So before I jump in, the steps to swap out the old for the new are:
Remove the bezel, glass and reflector.
Unsolder the MCPCB and remove screws.
Poke the driver out through one of the holes.
Unsolder the switch wires.
Solder the two new populated boards together.
Reassemble the parts and either use the old MCPCB with a thin layer of thermal paste or get a new one with your choice of tint.
Is that pretty much it? The light is of a size that it looks doable.
Will you sell populated and flashed boards?
Finally, how much? I know I may be jumping the gun but it looks like a very worthy mod to me.
You have 2 choices, either replace the XHP50 with an XM-L2 or SST-40 on the factory mcpcb (those 3 emitters share the same 5050 footprint) or get a 26mm mcpcb for XP LED’s (3535 footprint) to open your options up a bit. MtnE sells a maxtoch 26mm XP mcpcb which is what I’ll use for the luxeon V2.
The more I use the SP33 the more I like the UI. It is simple & straight forward. I really like the ability to jump up to Turbo & then go right back down to the brightness level you were at. Nice……
To me it looks like they are copying our UI's, so this is all good! I dnld'ed the manual and it's NarsilM/Anduril in the basics, emphasizing the 1-click ON, 1-click OFF, press&hold to ramp, dbl-click to turbo, 4 clicks to lock out.
Just fyi if it hasn't been noted already, that white glue looks the same as the white glue used on the SP36 driver, and that stuff softens with heat.
Curiosity got the better of me, so I sliced and diced the stock emitter.
Measurements before:
20.5Kcd, 286 meters (a bit higher than my previous measurement of 18.5Kcd) and 2,200 lumen at about 20 seconds.
Measurements after:
27.5Kcd, 331 meters and 2,030 lumen at about 20 seconds.
The tint definitely shifted. Stock the SP33 v2 was definitely cooler in temp compared to the C8F 21700. Now they have flip flopped. The C8F is definitely cooler in temp. The SP33 hot spot used to be slightly bigger than the C8F, now it’s slightly smaller. (I adjusted the colors to best match what I’m seeing in person)
As with most NW emitters, they can look a bit yellow at lower output levels. The SP33 v2 sure looks more yellow, but on turbo it looks a bit less yellow. I imagine some people will prefer this. I’ll try it out this week to see if the new color, smaller hot spot, increased throw and slightly less output agree with me. I’ve got a stock 5700K as a backup just in case.
Mod pics for those interested:
I might be able to shave it a bit thinner, but it’s tricky and I didn’t want to damage it.
Besides slicing it, did you also do some scraping ? I sliced mine only. I see yellow pieces around your dome in the picture. Maybe if I had before and after pictures , I would notice a warmer tint, but I don’t notice much difference and have ordered a 5000k for replacement.
Just an update, I swapped a new domed 50.2 back in my light after one day of the sliced dome. I didn’t like it. My entire spill light was yellow. It made things look wierd. The stock domed emitter is not the prettiest (meaning all 50.2 and 70.2 leds), but it seems a better compromise.
I’m thinking Sofirn should do a real OP reflector instead of this very light, almost SMO reflector that is stock. Then it would mix the yellow corona with the white hotspot and get a nicer looking beam. You loose throw, but it should look nicer. I consider this a short range, walking around type of light anyway.
My 5000 K XHP 50.2 came in today .Totally messed up the swap. I should of taken the new emitter off the new 20mm board and put it on the 26mm board that comes stock in the SP33. Instead I installed the 20mm board thinking there was clearance between the soldier joints and the reflector. Well there is if you keep the soldier blob real low but mine shorted . That in itself would not have put the kabash on things but when I removed the lens , the gasket stuck in it and pulled off the dome. Talk about a purple beam. Long story short, put the original emitter back in and I am back to where I started. Oh well. Modding 101.
Ok definitely time for me to upgrade from my panny bs!
Quick question Jason tho… how are the “5500mAh” Sofirn cells that are included in the kit on amazon?
I have a bunch that I just use as backups. Just ordered some of the black Shocklis from Richard and plan on buying more unless there are even better cells I should be considering??
I was told by Sofirn that their 5000 and 5500 are basically the same cell, but some gave higher capacity and are labeled 5500mah, while the lower ones are labeled 5000mah.
The Shockli 5500 is a superior battery. A real 5750 or so mah and good at delivering high amps. I think it came out in either 2017 or 2018 so it’s quite a modern cell. I use it in my SP33 and get longer battery life than any of my other 4300-5000mah cells.
