The Yellow Q8 (added a test of a pink Epileds 5050 led in post#18)
Cool :slight_smile: :+1:
Fresh snowfall here, bet it would look cool at night on it.
Really looking forward to your test results on the pink one when you get a chance sir.
I almost bought some big pink COB’s last month but didn’t want to deal with the inefficiencies of Chinese COB’s, I didn’t know pink epileds existed.
I wanted to do a mod with the pink led first, to post with the led-test, but I may skip that and just post the test one of these days (but not now because I’m off to bed in a moment).
Interesting choice of LEDs. Seems like it would be fun to play with.
Do you think the spectrum is different from what other manufacturers market as phosphor- converted amber?
PC-amber is very similar but a bit more orange. I just measured a PC-amber flashlight (with a ProLight PC-amber led) and the peak in the spectrum is just a bit more towards red, colour temp is 1900K. The CCT btw is, just as the yellow one, way above the BBL. Left the yellow hotspot, right the PC-amber hotspot:
Actually, quite warm :stuck_out_tongue:
Don’t eat the yellow snow
Thanks for the testing djozz. Are you leaving these leds in the Q8 long term?
Yellow snow, you can have it. :open_mouth:
:stuck_out_tongue:
Ewww, didn’t think of that.
Wow. I”m envious, as I have made a lot of amber lights to avoid screwing up my nighttime sleep cycle.
Maybe 3300 lumen of yellow is not ideal for your sleep cycle.
It probably depends on Luminus. I think it makes sense that now that they started with the other cool and neutral 70CRI CCT’s of the SST-40, but not 4000K and warmer, that at some point they finish the SST-40 line-up with warm 95CRI versions. One can hope, right?
Whats up with the Giant Gangster Whitewalls on the chick bike, Is that a happening fad over there for cyclists or a safety thing? The Yellow Bile colored beam really makes them POP! :smiley: :+1:
It is very common to have a reflective strip on the tire over here, it helps a lot with safety. But this particular bike seems to have reflective rims instead.
Same bike in daytime:
There you go ^
It would make sense if the behaviour was similar to the yellow one but it seems a quite different led. It did not even die at 10A when I stopped the test.
I made an S2+ shorty with BLF-A6 driver to check the led. It is indeed very pink and puts out 400 lumen on a 18350 battery. With some bypasses and such it should do over 600 lumen.
respect you got the rosiest tine ever achieved in a flashlight
Kawiboy his camarea has no or not good image stablisation
Yes, just checked, my ROT66 (219B V1 sw45 R9080) at max looks yellow next to this one :party:
About the bike shot, it was my phone camera, I did not hold it still enough for the beamshot.
