[♛ FreemeGB] Fireflies E07 7* Nichia/ SST20/ XP-L HI Emitters 21700 Flashlight Group Buy -【 New Copper+Titanium 】
It may be that the Nichia or SST20 just can’t take the current and that’s why they are going blue. If that’s the case, then no amount of improving the heatsink path at the star-pill interface will help. The problem is the peak output of the light is too high for the emitter when used with a full cell.
I still don’t see an explicit warning (all I see is “For SST20 version, around 20A discharge rate needed, LS 20A 21700 recommended”) but it’s good that they now have better recommendations online… I guess I will try mine with the 30Q to get to know how sst-20 look like before attempting the emitter swap to Samsung.
For something completely different: I have seen people with a mixed blue/purple aux-LED setup. I would have ordered that but I couldn’t find it anywhere so I went with just purple. Are those custom modded or would FireFlies have done that if I had asked?
Edit: Here is a sample image on Neals page (but apparently those are the generic FireFlies product images):
Are we really believing that any 21700 cells are outputting a constant 49A?! That’s about the point SST-20s die at (x7 emitters).
I’ll buy the Ti version if there is it’s all Ti and no copper etc to ruin the look.
That is cool. I’d really like one too.
I’ll wait for the Ti version :sunglasses:
Easy enough to measure if anyone cares to do that (I have no E07)
Ordered two, but decided to order one from BG, the other from FF, so it won’t really matter who sends faster.
Used your links and codes, thanks!
Thanks pal! Appreciated.
Code for bg ? Thanks
Got my 3rd E07 from Neal and he shipped much faster than Fireflies direct.
the MCPCB have little thermal paste but not enough spread evenly. Had to add more for extra heat transferring :slight_smile:
Is it too late for some sort of Code? I’ll take one if there is still valid option out there!
Thanks
Code for the FF store has expired. Can I ask for a banggood code?
And one more question. Is the flashlight glued? I mean head bezel, driver, etc.
Sent. [quote=TSO] Is it too late for some sort of Code? I'll take one if there is still valid option out there! Thanks [/quote]
Hello, can I get code for BG? Thanks
Where can the XPL HI V3 3A NW 5000K version be had? It’s listed in some of the descriptions but there’s no option to select it.
interested in BG group buy code — thanks FreeMe!
I’m in Clear anodizing confirmation
BG group buy code still available? Thanks @ freeme.
