What did you mod today?
9511 posts / 0 new
hcanning
Last seen: 6 days 5 hours ago
I finally received a couple of Convoy S2+ 18350 tubes that I ordered. It turns them into an even more compact EDC and my Luxeon V triple still draws 14 amps from the very impressive Keeppower 18350, making it ridiculously bright for its size.
CRX
CRX's picture
Last seen: 3 days 9 hours ago
vwpieces
vwpieces's picture
Last seen: 1 day 15 hours ago
I like the bolt action.
carpmon43
Last seen: 3 weeks 5 hours ago
i like the shiney brass
MRsDNF
MRsDNF's picture
Last seen: 1 hour 32 min ago
Like it. I want to know how he did it. That must be so small. I smell an alien here or alien technology. Beer
Firelight2
Firelight2's picture
Last seen: 2 hours 28 min ago
Filed down a #14 nickel-plated brass finishing washer tonight. Thinking of attaching it to my clear E07.
I don’t think the E07 really needs a washer to prevent accidental activation as the light is big enough it doesn’t move around in the pocket much and the button is small and flush. However, this washer would provide a little more protection and would make it easier to find the button by feel when reaching into a pocket.
The washer slightly overhangs the flat part of the light around the button. If I end up gluing it on I’ll try to fill up the gap so the lower edge can’t get caught on something.
Here is what it looks like not glued on yet:
pinkpanda3310
pinkpanda3310's picture
Last seen: 3 days 19 hours ago
Washers seem to be the thing for anti-pocket burn lately. That one looks like a nice one firelight Thumbs Up
Nicolicous
Nicolicous's picture
Last seen: 10 hours 7 min ago
!{width:50%}https://i.imgur.com/wNTAcSJ.jpg!
nice work Firelight.
how did you take out the switch ring?
was it press fit?
Nico -.-
carpmon43
i was thinking of a 3D printed lens cover and button cover in one (dont have any workshop machinery here)
Tom E
Tom E's picture
Last seen: 26 min 56 sec ago
That would be interesting. Not sure if I've seen that for a flashlight before? Are you think'n made from soft plastic that has a flexible all one piece connection between the 2 caps?
carpmon43
Tom E wrote:
That would be interesting. Not sure if I’ve seen that for a flashlight before? Are you think’n made from soft plastic that has a flexible all one piece connection between the 2 caps?
pritty much, even PLA if push comes to a shove, end of the day there’s plenty of different velcro straps about. havent fired up the mind Blender3D yet. (costs a bit for the rubberised filoments, and then theres setting up the machine).
tbh i’m surprised the torch manufactures don’t do silicon injection moulded versions, is a very short design step.
Tom E
Tom E's picture
I guess I've seen this before for binoculars. I got one pair with separate cup protectors and it's a nuisance, but if they were connected, and better yet, connected to the neck strap, it works well. For a flashlight, not sure it would work well connected to a lanyard maybe...
joechina
Last seen: 1 week 5 days ago
Lens cover?
I would try this
30-69MM Transparent Rifle Scope Lens Cover Flip Up Quick Spring Protection Cap Objective Lid for Airsoft Gun Caliber HT37-0072
https://m.aliexpress.com/item/32869480658.html
My idea is to use a diffusion film on the cover to change the beam of a GTmini from throw to flood.
But I think DC fix is not enough. I need more a lens structure or pebbled on it.
Any ideas?
contactcr
Last seen: 4 hours 10 min ago
I suggested this in another thread I think DC Fix will be enough, have you tried? Every time I have used DC Fix on a thrower it totally kills the hotspot. It wont give you a super wide beam but it will blend the hotspot into the spill quite a bit.
joechina
No, I need the light first, then I can measure and order a cover.
contactcr
Do you plan on putting the DC Fix over a 2nd piece of glass? It’s pretty thin. There are more thick “vinyl” feeling alternatives that may work better if you dont use two pieces of glass.
I got one of these same covers from Kaidomain for my Jaxman Z1, they are pretty cool.
DB Custom
DB Custom's picture
Last seen: 2 hours 43 min ago
Totally mind boggles me why someone would buy a light designed for throw then go out of their way to kill the throw…why not just buy a different light?
contactcr
He’s going to put the DC Fix on a lens cover. Dual purpose!
DB Custom
DB Custom's picture
Ah yes, so much better… make a purpose built small light large and bulky. Wink
contactcr
However, if it was some magic magnifier than increased lumens 2% you would be all for it!
joechina
To get one single light that can do all
And small and light is in my terms 16340. For me the mini is already big.
Where you never in the situation: Yes, at home I have the right light for the job
Mike C
Mike C's picture
Last seen: 3 weeks 4 days ago
I need a dual switch light for testing all switch combos my drivers and firmware support. I’ve had a L4 laying around hardly used for ages so why not give it new life as a driver firmware testing unit. My drivers are 17mm though, so I made a specific version for the L4 with integrated E-switch. As it’s bigger I can fit more regulators on it, so I now have full constant current PWM free ramping from 0.05 amps up to theoretically as high as 8.5 amps.
New custom L4 driver:
Flashing firmware acupuncture style, only have to unscrew the head and stick’em in:
The only LED I have around that can handle up to 8.5 amps is the SST-40 so that’s what I used. So, now I finally have a test unit. I need one because testing on a bench platform is not the same as using a real light.
carpmon43
joechina wrote:
Lens cover?
I would try this
Any ideas?
those capes are handy for colour filters.
Tom E
Tom E's picture
Nice Mike C! Would this work as e-switch only? How's the parasitic drain? I got lots of questions, but mainly what's the MCU?
Cereal_killer
Cereal_killer's picture
Last seen: 9 months 4 weeks ago
I believe it’s an attiny1634, he has a thread on them here
Beautiful driver MikeC, did you use a script for those vias or place them all by hand?!
I’d say I’d try to use that method (Cu ground ring with lots of vias) next time I need to size up a driver quickly but I’d never get that many vias aligned that well. That’s a piece of art!
Mike C
Mike C's picture
Tom E wrote:
Nice Mike C! Would this work as e-switch only? How’s the parasitic drain? I got lots of questions, but mainly what’s the MCU?
Thanks guys! Cereal_killer is correct. I use the ATtiny1634. Drivers and firmware support off-switch, E-switch and dual-switch. Same firmware, no need to re-flash, which is why I need a dual switch light for testing so I can test it all. I have a switch configuration setting so I can change on the fly.
I haven’t tested parasitic drain with my better DMMs. I just tested with the one I have here and it’s undetectable, but I’ll test some tine during the weekend with my better DMMs. When I built 7135 and CAT4104 based drivers I got it down to 0.1uA with OTSM compatible drivers, but I need to test with my better DMMs when using these new regulators. They will have some sort of shutdown standby current, hopefully really low. Datasheet only specifies a max shutdown current of 1uA, no typical or minimum shutdown current.
To keep parasitic drain to minimum I power the digipot directly from a MCU pin, and the negative side of the voltage divider doesn’t go to ground, it also goes to a MCU pin so that I can switch off GND for the divider. On of the benefits to having a lot of pins to play with Smile I don’t actually need the voltage divider for 1S but I use it for OTSM power off detection.
I use a script. Placing them all by hand would be horrible! I’ve deleted a few vias though, as I routed some signal paths out in the GND ring area.
Tom E
Tom E's picture
K, thanx! Might be asking you more bout this, but on the dedicated thread - I'm subscribed now.
1stein
1stein's picture
Last seen: 15 min 2 sec ago
Recently (like 3 weeks ago) I've modded Convoy S2+. This is one of the twin lights I want to put together. This is supposed to end up on my bike's steering bar since I'm cycling a lot. So the plan is to install 2xConvoy S2+ with striped lens (as short range lights = do not blind other drivers), a mid range one (thinking if not use Emisar D4s) and a long range (Convoy C8 SMO?) and Fireflies PL47 on head. All the lights will be 4000K, various CRI (70-95). This is what I've done: I cut off a piece of brass rod, filed, sanded, drilled holes and fit into the pill:
Then put some Arctic MX-2 paste inside to fill out remaining gaps and pushed in the piece of brass rod leading wires through.
The rest was a piece a cake. Used Luxeon V 4000K from L4P (which I love, even with not the highest possible CRI). I soldered it onto the pill with a tin paste.
Soldered wires, bridged springs and put parts together. You surely know how does the C S2+ look like so I skip the picture of host. But what's significant. Firstly I put inside just a cheap striped lens for S2 (don't remember where acquired - BG? GB? or Ali?). After a few days arrived an original Carclo Stripe lens LT-0843. I was stunned with an output difference it caused. Looks like 29% lux gain!
Cheap stripe lens:
Genuine Carclo stripe lens:
May your weekend be full of succesfull mods! Beer
1stein
1stein's picture
Have a while more so maybe I could get you bored with another my build. Nothing really interesting.
A Jaxman X1/XHP50.2 This is bill of components:
2.5A 6V FX-35 driver
XHP50.2 4000K 80CRI LED
Jaxman X1 host (not available any more, a pity)
Some on-site pics:
Resuld? Predictible - not bad performance but greenish corona is above my acceptance level. Some pics:
The Last Katun
The Last Katun's picture
Last seen: 7 months 1 week ago
DB Custom wrote:
The driver, with it’s new 70N02 applied… their FET has a 15mOhm Rds on time, the new one is 4mOhm Rds On. This is the one that started the FET craze with Comfychair leading the way what seems like forever ago…
have the 3-LED version; do you think it’s enough to change the FET to give the flashlight a bit of sprint?
