Infinitely Variable Brightness 1 x AA Headlamp 1050Lumens
Thanks, Al. Good point and price. Not sure who competes at that CRI/output/throw(?)/weight/price point in a headlamp nowadays.
Thanks ActiveAl I just bought the same one……
Can you link me to some Ni-MH cells please….thanks
Woah, thanks for noticing the weight difference, ACTIVE AI!
I’m holding off until I hear something about PWM. I don’t care if a light uses PWM but I’ve gotten some budget lights that it’s hard to tell if it’s pwm or a fast strobe.
(And yes, I’m sounding like the picky flashoholics I described previously but at least get the frequency higher than the <$10 lights!)
I recommend Eneloops if you can afford them - they have great longevity. This eight-pack of AAs at $18.99 is not too bad.
That “buy with 1 click” button is dangerous…
…agreed.
We rightfully complain that OEMs simply don’t ‘get it’ in terms of the most basic of inexpensive features needed to corner a particular market.
Immediately, one of their distributors lops off 15% while using a much more palatable and familiar distribution channel…sold.
With that said and in my opinion, TH20s will remain the suggested choice for relatively inexpensive/give-it-a-try AA headlamp hosts in an ever changing LED market over but one critical feature…low output.
Sucked in again.
Just PM'd Acebeam this question:
What type of regulation (for example, constant current or voltage) is incorporated into the HC40? Thanks!
It will be interesting to see what kind of reply (if any) I get.
But note the constant lumen output (except in Turbo mode) per LED for all three battery types.
Doesn't this indicate some form of regulation? It would be nice to know the specifics.
Why is ACEBEAM statrting another thread on the same subject? There are still plenty of unanswered questions in the previous one, including my question about runtimes:
Good question and catch.
Perhaps similar unanswered questions or those involving members ever taking control back of this forum have something to do with the following business attitude prevailing in our soon to fail trade negotiations:
I would keep the significant questions coming until they are all answered in every single thread or expect nothing different.
Hmm. This might be my first AceBeam purchase. I love everything about my Nichia Manker E03H except long-press for off. Anybody have both and can compare the two?
Edit: It would be nice to have the emitter in the center, instead of offset, better firmware on the AceBeam, and better low modes with a 14500 all look like advantages of the H40 (to me, anyway).
And from what I’ve read, AceBeams are generally higher quality builds than most Mankers, right?
Well ya’ll talked me into one. I don’t even need a headlamp. :slight_smile:
I’m skeptical. I suspect Thrunite is giving the weight with the headband and Acebeam is giving the weight without it. Parametrek shows a 1g difference between the two with NiMH battery and headband.
…at least you didn’t say (here) that you wouldn’t buy it…and then bought it anyways. :person_facepalming:
I’ll put you down for not needing one because you never had one…just because it sounds better. :slight_smile:
My Thrunite TH20 weighs 43 grams w/o battery. The headband weighs 33 grams.
I PM'd Acebeam and they verified that the 34 gram weight given in their description of the H40 is for the flashlight only - not the headband or battery. So I made a gross error stating that the TH20 is more than twice the weight of the HC40. Sorry if I misled anyone into making a purchase of the H40 based on my mistake. I screwed up.
In a separate PM,. AceBeam answered my question about the type of regulation used for the H40. It's "constant current."
I have to say that I am impressed at the quick turn around I got from AceBeam on my twp PMs. Looking forward to the arrival of my H40. I will probably end up running it with a Ni-MH battery.
It still does not explain the weird runtime differences between Li-Ion and NiMH on low setting, IMO.
Great to hear that it’s constant current. How do they achieve this with a ramping UI?
Your assumption of my never having a headlamp has failed you. I have headlamps. Not this particular one but, I have a few. I don’t have a AA/14500 headlamp. Might use them more often if they didn’t feel like I actually strapped a 18650 light to my forehead. So my sentence of, “I don’t even need a headlamp” did in no way convey that I never had or currently have one.
Just ordered mine Today…it will be here Today…i will post an Unboxing Tonight.
Just got mine along with some Eneloops but I’m going to run a 14500 in it.
SST-20 95CRI looks similar to the ROT66 SST-66 95….
The 3 blinks at the top of the ramp and the 2 blinks at the bottom are kind of annoying. But maybe it won’t be as I really put it to use later.
