BanL
(BanL)
January 11, 2019, 11:04am
1193
Two type of new LED is arrived to KD.
Lumileds LUXEON V2 W (310 Lumens) Y (3V) White 6500K LED Emitter
http://kaidomain.com/Lumileds-LUXEON-V2-White-6500K-LED-Emitter
Lumileds LUXEON V2 X (320 Lumens) Y (3V) White 5700K LED Emitter
http://kaidomain.com/Lumileds-LUXEON-V2-White-5700K-LED-Emitter
Lumileds LUXEON V W (600 Lumens) F (2.65V) White 6500K LED Emitter
http://kaidomain.com/Lumileds-LUXEON-V-White-6500K-LED-Emitter
Since the Luxeon V needs to have 4040 type LED PCB, it will be available later.
Enjoy
raccoon
January 11, 2019, 11:11am
1194
Which SSD do you have?
I thought they were supposed to be very reliable.
BanL
(BanL)
January 11, 2019, 11:14am
1195
I think this is not related to the SSD problem.
I am using the Samsung once. It is really good and reliable.
The computer is used for around 4 years. It is time to do the backup and re-arrange the files.
Too many dummy files
Satan
(Satan@103TFS)
January 11, 2019, 11:42am
1196
Hi ,BanL do you have Ultrafire F13 reflector ? I search your KD but not sure which one fit …THK
djozz
(djozz)
January 16, 2019, 11:37am
1197
Hi Ban,
I see you have added the 2700K 95CRI SST-20
Unfortunately the JC1 tint bin is above the Black Body Line
Especially for high CRI leds the actual tint is really important for many of us, and most will like a tint under the BBL.
I ordered one to check it out anyway.
contactcr
(contactcr)
January 16, 2019, 3:49pm
1198
Just make it a one mode and drive it as hard as necessary to be right on the BBL. It probably shifts dramatically like all the rest
Barkuti
(Barkuti)
January 16, 2019, 5:01pm
1199
Wow! Do you like to make mountains out of molehills? High CRI emitters usually have little tint deviation, so no big deal.
contactcr
(contactcr)
January 16, 2019, 5:13pm
1200
Courtesy of maukka’s posts:
I don’t think it’s so simple to generalize every high CRI LED in respect to shift at different outputs.
adam7027
(adam7027)
January 16, 2019, 8:33pm
1201
djozz:
Hi Ban,
I see you have added the 2700K 95CRI SST-20 :+1:
Hello Ban,
Probably a JD3 could be a bit better, but for me, JC1 is also very good, and I will definitely try it.
Could you please source GD2 tint as well?
SKV89
(SKV89)
January 16, 2019, 8:59pm
1202
JC1 tint bin is no good for me. I wish it was below the BBL. JD1 and JD4 would be even better since I use my WW lights at very low output mode most of the time where the DUV is much higher (greener/yellow). With JD1 and JD4, lower output modes should be just below the BBL.
BanL
(BanL)
January 24, 2019, 5:52am
1203
adam7027:
djozz:
Hi Ban,
Hello Ban,
Sure.
I am trying to source the SST LED under BBL every time.
But it does not have so much choice for me to pick.
I will put the first priority on that.
BanL
(BanL)
January 24, 2019, 5:55am
1204
n10sivern
(n10sivern)
January 24, 2019, 9:48am
1205
BanL, if we order 1 triple emitter, it’s $5.78. Is that for 3 LED’s on the triple board? And I assume the triple board is compatible with carclo 10507 optics?
BanL
(BanL)
January 24, 2019, 10:04am
1206
Hi
Yes, it has 3 x SST-20 LEDs.
Our triple pcb will include 20mm triple lens.
I am not sure the triple board is compatible with carclo 10507 optics or not.
Thank you
Ban
djozz
(djozz)
January 24, 2019, 10:22am
1207
The triple with optic that I bought a year ago at KD was not compatible with Carclo optics.
n10sivern
(n10sivern)
January 24, 2019, 10:26am
1208
Was the optic similar size as the carclo for fitment?
djozz
(djozz)
January 24, 2019, 10:40am
1209
The optic is similar but all dimensions (optic height, placement of legs, leg thickness, I think even led postion, is a bit different from the Carclo standard.
n10sivern
(n10sivern)
January 24, 2019, 2:20pm
1210
Ah, that blows. I may order one for the heck of it, but optic height needs to match up with the carclo.
Tom_E
(Tom E)
January 24, 2019, 5:11pm
1211
Banl - much appreciate your efforts in trying to get us the "good" stuff we all want.
I have some SST-20's on the way, in 4000K and 5000K, and a KDLITKER P60 triple drop-in to try. I assume the triple drop-in is using your triple board and matching optics.
I'm hoping the triple drop-ins are mod friendly, no glue?
KawiBoy1428
(KawiBoy1428)
January 24, 2019, 5:22pm
1212
Banl - much appreciate your efforts in trying to get us the “good” stuff we all want.
I have some SST-20’s on the way, in 4000K and 5000K, and a KDLITKER P60 triple drop-in to try. I assume the triple drop-in is using your triple board and matching optics.
I’m hoping the triple drop-ins are mod friendly, no glue?
They are mod friendly “no glue”… well not on mine so far…
