Yours looks way more centered than mine. I used the older 18650 host and did 3x SST-20 4K sliced dome. I would probably leave dome on if I did it over again but I was re-using LEDs from another build.
@Contractcr, centering rings did all the work, ALTHOUGH I did have to slightly widen the MCPCB-to-Reflector screw hole slightly (~0.4mm) because it was not aligned with reflector (thanks to DJozz for first pointing this out)
Hopefully Sofirn can correct this problem and/or improve QC.
Don’t know if this helps with what you need to see but here ’ya go. Both about 4-feet from an off-white wall.
I don’t have a reflectored triple XP-L Hi for comparison (I do have TIR triple but that’s too floody), so I grabbed a single reflector XHP35 HD for comparison.
Haikelite SC26 w/XHP35 HD warm/neutral for comparison (on Left), Sofirn C8F w/SST20 4000K (on Right);
FWIW, at longer distances my C8F config continues to appear even tighter (~30%) than my SC26.
EDITED - added a short distance beamshot
Both about 40-ft from a white fence
Furthermore, there is already a light such as thrunite Catapult V6 like that, how could Sofirn makes it better?
Note:
If you guys want tell new ideas for Sofirn light, please just PM me, but contact aliexpress sales only for order related topics. Simple and clear communication helps us making acurate plan.[/quote]
Easy. Make turbo in the mode sequence and so that turbo can be memorized.
In Modes, the difference between memorized and non memorized turbo is practically nothing. Single click for memorized or double click for non memorized. The extra click bothers you?
What he is trying to say: “If you put a CSLPM1.TG in a host the size of a Catapult V6, it will throw much farther with only a small drop in lumen output.
Late to the game on this, but was there a reason for the dual switch? I’d be interested in a single side e-switch C8F (21700 triple) ideally with Anduril Having the single switch would enable it be slightly shorter too. Does something like this already exist?
I don’t know anything about the XHP, but SST20 4000K 95CRI would be nice, especially if tint was below BBL.
It works with the unique UI. You can operate the light as if it were a single e-switch only, or you can use the rear switch to turn the light off which would then allow you to turn the light back on at the previously-used level using the forward clicky switch in a tactical way. For instance, flashing Morse code, etc.
I'd like to see a C8F 21700 (triple) come with an SS bezel and no tail switch, so the overall length is reduced, as hodor mentioned. All my C8F's are getting an SS bezel anyway, and the tail switch with either a NarsilM or Anduril driver is not relevant, and part of the advantage of having good e-switch firmware is to remove that switch. Maybe Sofirn can make a replacement endcap with no switch available?
I got a build of Anduril working with the tail switch by un-commenting this bit of relevant code:
// dual-switch support (second switch is a tail clicky) #define START_AT_MEMORIZED_LEVEL
In addition I had to use the following fuse value (turning BOD on?) to make it work correctly:
-U hfuse:w:0xde:m
Now, when I use the tail switch it turns on in the last memorized brightness. Basically, it acts like a normal forward switch but it cannot change modes or anything. It just comes on in the last memorized level it was turned off in.
Yes, it does bother me enough for me to pass on many lights when turbo cannot be memorized or just not in the mode sequence. Just doesn’t make sense to me. I only see it as a safety precaution. But we re all responsible enough so why make it more work for the user? Some companies are now even doing double click for turbo, and then another double click for brighter turbo?! That’s way too much work to get to the brightest mode.
I still like the double click to turbo at any time. But just make turbo memorized or in sequence. What’s the big deal with them. Some family members and friends don’t know about double clicking and just know to ramp up or change modes. So high mode will basically be the brightest mode for them, unless you instruct them.
As long as you can memorize turbo in ramping, then that’s fine with me.
I’ve seen those lights that make you dbl click for Turbo and then you have to pause, then dbl click again for Turbo S. Ah, such crap!
The Olight X7 and X7R has that.
With NarsilM v1.2 or v1.3 you can change the code (and then flash the mcu) to make the top of the ramp be less than 100. In this case it’s no big deal to me, you can do a dbl click instead of a single click to get 100 Turbo.
If you know how to reflash mcu’s or buy a driver from Texas_Ace or Lexel, then you can set the top of ramp to whatever you want.
All of my custom built NarsilM drivers use v1.0 or older so they ramp to 100%.
I’ve got the BLF GT, GT Mini and Astrolux S43S that ramp up to less than 100. I don’t use any of those lights very much so them not ramping to 100 doesn’t bother me.
The lights I use all the time I tend to set them at a mid level memorized setting and dbl click to turbo for short bursts.
The only time a see a problem is if you have let’s say a 3,000 lumen light and you want to set it at 2,500 lumen, but can’t because the top of the ramp only goes to 1,800. That might annoy me, but I can’t think of a reason I’d set it that little bit below Turbo. 2500 to 3000 is not a very noticable difference. Maybe if the top of ramp was 1000 lumen and I wanted to run it at 1500 lumen, then I might get upset.
This may not be perfect, but it’s still way better than non ramping UI where you have to cross your fingers that one of the brightness levels matches your needs.
The UI Anduril has the advantage of having a user setable top of ramp. That’s the best of both worlds. You can memorize Turbo and access it with a single click.
