I believe so. If I remember correctly, the normal un-polished version produces an ugly beam but is throwier. A frosted one looks nicer and can be polished to give a bit more throw while still maintaining a pretty beam.
10511 frosted makes the nicest beam
(what hodor said)
Q: FW3A, a TLF/BLF EDC flashlight - SST-20 available, coupon codes public - #3711 by ToyKeeper and FW3A, a TLF/BLF EDC flashlight - SST-20 available, coupon codes public - #3459 by ToyKeeper
A post with more about optics: FW3A, a TLF/BLF EDC flashlight - SST-20 available, coupon codes public - #1127 by ToyKeeper
Hello,
Interested in this light. Please add me to the list for 1/ea
No doubt, it dwarfs it for sure!! :+1:
The S2+ is much closer in size, just longer.
Looks great!
The D4S is much larger in the photo, but the shadows on the sides of the FW3A give a false illusion of being even slimmer.
Copy the photo, reduce the contrast, increase the exposure illumination and see the difference.
Is there a video on how to polish a frosted optic?
The link in Joe’s post seems to suggest you can just rub it :wink: :smiley:
I know I’ll find a way to mess it up w/o visual instructions. LOL… I am special.
Pro tip: Buy spare optics :slight_smile:
Yep, that picture certainly does make the D4 look huge.
EDIT: It is huge compared to the FW3A after all. The picture is of a D4S…. a 26650 light. See POST BELOW by iamlucky13 for explanation.
Except for length the FW3A is closest to the size Convoy S2+ no doubt.
And without the bezel & head of the D4 it probably would be closest.
That picture is a huge optical illusion.
D4
Bezel diameter: 28.0 mm / 1.102 inch
Head diameter: 30.0 mm (widest point) / 1.181 inch
Body diameter: 23.9 mm / 0.941 inch
18650 length: 93.7 mm / 3.689 inch
28.0 x 30.0 x 23.9 x 93.7 mm
FW3A
25.5 mm x 92.5 mm
1.004 x 3.642 inches
S2+
24.13 mm x 121.92 mm
0.95 x 4.8 inches
I have so many triples without frosted optics. Is there something about this flashlight that distorts the beam that much more than a D4, Oveready Boss, my modded triple Eagletac D25C, or other random triple mods?
^ Those dimensions are for the D4 (18650 powered). The picture shows the larger D4S (26650 powered).
For a comparison with the D4, see the photos of the 2nd prototype on page 1 of this discussion.
OK…. that explains the picture then. Thanks for the heads up on that… :+1:
I do not have any of the D4’s, so nice to know the picture was not that much of an optical illusion after all.
Commodity LED optics being relatively inexpensive, this is wise.
That’s a very nice, elegant light! :person_with_crown: :+1:
Thanks again… this looks more like it. :wink: Below is the picture iamlucky13 is referring to.
I would assume some rubbing compound, like for automotive paint/plastics, and a rag would be sufficient to make the optics clear. Even tooth paste might work.
Is the frosting on the lens so deep that you actually need to sand it with sandpaper? That’s more extreme than what I was thinking.
With 1000 to 7000 grit Wet-Dry paper… you are not removing much. Mainly polishing once you get to about 3000 - 4000.
Please put me down for one more. This will be for a total of 3.
Thanks!
