>> Homemade Gxb172 led driver (complete!)
46 posts / 0 new
clientequator
clientequator's picture
Last seen: 1 week 2 days ago
I decided to try to make myself the loneoceans gxb172 led driver. This was inspired by success of schizobovine and moderator007 when they try to build the gxb172 driver also, on this forum page http://budgetlightforum.com/node/59137?page=5. I am making a new thread because I think there will be challenges to build this driver and want to share my sucess or failure.
First step I use the files on loneoceans website and order my own oshpark PCB.
Next I order the component online. They arrived and I begin assembly. Some components are very small. I decided to solder the top side first where the MP3431 chip is. I use sharp pin to apply thin amount of solder paste to each pad under USB microsope which is essential. This took a lot of time.
Then I carefully place each component on the pad, after dipping each component pad with flux pen. The temperature IC is the most difficult to place and I did not add extra solder since they have solder ball on the bottom of the chip. The big inductor is also difficult to place with out knocking other chips aside. But thin tweezer and paitence help me.
I order wrong component for the 1206-size capacitor, so I will solder it next time.
Finally I use a hot air set on 300C and low strength and manager to reflow all the parts! I use spray flux cleaner to clean the flux after completed.
I use USB microscope to inspect the temperature IC to see if solder ball flow:
This is top side of pcb almost complete.
I recommend useing the website image to place component because some silkscreen is missing due to the text sitting on top of via.
Next step to get capacitor 1206 to solder on, and solder bottom side.
Edited by: clientequator on 02/14/2019 - 12:07
LouieAtienza
Nice job so far!
DavidEF
DavidEF's picture
Last seen: 1 hour 32 min ago
Thanks for chronicling your journey here. Those 402 parts are super small. I don’t envy you having to place small parts, but I wish I could get a few of those drivers WITHOUT having to do it myself! Shocked
- The YKK Philosophy
clientequator
actually the 0402 parts are easy to place, and quite easy to hand solder using thin tweezer and thin solder wire. The most difficult so far was the boost IC with long pad below, and the small temperature sensor with bga.
size compare: the 0402 is 1mm x 0.5mm size. the temp IC is 0.76mm square. it is easy to breathe it in!
DavidEF
DavidEF's picture
Shocked Shocked Shocked
Lightbringer
Lightbringer's picture
Last seen: 5 hours 5 min ago
Hmmm. At least you’d know whether/not you’re running a fever, then.
moderator007
moderator007's picture
Last seen: 3 hours 33 min ago
The only thing that was difficult for me was the temp sensor, the pads are really tiny. The small parts are tedious but reflowed well with the hot air station.
Now if I could just get the 841 programmed I be in business. The USBASP programmer most of us use isn’t wanting to cooperate. I would really like to find away for this to be programmed without having to buy a more expensive programmer to keep the cost down for anyone who ventures after us.
Wishing you luck clientequator, looks good so far. Thumbs Up
Barkuti
Barkuti's picture
Last seen: 22 min 10 sec ago
Wow! Looks like a chunky box of coiled copper up there.
Given the bill of materials, cost of the board and amount of man hours this totally looks like an inexpensive project. Joking, of course. Wink
Cheers Party
Fri, 01/11/2019 - 07:52
Smile
clientequator
Give the bill of materials, cost of the board and amount of man hours this totally looks like an inexpensive project. Joking, of course. Wink
Cheers Party
Mr. Barkuti, yes this project is expensive for driver, but it is interesting project and challenge to put together for hobby maker, so I hope the result is working!
You are correct this inductor is one of the most interesting I have used before. It seem quite big and cube shape, but only because 17mm PCB is very small! Even though it is only 7mm square small, on datasheet it is actually 19.6A saturation current, which is amazing!
https://www.coilcraft.com/xal7070.cfm
Soldering this took a while but I recommend just some careful waiting with hot air, and allowing it to cool down before touching it because it remain hot for long period of time and solder will still be wet.
CRX
CRX's picture
Last seen: 9 min 8 sec ago
Cool Thumbs Up
clientequator
Today I solder up the bottom of the pcb.
I have to say it was much easier to do compare with the other side! The most difficult chip to solder is the atmel 841 microchip, but I use the same method of solder paste with pin and hot air and a flux pen and eveyrthing work very well.
The rest of the component are at most 0402 and easy to solder with thin solder wire and USB microscope.
loneoceans suggest the opa333 opamp is temperature sensitive, so I solder that last with soldering iron set on low heat.
The pcb is now complete, minus the 1206 capacitor which is on order, and to program the 841 chip. I was able to email loneoceans and he provided link to make the pogoprog on OSHPARK!
https://oshpark.com/shared_projects/OGnP2C5u
for the component:
Pins - P13-0123 or P50-B1 x 6
Switches - CAS-220TB
Regulator - AP2114H-3.3TRG1
USB - 1050170001
F1 - 0ZCK0100FF2E
C1, C2 - 4.7u 0805
D1 - 0805 LED
R1 - 1k 0805
Header - 2x3 100mil
I will make one and use atmel ICE to program the 841 controller. The pogoprog has external power using USB, so I will use 3.3V on vcc line to program the 841 chip.
Slayer1
Slayer1's picture
Last seen: 5 hours 40 min ago
Nice, thanks. Thumbs Up
staticx57
Last seen: 1 hour 42 sec ago
That temperature ic would give me nightmare. Good job!
moderator007
Nice job clientequator Thumbs Up .
I’m still working on getting the 841 programmed with a usbasp programmer. No luck yet Facepalm .
clientequator
I got the 1206 capacitors. Now the gxb172 driver is complete. Next step is to solder on spring and wire to the driver, and program the attiny chip with pogoprog programmer.
For the flashlight, I will use convoy s2+ host and plan to use xhp50.2 led.
clientequator
Today I focus on led.
After reading this forum and thinking, I decide to use brightess possible led, so I decide on XHP50.2 maximum bin led. This is J4 led with 1239 lumen at 1400mA 6V.
For heatsink, I use notigon copper pcb in 16mm size to fit a convoy s2+ flashlight.
To solder, I use datasheet recommended heat with hot air and solder paste (lead). I keep pcb hot at 200C for long time, then turn heat to 240C until solder melt, and place led on solder.
The result looks good to me.
This is my progress so far. XHP50 not as big or bright as schizobovine XHP70 led, but I think will fit Convoy flashlight easier.
I borrow ATMEL ICE from friend and will use Atmel Studio to program 841 and to set correct fuses next.
clientequator
moderator007 wrote:
Nice job clientequator Thumbs Up . I’m still working on getting the 841 programmed with a usbasp programmer. No luck yet Facepalm .
Mr. moderator007, you say you program this with usbasp in the end – was your pinout drawing of the programming pad correct in the end on the gxb172?
Thank you!
moderator007
Thank you!
It is correct, all the pads are directly connected to 841 also. No components in series that would cause any interference.
Checked on a unpopulated pcb with a DMM.
clientequator
moderator007 wrote:
Nice job clientequator Thumbs Up . I'm still working on getting the 841 programmed with a usbasp programmer. No luck yet Facepalm .
Mr. moderator007, you say you program this with usbasp in the end - was your pinout drawing of the programming pad correct in the end on the gxb172? Thank you!
It is correct, all the pads are directly connected to 841 also. No components in series that would cause any interference. Checked on a unpopulated pcb with a DMM.
Thank you. I have another question. Do you recommend what sort of spring you use for gxb172? I am not sure to use metal button like schizobovine or upside down spring like loneoceans.
Today I make some progress. Silicone wire arrive and I use it to solder to driver.
Like schizobovine say, I test it in Convy S2 brass case and some part almost touching, so I use loneoceans idea and solder copper wire around driver like this.
This is a little tricky and I had to use hot soldering iron and some clip to hold it in place, and add flux.
Finally, my advice to others - I recommend using thinner wire. My wire almost as thick as pcb thick, so it is almost too thick for retaining screw to hold the pcb (just able to fit!!!). I recomennd use thinner wire maybe half thickness. As long as it can clear height of 0402 capacitor, then there is no problem.
I did not solder whole ring in case I decide to remove and use in other flashlight, so I only solder about half ring.
Tally-ho
Tally-ho's picture
Last seen: 13 min 13 sec ago
Great work and great pictures. Thumbs Up
moderator007
I used a heavy guage copper grounding wire, cut a small section out and filed it down flat on both sides, checking with calipers to make sure it was true.
This copper wire is pretty flexible and its used to run from your house inside panel box to the ground rod outside your house that’s drove in the ground.
I had a piece laying around but I think lowes carries this and is probably sold by the foot. It worked perfect with a little elbow grease. Wink
I used the hot air and solder reflow paste to attach it. Beer
DavidEF
DavidEF's picture
. #4 AWG Bare copper wire in the USA. And yes, Lowe’s and The Home Depot have plenty of it. Wink
moderator007
Thanks for the info, now people have a solution for making positive copper studs. Thumbs Up
I could have turned one down on a my lathe but my copper stock is 1”. Would have been a lot of expensive copper waste just to get to about 1/4” stud and time also. This solution was pretty simple and quicker.
clientequator
Mr. Moderator007, thank you, I will look for similar copper piece to use, it is good suggestion! Today is good, I receive pcb for pogoprog and solder it quickly.
I notice this progprog has useful USB power input for program ATMEL IC with no need to add extra power because USB supply voltage to VCC pin at 5V or 3.3V! This project getting expensive but hope to make it working.
To solder pogoprog, at beginning I believe very difficult to solder pins, but actually it very easy and the pin reflow in place the moment I touch it with hot soldering iron! Next, I use ATMEL ICE to program the Attiny841.
Advise - I use 0.8mm pcb thickness from oshpark.com, to make sure the pin fits.
Here is image from moderator007 for pinout, which match the pogoprog:
moderator007
Glad your still making progress clientequator Thumbs Up .
I have also ordered the pogoprog and 3 more boards. I’m not going to populate the boards just using them to connect to the USBASP to the pins for easy programming. Way better than having to solder on 6 tiny wires ever time I want to program one.
Expensive yeah, but mtn’s boost driver is $25 plus shipping. I figure I got some where around 30 to 40 per board in just the parts. I hadn’t reached a exact figure yet. But this has been a fun learning project. To be honest I wasn’t sure I could do this, but I gave it a shot and I hit a few road blocks along the way but I found a way.
I hope this inspires others to try this, it’s not as difficult as it seems. Time consuming but fun and interesting. Smile
To me the key to building these boards is having a hot air station. The second board I built, the only thing I soldered on was the led wires and the programming wires to the pads, ever thing else was reflowed with hot air. Beer
BlueSwordM
BlueSwordM's picture
Last seen: 2 hours 29 min ago
Maybe you could sell one?
What’s your price? 20-25$USD+shipping?
The main problem is that the boost driver in itself is quite thick, and you can’t just ship it in a reinforced envelope under 2cm because of this.
Maybe ship a light with it?
I know a lot of people would be loving to have 2000 lumens of awesome Nichia 144AM 4500k 90CRI light.
clientequator
Good progress today on driver!
I had some problem when I notice small short on one component, so I desolder and carefully resolder. I advise checking with multimeter to make sure no short!
So this took a bit extra time but lucky I catch mistake because components are very small!
I use good idea from moderator007. I do not have thick copper wire, so I use cable terminal and make my own by cutting out plastic, and flatten both side using hammer and careful sand paper.
The final is about 5mm long and 4.5mm wide. I solder this on pcb with hot soldering iron.
Programming the 841 - I use pogoprog and ATMEL ICE programmer from friend, and use Atmel Studio 7 to program fuses and hex file.
This lucky had no problem and everything was OK! So after that I carefully solder driver to led pcb and add some thermal paste between led and brass holder of Convoy S2+.
I use plastic butterfly piece for prevent short to aluminum reflector.
Finally I test and it WORKS!! Very happy that carefully soldering produce working result!  Very bright!
I cannot believe I finish building driver finally!!
Next I wait for pcb for tailcap to finish S2+ flashlight!
Question - do anyone have recommend battery to use? I have LG Brown 18650. Hoping to test flashlight much more!
BlueSwordM
The LG HG2 is a good high drain battery, so you don’t need to buy any other.
clientequator
Thank you for good advice, yes I read brown HG2 is good for high current. Good to know you recommend it. I will test driver out and post photo of performance. Now I am using default mode (4.2 at Turbo), with candle flicker mode also, but the flicker is a bit too ‘strong’, like a windy candle. I will test more later one with higher mode at 5.5A. Right now I am using spring tailcap. Will add bypass wire next. I am wait for pcb for gfs16 mosfet switch to upgrade.
DavidEF
DavidEF's picture
That “button” you made from a cable terminal is a good idea. But, it won’t perform nearly as well as a solid piece of copper. As long as you’re happy with it, that’s all fine. But, I thought you should know that will be a source of resistance in the circuit.
clientequator
Hello Mr. David! Yes I agree with you but I do not have same skill and copper to make as Moderator007. I think the resistance is not as good, but very much better than spring or wire bypass because it is still essentially a heavy copper pipe. This cable terminal is design for more than 15A so I hope it is OK! I try my best to sand the top and bottom as flat as possible.
