[Optisolis/E17A/E21A] Jetbeam Jet-µ
In what way?
The cool Optisolis leds use a special 420nm led under the phosfor to prevent a dip in the cyan region of the spectrum, this gives them that extra bit of colour rendering. The warmer Optisolis use a conventional 450nm led because the blue/cyan part of the spectrum plays less of a role and going with the 420nm led does not help much. Therefore it does not stand out much compared to the very high CRI version of the E21A.
Ah, never knew that. Yeah I definitely want to have an Optisolis that’s violet based and not blue.
So, with anything lower than 3000K, E21A is a better option. Better invest in longer regulated runtime. To the naked eyes its extremely hard to see any difference between 3000K and 2700K Optisolis vs 3000K and 2700K (mixed) E21A. From Maukka’s test graphs there’s indeed a substantial higher CRI in color samples. They come from different phosphors mix I guess. As Djozz observed a year ago, Optisolis is the first Nichia with green phosphors, other than obviously, single color green E21A. This green phosphor can be excited by normal 450nm LED too.
- Clemence
I didn’t know that either. On these suggestions I would like to change my Jetusolis order to the 5000K. What do I need to do?
Not much difference in 3000K
In 4000K Optisolis still wins with higher blue and red. Some CRI snobs can see the difference by the eyes. Camera will spot the difference easier
5000K and 6500K, Optisolis KO E21A and any blue pump LEDs
IMHO, warm white Optisolis is a great LED alternative for premium high CRI general lighting since cost per LED is so much cheaper than E21A.
- Clemence
Sorry I must have missed it while going through the thread, but both the Optisolis and E21A models work well with nimh rechargables correct?
Correct, and that’s the only battery I recommend. Never ever use alkaleaks battery whenever possible to save your flashlights.
- Clemence
Excellent, I know some still prefer lithium primaries for AA/AAA lights so wanted to be sure.
E21A
E17A
Beam comparison. I shot under exposed (–2 stops) to show center beam better but that caused the tint over saturated
- Clemence
I consider myself an enthusiast but i’m starting to think clemence provides TOO much information about his products. Is that possible?
I think its great. All the added beamshots and tint comparisons make it alot easier to select preferred LED both for his products and any custom builds you chose to do on your own.
I have a few lights with e21a at this point with 4000k and 4500k and they are by far the best tinted and colour rendering lights I own!
but that ruins the surprise when you order from a no name company and they describe the tint as “yellow-white” or something
Those are the pictures I promised from my earlier post. This is BLF, people value research, data, and test results. unlike the other forum out there.
Do you prefer I don’t share any information instead? I think I have a problem being an enthusiast and a seller at the same time. Can’t decide which one should I be.
- Clemence
Of course I think more information is better. I’m only joking
However, it does just drive me deeper into this rabbit hole digesting all of this new information
Yes and no. I really like having the data to evaluate. However, it’s also possible to get the audiophile disease where you get lost in evaluating, and forget the real goal is to use and enjoy the product (it’s only a small percentage of audiophiles, of course, but they’re the ones who get noticed).
I’m currently thinking what I should do personally is just order each of the different emitters that potentially interests me on MCPCB’s, try them out on my work bench, and decide from that what my dream light is.
Exactly what Ive been doing. Have already tried most combinations of e21a, and just ordered a number of optisolis to combine and see.
For now it is e21a at 3000k and optisolis 5000, but looks like I’ll end up at higher cct with optisolis
I will put E21A and Optisolis modules for DIY-ers to experiment themselves but take note:
- Jetusolis and JetuE21A lens holders are NOT interchangeable. I modified the lens holder of JetuE21A so much that you can’t use Optisolis with it. There’s a potential one could easily crush the Optisolis put in the JetuE21A.
  • You can use E21A/E17A LED modules in Jetusolis but the beam will be about 50% narrower and you’ll lose ~20% output.
- Clemence
Updated some pictures and measurements in the product pages using final TIR optics selection.
Warning: big pictures, click to enlarge
- Clemence
Thank You Clemence.
