default config for D18 is:
  • 1×7135 highest level: 50
  • Nx7135 highest level: 100 (highest regulated level)
  • Smooth ramp: 1 to 100
  • Stepped ramp: 25 to 100 in 7 steps
  • Thermal hard-drop level: 125
  • Turbo: 150
So if it arrived with the ceiling set to turbo, the config has been changed. Maybe someone at the factory tested it.
shinysideup
Thanks TK!
Nev
Last seen: 1 year 1 day ago
That’s how my D18 is ,I actually prefer smooth ramp to ramp to turbo.
ToyKeeper
ToyKeeper's picture
If you want the light to ramp all the way from the lowest level to full power, it’s fairly easy to set up…
  1. Turn the light on.
  2. Click 4 times.
  3. At the first prompt, click 1 time.
  4. At the second prompt, click 1 time.
Done!
Configuring it for a lower level takes longer. Like, to set the ceiling to level 100 of 150, it’s the same process… but the second prompt needs 51 clicks instead of just 1.
Nev
  2. Click 4 times.
Done!
Thanks TK , I will have a go ,i like the step ramp to go to ceiling then double click for turbo but I like to to ramp to turbo on smooth ramp , that’s how my d18 came , I would do it to the FW aswell.
Will it alter the step ramp as Well?
ToyKeeper
ToyKeeper's picture
No. It only changes the ramp you were using before entering config mode.
Nev
Good , thankyou Thumbs Up
jon_slider
jon_slider's picture
Last seen: 5 hours 49 min ago
thanks for all the info
is there a way to reset a D4 with Anduril to factory defaults?
I borrowed one and changed a lot of settings, and am getting ready to return it
fwiw, here are some pics and impressions:
http://budgetlightforum.com/node/67288
blueb8llz
Last seen: 11 hours 57 min ago
Does the fireflies e01 have a new version Andúril? Why am not able to program the maximum brightness as top of ramp? I tried 4 clicks with no response.
noboneshotdog
I’m pretty sure that while the flash light is on and in ramping mode you click four times then you will notice the light flutter and you push the button once and it allows you to access the lowest usable mode. Then it will flutter again and you push the button once and that allows you to access the highest usable mode.
blueb8llz
Not on the fireflies e01. I have two of these lights and they both don’t flutter after 4 clicks.
I’m able to program my e07 though.
noboneshotdog
blueb8llz wrote:
Not on the fireflies e01. I have two of these lights and they both don’t flutter after 4 clicks. I’m able to program my e07 though.
Gotcha. Sorry, I figured they were the same.
ToyKeeper
ToyKeeper's picture
Fireflies asked me to make a new UI for the E01. It’s basically a stripped-down version of Anduril. The ramps are not configurable, and most of the blinky modes are gone. It has a police strobe and SOS instead of the Anduril strobes.
Tom_182
Last seen: 1 day 14 min ago
I have a problem with anduril. I set the ramp floor higher in the ramp cfg and want to set it down as low as possible again. How can I set it down? The diagram only shows how to set it higher.
ToyKeeper
ToyKeeper's picture
  2. Click 4 times to start ramp config mode.
  3. At the first “buzz”, click 1 time.
  4. Wait until the config mode exits.
That’s all. That should set the floor to the lowest level.
