What did you mod today?
9496 posts / 0 new
djozz
djozz's picture
Last seen: 46 min 9 sec ago
Good mods 1stein!
I find the 80CRI Cree leds very acceptable outdoors, even the yellow corona.
1stein
1stein's picture
Last seen: 7 hours 15 min ago
djozz wrote:
Good mods 1stein! I find the 80CRI Cree leds very acceptable outdoors, even the yellow corona.
Thanks djozz. I wish I knew as much as you guys, but I’m very happy I can learn from this forum. Actually from the great people willing to share their priceless knowledge. Though it’s still a long way ahead, but seeing own skills improving is great as well. However there should be a warning at the forum entrance: you enter at your own risk. Not leaving this forum in time may result in becoming a dedicated flashololic. This is contagious! Yep, too late for me…
vwpieces
vwpieces's picture
Last seen: 3 days 22 hours ago
My Wally World Solar Street Light,
Aint really solar anymore… It got a power assist.
Cant count on the Sun, what can ya count on?
Added a 2.1mmX5.5mm power jack to plug it into a USB wall wart. Charge circuit cuts out about 4.1V so it’ll be fine. Still got a couple 18650 laptop pulls inside cause they are better than the garbage cells it came with.
Look Ma, no batteries.
Firelight2
Firelight2's picture
Last seen: 2 hours 3 min ago
Glued the modified #14 finishing washer around the button of my Fireflies E07 last night.
Used epoxy so this is permanent. Removing it would probably damage the finish. Didn’t see the post about Goop till I’d already done it.
Still the final result looks pretty good. The gap below the sides of the washer are covered by tiny bits of aluminum strip. It hides the glue and makes the light look like it was manufactured this way.
Here are some pictures:
Firelight2
Trying to flash my D4 to Anduril, but I can’t get AVRdude to run.
Every time I try running it the command prompt says “Does not have permission”. And a popup window appears saying the app is not allowed to run on my PC.
I installed AVRDude last week briefly. For the first 20 minutes it worked and behaved normally, but now the app won’t even run. Uninstalling and reinstalling didn’t help.
Using Windows 10. This is a home PC and I’m the only one who uses it. I have admin privileges and have no idea how this happened or why the app stopped working.
Any ideas? or suggestions for alternate programs that might run?
DB Custom
DB Custom's picture
Last seen: 3 weeks 6 days ago
You may need to install the driver for the USBAsp, Windows 10 may not have it in it’s library. I recently had to restore Win 7 Pro and lost things such as this, had to hunt everything down and do reinstalls.
Tom E
Tom E's picture
Last seen: 15 min 19 sec ago
Might try running it as admin (right click), even though you have admin rights. Seen you need to do this sometimes just once.
carpmon43
Last seen: 2 weeks 2 days ago
that happens a lot with 3D printer stuff, it seems microsoft runs some kind of check or something then disallows the the thing! .. i.e. it ran fine for 20 minutes? hmmm then not.
next comes the windows update that resets everything back to let every one use and record and store bumf on your pooter.. then your drivers no longer function.
(in hind sight microsoft are robbing you of any non microsoft ‘approved’ things. very anoying being monopolied isnt it).
‘zadig’ can be a help, haven’t got a link to it off hand but it’s got the printer working a few times. it basically recalls or initialises the drivers microsoft reset to ‘off’..for want of metaphor’s that seem extremely accurate lol.
contactcr
Last seen: 3 hours 16 min ago
UltraTac A1 emitter swap/tear down
The sum of the parts are actually pretty decent. It has a copper mcpcb, short brass pill, retaining rings, LED spacers, o-rings, etc. HOWEVER, it’s glued everywhere. The retaining ring has a slight indentation on it that I tried to use but it didn’t budge. I ended up using the smallest dremel drill bit I had (1/32”) and making two holes in the retaining ring and nearly breaking the best hardened stainless tweezers I have but I got it free. I found blue loctite on the retaining ring only. I was going to swap the tail spring as well but that ring is also glued so I decided not to.
TL;DR – dremel > blue loctite Sad
Parts:
Money shot:
Two holes in the ring are mine and the left hole in the driver ground ring is mine, the right hole was already there.
I swapped in a LH351D 4000K 90CRI and didn’t really lose much/if any output from the ugly XP-L HD that was there before.
Cereal_killer
Cereal_killer's picture
Last seen: 9 months 3 weeks ago
Busy weekend. 3 lights modded with triple channel drivers:
Friday was this NS22 Seeker, I built it a 1+8×7135+FET TA driver with bistro. You can swap the driver without opening the bezel but I went ahead and did that so I could adjust the centering ring height a bit which cleaned up the transition from hotspot to corona. Stock 3500k 95cri SST-20
Saturday was the Utorch S1 mini. Its got a custom driver, 1+4×7135+FET running anduril and a 5000k Luxeon V2 with a layer of DC fix on the inside of the aspheric lens.
Finally I capped the weekend modding extravaganza off with the AX3 mod. Again a TA 22mm driver but with the 1×7135’s output leg isolated and modified anduril FW for a red moon mode than can be turned on/off without flashing new FW.
My anduril light collection is up to 6 now (and only one of these lights came with compatible HW)!
chadvone
chadvone's picture
Sweet mods.
g_damian
g_damian's picture
Last seen: 3 hours 10 min ago
I built Luxeon V2 5000K E2 triple using 18500 tube and 18650 battery. More details in this post
djozz
djozz's picture
I build a small wooden box for my spectrometer. The device came in a complete suitcase that protects the expensive tool very well but is very inconvenient to use because of its size.
And because I was in a nostalgic mood I made this little chest with pine wood, triplex, wood glue, nails, paint and some dark grey polyether for the inserts.
It is not made very precise but it feels good and makes for a very good protection of the spectrometer, that is now much easier to carry with me, with less worries.
MRsDNF
MRsDNF's picture
Last seen: 4 hours 32 min ago
Watch out Don. Smile
Nice job djozz. I guess you still have all your fingers and thumbs.
djozz
djozz's picture
With everything askew, it is not a work piece I would dare to show Don, I hope he is not watching Facepalm
Cereal_killer
Emitter swap in a TK35UE for a member here. Swapped in a 4500k 90CRI emitter (XHP70A-01-0000-0D0UJ445G).
Build quality is amazing as you could expect. The battery carrier is the driver and the battery charger all in one!
WillyD
I finally picked up the pieces of an F13 triple I started over 2 years ago. I had amber/yellow/red in the tailcap from when I started, but I decided to go all amber. I’d like to throw some amber trit vials under the lens.
Purchased the spacer from kiriba-ru back in ’16 or ’17. Wait too long to build this stuff, something better always comes along. With the latest boost drivers, I’d much rather go with a single xhp50 or 70 now. I do love this spacer, though. Huge chunk of metal.
DB Custom
DB Custom's picture
Took the C8ish 7 emitter ebay light to the next level with 7 SST-40’s. Out of the box on a Basen 26650 it measured 1368 lumens from XM-L T6 emitters. Now, with the 40’s and a Samsung 30T, it does a start value of 9694.5 lumens. Big Smile
DB Custom
DB Custom's picture
The F13 makes a very neat triple, with it’s 26650 cell capacity it’s a nice solid build. Wink
gchart
gchart's picture
Last seen: 3 hours 18 min ago
^ show off Wink
(PS – nice touch with the 45 casing)
WillyD
gchart wrote:
^ show off Wink
Lol…yeah, no kidding! DB is there a build thread on that F13 somewhere?
Wieselflinkpro
Wieselflinkpro's picture
Its This flashlight, I think: http://budgetlightforum.com/comment/1447900#comment-1447900
Did you only do an emitter swap? Or does it have a better heatsink now.
Do you have a link to this Flashlight?
Nicolicous
Nicolicous's picture
Last seen: 11 hours 43 min ago
Several months ago i bought 3 Osram Flat black and now I decided to put in Convoy L2 with LD25 constant driver tuned to 5A
Driver hook up with XML2 for testing current purpose. Didn’t want to kill my Flatblack during testing.
Driver with 20mm brass ring adaptor
Beamshot at 8m with perfect focus. Thanks for the orginal centering ring and I didnt to do any focusing.
inside reflector
Took lux reading 8m and it gives 3850 lux. This equivalent to 246k candela.
I also did mod with convoy C8+ similar setting and it have slightly lower candela but not much. Considering the size for pocket I definitely think C8+ is perfect reflector size for this LED throw and it’s a winner Smile
Link to Convoy C8+ with Flat Black
Nico -.-
i42dk
i42dk's picture
Last seen: 6 days 3 hours ago
Don’t know if it counts as a “mod”. But i made a 5-minute setup, to light up my wife’s Harry Potter LEGO castle.
Q8 was the only driver I had that was’nt in use. It’s extreme overkill, but gets the job done Big Smile
BLF Q8 driver + XP-G3 R4 8A3 2700K + 3 × 18650 LG S3 2000mAh cells + Anduril in candle mode
Link to a givf showing it in action: https://imgur.com/HhzK5cw
DB Custom
DB Custom's picture
Nice Castle lighting! Smile
Wieselflinkpro, it’s the SupwildFire 7x shown in THIS post. I had to make an aluminum filler for the hollow head, changed the large MOSFET, bigger leads, spring bypasses, and of course the emitter swap. Will probably do individual copper DTP 16mm MCPCB’s as a final tweak. This has been another incremental mod light, recording each step along the way to see where the gains come in…
polarweis
polarweis's picture
Last seen: 3 weeks 1 day ago
I made a flat white 1mm² in my convoy c8. The gaskets from int outdoor are for a 7mm reflector but i used it anyway. After turning the bezel a couple of times i got a pretty good beam. Uses a single mode nanjg driver with 3.04 amp. It gets pretty Hot after 60 seconds.
IMG-20190130-154438**
IMG-20190130-154502
Top is the flat white and bottom a c8 with xpl hi and fet driver.
"It wouldn’t be so bright if there wasn’t a shadow every once in a while." - Jason Mraz
Lightbringer
Lightbringer's picture
Last seen: 17 min 58 sec ago
Damn, that’s a nice tight beam! LOL
polarweis
polarweis's picture
I used a lightmeter app on my phone.
utorch ut02 xhp 35 got 120k candela
convoy c8 xpl hi fet got 69k candela
convoy c8 flat white got 169k candela. Its at around 3amp so a little heigh meisurment i guess.
btbw
Last seen: 1 year 8 months ago
Since this is my very first 'essential' post here, I'll shortly indtroduce myself...
I've been AF (Anonymous Flashoholic) since the middle 2017. At least this is the date I've started to read BLF and even worse - started to buy ... THEM !
Yes..., I know I should not, but...  I buy THEM because they are cheap, sexy and ... available wink. Someone, please help me to stop this...
Looks like, I'm especially in love with Convoys S2+ (well... basically it means - whenever price drops below 9$ I buy them, sometimes I manage not to do so). For this price man can buy only 'basic' 6x7135 XML2 Grays... and it's ok for an addict like myself (guilty me, once a month you have to take your dope)
Of course, last year it happened to buy some other stuff as well (2 Convoy's C8s and 1 C8 from Sofirn when they droped below 15$, and 2 SP33's lately on Christmas for the less then 20$ each) but you know what they say - the first love is the biggest one and for forever...
OK, now to the point - this about my first mod.
Let's call it "Quick and dirty 2S (2x18650) mod to 2S+ "
The background...
1) To many 'grey' S2+ on my shelf. To many to take everyone and each of them for a walk from time to time
2) Plenty of 18650's (many of them not so modern high drain models)
3) The curiosity - what the XHP family (or the other high output 6v Leds) can do inside my little beloved one ...
The obstacles...
1) Mainly there is one.
Why the heck they don't produce and sell extension tubes in a most common size (18650) for a most common flashlight (S2+) on the planet ?
You can easilly find them for L4's, C8's and many others but not for S2's !!!
The decision...
One of my sweethearts must die... to give the birth to something bigger...
The result...
Remove everything form inside the head of S2+ and cut it exactly in half (I did it with a dremel tool)
 fig1
Now, you have a muff wich will hold and connect two original body tubes of S2+'s. The thread  must be milled out 3-4mm deep from one side of new muff (one where was a cut made) for the best matching with the original tubes. Do a final polish to the sharp edge with some sand paper, and we are done with hard metal tooling...
About the LED...
I've choosen XHP50 (it has good output, it is efficient in low current, it has high Vf value which should ease a load on my 7135's and it was ridiculously cheep to get.
About the driver...
I've decided to keep the one what I have had form inside a donor light (costless solution).
I had no suitable electronical components for a 'Zaner mod' modification, so in my case the original Convoy's 6x7135 dirver board was used as a simple 'one mode' linear 2.1A current regulator.
To make it work:
1) Remove D1 from original driver board (the same element which you remove to place 200Ohm resistor in classic Zener Mod) - this will disconnect excessive (+8V) power voltage from the MCU (we may need it in the future...)
2) Connect VDD leg of any AMC7135 (one of them is enough because all AMC's are in parallel) to +Vin - this will open a full throttle of all 7135's (6x350mA)
fig2
For my current needs it suits good enough to have one "high" mode only. Latter (e.g.when I get a proper Zener diode) I may consider to restore MCU functions for this driver.
Since basic Zener mod destroys the proper low battery protection then you may try to restore it by modifing the board (cut of the trace with the original R1/R2 voltage divider and build a new one which would be powered by +Vin). An example was given - e.g.look for "The IMR Enhanced Zener Mod to run the MT-G2".
So how does it looks like ?
fig3
fig4
Pros:
1) Twice as much 'floody' lumens comparing to original design (for 2.1A XHP50 gets 1560 lumens vs 800 lumens for XML2). You can really see the difference in the dark.
2) Does not need expensive high drain accus (like when you power up XHP from a single 18650 cell) or some fancy low capacity and high price 2x18350. It comfortably sucks 2.1A from every low cost 18650 I have in my drawer.
3) It gives similar running time to original S2+ with more light
4) It is still very convenient in every day use. It's size is just 43mm (1.7inch) more then C8. Fits well your pocket since it is as thick as an orignal design. And feels good in your hand.
5) It was planned to be "zero" cost mod. And in fact it is (almost). I had to "sacrifice" one of my Grey's (cut off the head) but it was worth it. I bought XHP50 on a 17mm copper mcb some months ago for 2.5$ on AliExp (4.5$ including delivery! minus 2$ coupon)
6) And it's still "my precious..." S2++
Cons:
1) Of course, it is not so cute and handy as a original S2+ beauty, but still close to my liking.
2) Get's a bit more heat in 'high' mode.
This should not be a big issue since the original design has some redundancy and is pretty safe with 8x7135 and XML2 pill (power used by XML2: 2.8Ax3.4V=9.5W  plus power lost on 7135 regulators 2.8Ax(4.3V-3.4V)=2.5W makes 12W loss in total) and mine has 6x7135 and XHP50 LED (power used by XHP50: 2.1Ax6.3V=13W  plus power lost on 7135 regulators 2.1Ax(8.4V-6.3V)=4.4W makes 17.4W loss in total).
Not a big difference (5W more), but the body of moded S2 is now longer so the heat dissipation should be also a little bit better.
This post has been written by a beginner (myself) and for beginners, so all experts and advanced users please be gentle or just skip it...
Cheers to all BLF flashoholics...
djozz
djozz's picture
That is a very clever mod btbw!, and welcome to BLF. Since I do not know electronics very well I can not judge what you did to the driver, but it works so you did the right thing Smile , am I correct that the voltage on the 7135 chips is outside the specs? (but who cares if it works?).
Great start on BLF Smile
