[Oshpark] Hexagon HQ10D - 17mm *10x* 7135 - 3,8A - dual channel
10 posts / 0 new
HarleyQuin
HarleyQuin's picture
Hexagon HQ10D Driver Board
My take on the Moonlight Special
17.6mm driver board for 10x AMC7135, Dual-Channel and Off-Time-Capacitor
Nanjg105 replacement with the benefit of additional features:
  • Space for 10x AMC7135 to achieve up to 3.8A without having to stack
  • Dual-channel connection of the AMC7135 allowing the advantages of a dual-channel firmware
  • The AMC7135 #1 (Q1) has a large solder pad under the GND connector for better heat-sinking to further minimize the risk of a flickering Moon mode
  • Dedicated place for an off-time-capacitor
Oshpark Link
The circuit follows the Nanjg drivers, so the resistors for low voltage protection and C1 are behind the diode. A Nanjg can be used for harvesting parts, although R1 and R2 in my board have a 0603 footprint, but the stock Nanjg105 resistors (0805) do fit if soldered carefully.
Q1 is connected with pin5 and Q2-10 are connected to pin6. By driving one 7135 seperately you can get lower Moon, can use different kind of PWM (fast/phase) or different frequencies for the modes and have no PWM when switching the channel completely ON to get a current regulated Medium mode. That way you can get a single-LED/single-cell driver board with output >3A, good regulation, no whining and a low and reliable Moon mode.
You need to use an advanced firmware with dual-channel like JonnyC’s STAR Firmware or Toykeeper’s Moonlight Special to switch Pin5. For more firmware options you might take a look at the Firmware Repository thread to find the latest firmwares.
To reach 3.5A or even 3.8A in a single-cell/single-emitter setup you need a high drain cell and the least possible resistance in your current path (e.g. copper braided springs, thick wires).
You can use either 350mA or 380mA current regulators, but I recommend 350mA at least for Q1, as they seem to be more reliable in low PWM modes. The 7135s, that you can buy or harvest, can behave quite differently at low PWM levels like 1/255 or 2/255, depending on mA-version, manufacturer, or simply the production batch. I only get consistent results for a chosen combination of frequency/PWM-level when I use regulators as identical as possible. I already stock a certain batch seperately only to use them as Q1.
350mA as medium mode has really grown on me and with the 10D I like a mode spacing of Moon-35mA-350mA-3500mA.
The boards are slighly oversized to 17.6mm. Oshpark tends to produce a smaller copper layer than is set in Eagle and I prefer to have true 17mm of copper
Happy modding
HQ
P.S.
Strictly speaking this board is untested. But I use these kind of boards for more than a year now and this is the 6th version, always tweaked a bit. I just ordered this newest version and post pics as soon as these are built.
In the meantime a picture from an earlier version successfully installed in the Convoy M1.
Oshpark Boards:
HQ ProgKey: Universal Driver Programming Key . Boost: HQ 15mm/17mm programmable boost driver with ATtiny13A
46mm Triple-Channel: BLF SRK FET v3 . 17mm Linear: HQ10D / HQ4D / HQ4S . Contact Boards: 22/24/26mm
Edited by: HarleyQuin on 06/28/2016 - 08:18
n10sivern
n10sivern's picture
Last seen: 2 days 9 hours ago
I built this driver the other day, but I’m having issues. I used a 380mA all the way around and a 13a with guppydrv on it. I’m not able to program it. It’s basically single mode only.
Three tomatoes are walking down the street- a poppa tomato, a momma tomato, and a little baby tomato. Baby tomato starts lagging behind. Poppa tomato gets angry, goes over to the baby tomato, and smooches him… and says, Catch up.
staticx57
Last seen: 1 hour 38 min ago
Sounds like you have bypassed the driver when soldering in the LED
MRsDNF
MRsDNF's picture
Last seen: 5 hours 9 min ago
Nice work HQ. Beer
USA
USA's picture
Last seen: 1 week 6 days ago
Thanks for sharing, I ordered/built the Moonlight v3 and was a bit challenged by it – however it all worked out after all.
Lexel
Lexel's picture
380mA AMCs had always lacking speed for ultra low moonlight
n10sivern
n10sivern's picture
I could care less about moonlight. I wanted to used this because it has more 7135’s on it.
Lexel
Lexel's picture
Did a design on my latest 17mm design with programming port
Cereal_killer
Cereal_killer's picture
Last seen: 4 months 4 weeks ago
Wow did I get lucky yesterday!
A mistake at FAB means I got these regular thickness boards (1.6mm FR4) but with 2oz copper weight!
n10sivern
n10sivern's picture
!{width:65%}https://i.imgur.com/7JHlp6w.jpg!
Build some and send my way.
