That’ll just cause plastic deformation and actually thicken the rest of the metal. When I make my own washers I make / enlarge the center hole with a step bit [handheld].
This was not a washer, it started off as a square I cut from a sheet of Cu. I drilled a small hole with a drill then mounted the step bit in the vise and went to town rotating the material around the stationary bit.
As you expand the jaws, the washer bends into a bean shape. But then go around to the short part of the bean and expand again. Continue going around in a circle until the washer is circular. Yes, you get plastic deformation, but when you go back around in a circle the inner edge of the washer fails to fully return to its original position and stays closer to 90 degrees vertical (compared to 45 degrees before modding).
This technique easily opens the center hole up a couple mm when done with a 10mm #10 brass finishing washer. At least that was my experience when I used this same technique on two previous DQG Tiny IIIs.
Not sure drilling is a good idea. These washers are very thin. Drilling is likely to go through the side of the washer. Also, even if it worked, drilling would remove the beautiful nickel finish.
Fairly certain Turning Blue Chips is about to turn a pile of shavings into a bar that he will then make a light from. Converting “scrap” into a nice final product.
Did me a pintrest project with my son today. Accent lighting for his room.
Edit it didn’t work, here’s a link (Idk if you have to be logged in or just open it in a new tab or what, never tried to do a video on imgur before) https://i.imgur.com/ZhGemH2.gifv
Not sure of the imgur video is gonna embed so here’s a photo jic…
“pencil mod” on the suspect capacitors on two Astrolux A01s — both now behave properly, starting on low, eliminating the next mode sometimes flakiness.
Finally got my Skilhunt H03 modded. Used a LH351D and Lexel’s newest 21mm driver, flashed Anduril and bypassed that weird tail (mostly). One thing I think people don’t mention for this mod is to make sure the optic presses against the PCB firmly if you switch to a 3535 LED. I sanded down an XP butterfly spacer flat and thin and now it presses against that and holds everything with good pressure.
I also had a bad re-flow the first try thanks to the damn BLF A6 star I tried to re-use. Gotta love seeing that blue light.
Built my second S2+ triple yesterday. Headline specs:
Desert Tan S2+ Host
Triple Luxeon V 4000K on Led4Power MCPCB with MOSFET and NTC
LED4Power B4 driver
Carclo 10507 TIR optic
Kiriba-ru copper spacer
Both springs bypassed with 20AWG silicone wire
LG HG2 battery
My Nichia 219C triple (in the copper host in the photo) is the first torch I built from scratch, i.e. with a host and collecting all the parts together. I love it, and it’s a ridiculous little hot rod. But I felt I could go even further, so after some browsing of led4power.com’s site and these forums I saw that the Luxeon V seems like a very efficient and high-power emitter. I’m a huge fan of the S2+ so I decided my next build would be a Luxeon V triple.
The results are quite amazing. It is both brighter and throwier than my 219C triple, as you can see in the photos (same camera settings for the outdoor comparison shots, including the hilariously grainy high ISO setting that I didn’t notice on Lightroom Mobile!). I measured 19A with my clamp meter which is roughly the same as my 219C triple, but according to the tests posted here, a Luxeon V at 6 amps is 2000 lumens! I’m not sure if that really equates to 6K of real-life light output with three of them, but it is very impressive nonetheless.
I used the L4P B4 driver and their triple Luxeon V MCPCB with external MOSFET and temp sensor. This means 5 wires to the MCPCB rather than just 2 which made for some fiddly soldering, but it allows for much quicker, more granular temperature control, and more efficient heat dissipation thanks to the external FET. It’s quite a sophisticated little build and it works really well. You can set the temperature stepdown threshold wherever you please with the L4P driver, so I increased it a bit since the stock 65C was quite tame
All in all, I’m extremely impressed with this build and the quality of L4P’s hardware. But… I’m wondering if I can go even better and brighter with the S2+ host…. What say you all?
I’m not gonna lie, they came pre-soldered from L4P, which was a nice surprise as I wasn’t expecting them to, nor did I pay for this service. But soldering the 5 wires onto the driver was very fiddly and I’m quite pleased with the results of that (forgot to take photos so you’ll have to take my word for it)! My cheapy Amazon iron has done me well over the years and I’ve never had any trouble soldering onto MCPCBs or anything really.
