Lumintop GT micro
+1 … Please try to get them to NOT glue the bezel Martin. AND to use a minium amount of glue on the driver.
I’m in for one…
Im in for a NW or warm emitter. Hopefully not too much glue : )
I’m in.
€dit got the
Specifications
Emitter: Cree XP-L High Intensity, neutral white or cold white, mounted on copper DTP MCPCB
Flux: ~1000 lm
Throw: ~400 m & ~50Kcd
Firmware: Tom E’s open-source GPL NarsilM v1.3 adapted by Texas_Ace
User interface:
[1] By default the GT micro is set to use the very intuitive Narsil smooth RAMPING UI. Instant access to a 2.5 A TURBO mode is also provided.
[2] A more conventional discrete level MODE-SET UI is available as an alternative. Any one of 12 predefined mode-sets can be selected.
[3] MOMENTARY mode is useful for signaling purposes or rapidly/briefly lighting up targets.
Battery: One 14500. Cell is not included.
Driver: Texas Avenger FET driver
Reflector: 29 mm ID, aluminum, smooth finish
Lens: Glass with anti-reflective coating
Body: Aluminum with Type III hard-coat anodizing
Button: Tactile with back-lit rubber boot
Ingress rating: Equivalent to IP65, do not immerse in liquids
Weight: Approximately 70g without cells
Dimensions: 36 mm Ø head x 105mm length
Link to the groupbuy: https://m4dm4x.com/lumintop-gt-micro-interest-list/
So once again they chose not to take any risk and go for an already BLF brewed TA driver with only li-ion… it’s a shame, I’d love a Ni-MH powered Narsil driver.
Anyway, this will be a best seller
EDIT : an SST20 would have been a better choice IMHO, smaller die, better tint and lower price
the AA/NiMh + 14500 driver was not near "good"
  • 14500 turbo only
  • in aa just 250 lumen
  • very high parasitic drain
  • some other downs
i am glad they skipped that ;)
SST20 option is not off the table ;)
Looks good , I can’t wait. :+1:
I hope for a GT nano light next.
Thanks for the specs update Martin, form completed. :beer:
Can you ’try’ to influence them to NOT glue the bezel……
I already did teacher ;)
:+1: … Thank you sir, hopefully they will listen. :wink:
Form filled for 2 NW versions. This little light will be awesome.
Take my money! Almost a quarter-mile of throw in such a small light I’m stoked!
If & when you can find out, let us know the CCT of the Neutral White & Cold White please. :beer:
Add one if SST-20 is added; protected battery fitment only.
I have a BLF GT70 and a GT Mini, and both of them were easy to disassemble with strap clamps. I didn’t even need a lot of pressure. Suppose they’ll sort these by glue bins now…
My GT70 had no glue. You were lucky on your particular GT Mini.
Question, what does “NarsilM v1.3 adapted by Texas Ace” mean, exactly….
And the 2.5A Turbo, why 2.5A? The emitter can take over 6A…
Really need the answer to both of those questions…
Good eye Dale. I hope that 2.5A is a misprint or typo. A stock Convoy M1 with an XP-L HI is about 3A out of the box. Of course it does use an 18650… but so what.
