Neales directions states “Double click” for strobe for my SST-20 3000K version. First the terminology is incorrect,it is DOUBLE HALF-PRESS.
That is not right,Mine Triple Half presses for strobe.
I put my sunglasses on and went into a dark closet! No,comments!..….I Double half pressed as soon as light went on or in any mode. I tried to determine if it got brighter. It seems like it did but I am not positive. I have no equipment to verify.
Maybe tonight on the trail I will be able to tell.
So,I either got 50 minutes of high w/ ending voltage of 3.66V W/ MY 50E………OR maybe that is turbo and my light is 3 modes[not including strobe]! I do not know!
oh,yeah,This is a FIRST in regards to the UI,A Reverse clicky
The LED changing tints so much fools you. Also, on mine, there seems to be a small surge in current when you change modes. It takes a second or two and settles a full 100lm less. Not sure why that is.
I never had this UI and then to add to the confusion he lists: 4 modes and strobe which on mine is a triple half press NOT double. I seem to have 3 modes[minus strobe] and when I double half press I am NOT sure if it gets brighter!
Group 2. L-M-H + T (2 half press) or Strobe (3 half press)
To switch from one group to the other one you have to make 4 very fast half press. If they are not fast enough the firmware interprets that it is a mode change, not a group change.
It is a bit difficult because the reverse switch is very hard and the speed must be high.
I noticed that at the first moment my flashlight had four modes and after playing with it there were only three. Try to do it
wolfdog I know you like to be super dramatic but the light stops working when the bond wires are broken. The “burnt” look is just how all of these emitters look. Maukka’s review looked the same.
In fact, you can barely see the bond wires in this picture because of the dome.
