Sadly it is not possible due to the way the machining works. It has been tried many times but it is simply not possible to make it line up without a lot of manual labor to grind each piece individually by hand pretty much.
Can't the flats be set to line up with the button by loosening the battery tube slightly until they line up then tightening the tailcap holding it in place? At least that what someone else recommended long ago and I have did ever since. Of course, that won't help to line up the strap attachment point.
Something like the charging indicator in the Convoy BD01 would be coll too.
They use transparent centering-pieces with path through the MCPCB and shell to a LED on the driver.
You can see it here:
