I wonder if it would be better to move the switch LEDs all over to the MCU so that they can all be controlled to go off and work with LVP.
I’m actually surprised Dale didn’t do this
a friend received this one a day ago and had a look....
Some observations:
a friend received this one a day ago and had a look….
I think all of them look like that. I haven’t seen a single picture that shows a stock star with a film of thermal compound on it. I don’t think we’ll see compound on the bottom of the star until their latest revision using much more compound hits the market.
Last night I swapped the stars on my two E07s. Unfortunately, I’d used way too much Arctic Silver 5 on the first one. That star just didn’t want to come out. I could slide it back and forth, but trying to lift it up… ouch! Reminded me of those old denture cream commercials “Fixodent and Forget It!”
Eventually I managed to get it off and completed the switch. Used a much thinner layer of compound the second time.
If the copper MCPCB were a little smaller in diameter you’d see their thermal compound on the bottom. It’s not seating all the way down flat onto the emitter shelf. That’s all.
Finally, ImageShack is working again!
Changed half the Aux LED’s to orange to complement the lavender or light purple look. . .
very nice dale
contactcr, I’m not that much a fan of the lighted switch to begin with so I won’t be making any changes there unless I just disable them altogether. The 4 lighted dots look neat, I like the color, but don’t care that much for the diagonally opposing action when in lockout with the aux LED’s off. I just turn the light around so they aren’t visible and don’t worry about it.
Edit: LVP is something I never see in action anyway, so again it’s something I don’t use. Lighted or otherwise. I just don’t tend to let a cell get that far down.
but what I’m saying would fix both of your concerns. It would have all 4 lights either on or off, no “slash” and allow you to turn everything off and on with the firmware, right?
Looks great.
I still think I prefer blue outer ring and purple middle ring though.
@DB Custom: I should have stated I own a ROT66 and assume the switches are the same. Edit: after closer looking the E07 switch seems to protrude a bit and have some kind of ribbing on it, can anyone who has both lights tell if they are the same or different. Why it would withhold me from buying? Because I’m a perfectionist and spoiled by both the ZL switches and the shimmed switches of the Clemence’s E21A Wizard’s ; )
When using the ROT in both winter and climbing gloves I feel and hear no click at all while clicking the Wizard is very responsive by both feeling the switch through the gloves.
You are correct that the E07 switch looks and feels the same as the ROT66. If you can’t stand the feel of the ROT66 switch, then the E07 is probably not for you.
Thanks for clarifying my doubts Firelight2.
Good idea:)
Finally, ImageShack is working again! Changed half the Aux LED’s to orange to complement the lavender or light purple look. . . !{width:62%}ImageShack - Best place for all of your image hosting and image sharing needs
Quite an achievement to replace those leds
Possibly Firelight, and that is what I asked them for, but I got all purple auxiliaries so I addressed it. Now mine is Custom, as usual. lol
How in the world did you change those tiny things? You use a microscope or something? Wow
Which SMD LED size did you use?
I used 0804’s but they had 0603’s on there. The bigger SMD barely clears.
No scope, no magnifier, no helping hands… pointy tweezers and my hot air station. Dropped one of the purple ones coming off and aliens ate it…
Thanks a lot! Now I can order some while the light is still shipping so I don’t have to wait ages.
