Review: XinTD C8 (SC-82)
Thanks BetweenRides, as you can see not much difference but i was interested how it would turn out.
I was just playing with my Fluke 123, connected directly to a XR-E to see if i could measure the flicker induced by the driver at lower modes (refered to by most on here as PWM)
Here are the results with the light details photoshopped onto the display:
As you can see the sample rate and scales were altered to best suit, i am not 100% about the readings and if anyone has advise please feel free to add. It seems to add up tho, the 980 has by far the worst PWM, closely followed by the 3T6, the XinTD is almost not visible. I tested my Crelant 7G5 but could not measure or see PWM(low is not very low tho), the same with the cheapo DX 5 Mode XM-L 501b!
Edit: Still cant get the mouse over working :(
lol sucks man..it can be tricky..
also the nangj has great pwm..great driver..the 980l has the same driver as the uf 3 mode drop-in found at manafont..it's bad pwm, but a nangj can fix it also if it bothers you..luckily for me i'm not highly succeptible to pwm and wouldn't even know to look for it if it wasn't for this site lol..damn you all! ;)
Hi Pok,
I did the same thing with mine when I first got it, until I found my favorite "sweet spot" for the beam.
Missed this previously, im gonna give that a try, cheers :)
Jeansy -
Good job and this looks like a great flashlight, especially for the money.
I keep my eye out for XinTD reviews to see if the quality I experienced is consistent across models. For example; an UltraFire MCU-C88 or the UF- 980L are both top quality pieces but the UltraFire WF-502B is not. (at least the few I've seen)
This XinTD C8 looks exactly like a Palight and any number of other C8s. Which is not necessarily a bad thing but other XinTD designs appear to be more exclusive to the brand. (if it is a brand)
Am I making any sense?
pleaseignoreifnotFoy
I noticed that the XinTD C8 looked more like a generic C8 with the exterior build quality as opposed to the XinTD that you reviewed, which looks top notch quality. I have all the UFs you mention and that is exactly my experience aswell, it seems the 502 gives the other UFs a bad taint, they really are rather good quality.
Perhaps my five stars are generous given the blemishes but for the money I think it truly is the best you can buy.
I am still a new (budget) flashaholic and jumped straight in for the powerhouses with a triple XM-L and then super throwers such as my Crelant 7G5 and SF MPP1, Im glad I own these but they have allowed me to appreciate just how well rounded this light is, if I was to own one light now, at present this would be it! The king may not reign long for me tho, if the Intl-outdoor dropin combines with my SF L2T to create what I hope it will.
OK I have given this a quick go but it didn't make much difference, was this on the XinTD or another C8?
I believe they were talking about the XinTD because it is the only one I know that has the screw in reflector. I tried it myself before and did not notice much difference either.
OK following some questions about the PMW results i achieved here are some more (on low). As you can see the results match others now but also it has shown me how easy it is to get differing results. The PWM is complicated and contains different frequencies/amplitudes thus differing sample rates give different results, perhaps a cheaper meter is easier as shown by the 179 results?
Note the zoomed in waveform on the 123 on the last pic, it is mainly out of shot and i forgot to get a pic of it but at that sample rate the Hz was recorded as different dispite being exactly the same, bar the sample rate. I think it measures the frequency of the content of the 'chunks' (want of a better word lol) in the top pic.
My XIN TD C8 appears to be perfect in fit and finish; no flaws noted. Still the best $32 I have spent on a flashlight. If it would only run on 2 x Cr123 as well as 1 X 18650, it might be the best light on the market up to $50.
Can't say about Xin TD. but my C8 and UF-2100 with Nanjg 105C AMC7135*8, 2.8A installed run on 2xCR123a 3.0V very good, even Uf-2100 runs on Hi (but very! hot). Effeciency of the driver is only about 65-70% (30% is converted to heat of the driver :( ) with high voltage, but AMC7135 is rated to work up to 7V peak. None died yet.
How how many hours have you run 2xCR123A in the C8 and the UF-2100? And could you estimate how much time the flashlights were on at a time on High mode.
Your efficiency estimations look very good compared to other which have tested 56-70%.
Need to make a run test :) Not done yet.
Efficiency is not my own measurements. Once I saw an AMC7135 specs table or something like that and just remembered that it is most efficient at 3.9V - 90% and worst at 6V - about 65%.
btw, XinTD C8 is marked SOLD OUT in intl-outdoor... :(
The 1A driver is 56%, the 1.4A driver is 63% and one chip is 50%. Results are from from this thread on CPF.
UF-2100 is so small and works with 2.8A with 6V, should be a lot of heat, many around the forum get scared of lower watts in bigger lights.
i got my light a few weeks ago. i love it. there was a small speck or nick on the dome of the LED but Hank is taking care of me. he rocks.
i also had a small issue with the reverse spring on the driver and my AW batteries so i had make a mod for that. i just silver soldered a piece of copper tubing in its place with a little silver solder blob where it contacts the battery.... like .140" long overall. i would think the short, stiff spring that comes with the nanjg drivers would have worked perfectly for me so i dont know the reason for the reverse spring.
the fit and finish of my light is flawless. threads are real smooth. love that big brass pill too.
NW is real nice too.
everyone at work is trying to steal it lol.
i too noticed that it is out of stock cause i was showing a friend where to get it.
Brian
The XinTD C8 is now available for purchase in intl-outdoor.com.
A little trick I use the reverse spring trick on my drop ins.
If you are having problems with the reverse spring not making contact with the small nubs on your batteries take a needle nose pliers and bend the last coil across the middle of the opening like so.
could a 20mm-star fit instead of the built-in 16mm-star? it looks like there would be enough room for it
To XinTD C8 users: What was the longest time you ran it on high? Was it too hot to touch?
