For me, the UT03 is not that interesting anymore. Since there’s a bunch of high powered soda can sized flashlights already. The MT03, M43, and ROT66 is already adequate. However, I would be interested if it had USB-C recharge and functional cooling fins to allow it to sustain high output in order to be practical. I wish there was USB recharge with the ROT66 because I hate taking out the batteries to recharge so often. It’s a big hassle.
Speaking of sustaining high output. Maybe Sofirn can come up with a new flashlight/host with excellent heat dissipation capabilities to sustain 3,500 lumen output from a XHP70.2 or 4x or 7x emitters from 21700 cell. This would make it a very practical and unique light that does not yet exist. Here are some examples of functional designs that maximize surface area for heat convection and radiation.
Upgrades to these lights: SP10A
*Built in USB C charging
*Narsil or ramping UI like current SP32 V2
*Side switch like SP32 V2 SP32 V3
*Deep pocket carry clip black
*Power bank function
*Optional 21700 battery version as well C8F 21700
*Ramping UI like SP32 V2
*SST-20 emitter option(5000k/4000k)
SP32 V3
*Built-in USB-C charging
*Optional 21700 version
*SST-20 5000k/4000k
C8F 21700
*Same UI
*SST-20 5000k/4000k
*FET tailcap switch only instead of E-switch+tailcap switch
That’s about the only thing they should change.
Their lights are already great, and these changes are extremely easy to implement, unlike USB charging/powerbank function and a smaller NarsilM driver, and less costly.
Who might be interested in UT03 or Q8 +XHP? It is needed not for record brightness, but needed for long work without overheating in high modes. Cooling fins are needed, but they are not critical. It is much more important to use efficient emitters XHP. I will give the data that I have. They show for example what the big difference between C8F and SP33+XHP. The cooling area of the C8F is larger than that of the SP33, but the SP33 has a very big advantage in working without overheating.
Some analogues have a high price, others have problems with a new driver, and someone does not use effective emitters XHP.
C8F 21700 - having E-switch+tailcap was the reason why I bought it.
Also I agree with Klotski. USB charging makes light more attractive. Not only for me, but muggles usually don’t have huge flashlight collection and they probably don’t have 18650/21700 charger laying around. When I have the chance, I will always charge battery in high quality charger with thermal sensor(protection), where I have control over everything. BUT when traveling, going on vacation… it’s really nice when you can charge your flashlight with cell phone charger, because you always have it or someone else does. I don’t want to carry yet another charger.
That’s why I always have a Folomov A1 thrown into my bag. Takes up about as little space as a folded-up charging cable, and will snap onto anything from a 14500 through 32650 like nothing.
They were on a flash sale at GB recently, <5bux, so I grabbed like 6 of ’em.
but you still have to take yet another thing with you. Also, as it does not know anything about that battery (flashlight would), it uses too high current for 14500 and 16340 batteries. I’d probably use it if I did not have anything else, but it’s not my first option. (I will now go buy one… for… science
Sofirn -
If you make something along the lines of the UT03 or a version of the Q8 with 10,000+ lumens, I would buy one. Either 4x 18650 or 4x 21700 would be fine, UI like a Q8.
+1 . Agreed on the UI of the SP33. The more I use it, the more I like it! A quick double click to Turbo, and a quick single click back to the brightness level you were in.
And the choice of a good ramping UI is a must I think. :+1:
I do not care about any tint warmer than 5000K.
High CRI… I can take it or leave it. It is not a priority to me.
I do not care about USB charging at all, be it Micro or C. However, if a light must have it; there should at least be a very substantial tight fitting plug covering the port.Better yet is a covered port like the Zanflare Z1 has!
I just got a C8F 21700 version and a SP33. I actually purchased the SP33 to give to my “Muggle” inlaws as a less expensive alternative to the discontinued Fenix FD-40.
SP33 - I wish turbo was brighter and there doesn’t seem to be all that much difference between the regular levels. I don’t really care for the UI on it. The e-switch is a little hard to locate on this light by touch but I generally like the size of it. I wouldn’t mind though if the head was a bit larger to make it easier to distinguish which end is which by touch. I think Fenix got this right on the FD-40. I don’t know if the slight outward flare at the lens was required for the optics but it definitely makes for a nice to hold light. I would make the crenelations on the head a bit more pronouced so when the light is on and standing on the head, more light spills out.
C8F 21700 - I love the multi-UI as you can choose what you want. The beam pattern kind of stinks with the triple reflector. Based on my Emisar D4 and the reviews I’ve seen for the Fireflies E07, it seems like multi-emitter heads with TIR optics make for nicer (floody) beams. I really like the tint of this light better than the ~6000k SP33 I don’t know what color temp LEDs are used and I haven’t taken it out yet to compare to my Nichia 219 equipped D4. The threads on the tail switch need to be phased so that the rear switch can be reached with the thumb while the mode switch is pressed with the pinky finger.
I’d love to see a light with the UI of the C8F but with 4 or more emitters and an option for a 26650 body as I find this diameter more comfortable to hold. Also, I wouldn’t mind seeing 2x 21700 or 2x26650 bodies if the drivers can handle the extra voltage. Adding a second cell might also enable the lights to maintain turbo longer since the cells aren’t stressed as much.
Their tint and R9 color rendering is even better than the LH351Ds, are easier to find in China, and a bit cheaper, and are way throwier than the LH351D.
I would like to see something similar to the NITECORE LR30 (replaceable 18650 or 21700, and maybe even a version 26650), but in the aluminum body, perhaps slightly larger for a heat sink, and HiCRI Warm or Neutral white.
Lumens - how does the SST-20 compare to the LH351D in lumens in real flashlights? SST-20's have to be defined for what they are. They compare great against a 219B or 219C in the 3000K/4000K high CRI version, but it's the SST-20 5000K/6500K that does better in throw than a XPL HI, slightly lower than a XPL HI in lumens. The SST-20 4000K has less lumens than a XP-G2 S4 and about the same throw.
The SST-20 5000K/6500K seems to be a great stock 3V thrower with a slight sacrifice of lumens compared to a XPL HI.
The SST-20 3000K/4000K is also a great thrower for what it is, but considering it's high CRI, it sacrifices lumens and throw to get there.
