Really simple. Cut the trace on the single 7135, cut trace and isolate a single led on the quad, replace with a red xpe. I did it on a Emisar driver first, then ordered a TA driver from Lexel that he drilled a hole and separated the single 7135.
I adjusted Anduril ramping tables.
The way the ramping works, single 7135 for the lows now runs the red led.
Yup. I ended up installing the washer on my D4 with bare aluminum head. I removed the flip-up cover in order to install the washer. The washer is glued on with Arctic Silver Thermal Adhesive. It can take the heat, is strong enough and the silver coloring helps any bits of glue blend in with the head.
I think it looks great! Much better than the flip-cover did. Downside is the washer doesnât provide nearly as much protection from accidental turn-on compared to the flip-cover.
For the washers: I also looked in my local hardware store and didnât find anything suitable. Steel finishing washers were available, but I find them too hard to file down. Nickel Plate Brass works well because the brass is easy to file down with a hand file and the nickel plating looks great. Best place to find them is probably Ebay or Amazon. The size you want for this light is #14.
My plan now is to flash Anduril in this light and install one of Lexelâs aux LED boards.
Hm⊠I wonder if Lexel sells LEDs to light the switch. Iâll have to check.
^ That is an awesome job. That is how the Emisar light should of came out of the box.
I tweaked Anduril to give me memorized level from lockout instead of momentary moonlight. Just for those time I need to pull it out and see something for a few seconds.
I pmâed AEDe about a switch bezel(he had some nice ones for the H03) but didnât get and answer back. I think I will have to give your mod a try.
I think with the washer bezel and the firmware tweak this could be a sweet EDC light.
I donât have a D4s, but it looks like the switch is more recessed, anyone?
I asked a similar question of ToyKeeper not too long ago. I asked
I am looking to buy one of Lexelâs aux LED boards to add to my D4. He has told me the D4 driver can be flashed with the D4S FW to control the aux LEDs. What are your thoughts on that?
Here response was, I wouldnât recommend running D4S firmware on a D4 with Lexelâs aux LED board. There are a few problems:
*_Thermal regulation wonât work, because itâs configured for a bigger host.
The ramp shape is wrong because it expects 3Ă7135 chips and only has 1.
Lexelâs aux LED board canât do the low brightness modes, just on or off or blinking.
So Iâd recommend making a custom build for it. Start with the D4 config, enable the aux LED options, and tell it to skip the low mode. The lines for that are in the PL47 config. It may also need one line copied from the D4S hwdef file, to tell it which pin the aux LEDs are on._*
