I believe so. If I remember correctly, the normal un-polished version produces an ugly beam but is throwier. A frosted one looks nicer and can be polished to give a bit more throw while still maintaining a pretty beam.
The D4S is much larger in the photo, but the shadows on the sides of the FW3A give a false illusion of being even slimmer.
Copy the photo, reduce the contrast, increase the exposure illumination and see the difference.
Yep, that picture certainly does make the D4 look huge.
EDIT: It is huge compared to the FW3A after all. The picture is of a D4S…. a 26650 light. See POST BELOW by iamlucky13 for explanation.
Except for length the FW3A is closest to the size Convoy S2+ no doubt.
And without the bezel & head of the D4 it probably would be closest.
That picture is a huge optical illusion.
D4
Bezel diameter: 28.0 mm / 1.102 inch
Head diameter: 30.0 mm (widest point) / 1.181 inch
Body diameter: 23.9 mm / 0.941 inch
18650 length: 93.7 mm / 3.689 inch
I have so many triples without frosted optics. Is there something about this flashlight that distorts the beam that much more than a D4, Oveready Boss, my modded triple Eagletac D25C, or other random triple mods?
I would assume some rubbing compound, like for automotive paint/plastics, and a rag would be sufficient to make the optics clear. Even tooth paste might work.
Is the frosting on the lens so deep that you actually need to sand it with sandpaper? That’s more extreme than what I was thinking.
