Well the guy is complaining and hasnt even received his light! I have used mine a lot since I got it some time ago and love it. My battery fitted without a problem, my aux LEDs are fine, the FL is not too sharp IMHO and the missing optic leg is so stupid that nobody ever notices without actually trying to.
From the various design issues that I hope FF will fix, the two things that I can not easily address myself is a clipped-off optic-leg and a short battery tube. I hope that at least those will be improved, and the improved version announced in a way that I can be sure that I will receive the improved design instead of old stock.
If the clipped off optic leg really bothers you, you could try making a replacement.
obtain a replacement optic leg, either by cutting one from another similar-sized optic or by making a new one from epoxy.
Use a pin-vise drill to drill a small hole partway into the remaining optic and into the top of the new leg.
Insert a short piece of small paperclip into the holes you drilled at the top of the new leg and in the bottom of the optic to hold the new leg in place.
Also, the too-short battery tube is also easy to fix:
Order copper washers (there’s a link to the correct size in this thread somewhere); or
take a piece of sheet copper or aluminum, cut it into a narrow strip, then bend the strip into a ring shape and insert in the tailcap.
Hmm, I’m not afraid of some modding, and would certainly fix the light if it has issues, but I’d rather have the light done right by the factory, not even because I think they should (I do think that they do themselves a favour if they do the fixes ), but because my fixes always look worse than what the manufacturer can do with a simple design change.
Once my 2nd E07 arrives I guess I’ll try and fixing the thermal paste issue. It looks like some tiny delicate soldering. Definitely not gonna be purchasing any “premium” models In fact I’m not going to purchase anything else till there are many improvements. I would dread attempting any actual warranty work from them. I’m still on honeymoon with my raw aluminum XPL HI 5000k E07 and wowing my coworkers The 40t that came with my light has the suspicious ring around the neg side. I’ve ordered extra from IMR to compare.
1. The whole point of the video you linked is described at minute 16:20. The cooler tightening down pushing out any excessive paste, meaning that the layer of paste will always be as thin as it can get. From what it sounds like this would not happen in the E07 unless the MCPCB gets bevelled because it does not touch the surface beneath it.
5. I don’t know but there are images of it here: Fireflies E07 | Taschenlampen Forum It’s also a light with broken aux LEDs which is the reason he opened it up in the first place.
6. Nope. SST-20: Fireflies E07 preview - #801 by DB_Custom And Fireflies said that high-drain batteries should not be used with SST-20 and the Nichias. In comment #901:Fireflies E07 preview - #886 by FireFlies “* For E07 SST20 / Nichia version , we only recommend max 20A battery , 20A battery can reach max power for E07 SST20/Nichia version. With a 30T battery on SST20 or Nichia the turbo will go blue no matter how much paste used.”
There are just too many things going wrong imho. Many of which might be small issues or even non-issues for some, but there are just too many things wrong to wave it off. I did not compile the list of issues already found to nitpick on each and every detail but to express my concerns with Fireflies QC and their responses. Most of the issues aren’t even adressed. So why do a “premium edition”?
I hope so too and I hope we are both right. And I agree with that the 40Ts being fake is not confirmed yet. I will adjust that statement in my post above. But at this point with all the open issues and unanswered questions, doing a “premium model” seems kinda counter-intuitive.
But Fireflies already admitted that (and not due to excessive heat, apparently). See quote at point 6. again: “For E07 SST20 / Nichia version , we only recommend max 20A battery , 20A battery can reach max power for E07 SST20/Nichia version. With a 30T battery on SST20 or Nichia the turbo will go blue no matter how much paste used.” I have not found this recommendation anywhere. Does it come with the instructions maybe?
Edit/P.S.: I don’t want to give the impression that FireFlies is the devil himself. Far from it. They produced a fabulous looking light. They listened to us when we demanded a clear anodized version. (Which is the version I ordered) I just can’t wrap my head around all those tiny details they are lacking. That are sometimes so obviously wrong. Like the PL47 headband. I am really looking forward to their future.
It may be that the Nichia or SST20 just can’t take the current and that’s why they are going blue. If that’s the case, then no amount of improving the heatsink path at the star-pill interface will help. The problem is the peak output of the light is too high for the emitter when used with a full cell.
I still don’t see an explicit warning (all I see is “For SST20 version, around 20A discharge rate needed, LS 20A 21700 recommended”) but it’s good that they now have better recommendations online… I guess I will try mine with the 30Q to get to know how sst-20 look like before attempting the emitter swap to Samsung.
For something completely different: I have seen people with a mixed blue/purple aux-LED setup. I would have ordered that but I couldn’t find it anywhere so I went with just purple. Are those custom modded or would FireFlies have done that if I had asked?
Edit: Here is a sample image on Neals page (but apparently those are the generic FireFlies product images):
