Development is on going… not at lightning speed exactly… Anyhow, now I’ve at least reached the stage where I can start testing all switch combos in a real light so I’ve built a dedicated test unit. Posted in the mod today thread but worth posting here too.
I’ve had a L4 laying around hardly used for ages so why not give it new life as a driver firmware testing unit. My drivers are 17mm though, so I made a specific version for the L4 with integrated E-switch. As it’s bigger I can fit more regulators on it, so I now have full constant current PWM free ramping from 0.05 amps up to theoretically as high as 8.5 amps.
New custom L4 driver:
Flashing latest firmware:
The only LED I have around that can handle up to 8.5 amps is the SST-40 so that’s what I used. So, now I finally have a test unit. I need one because testing on a bench platform is not the same as using a real light.
Not sure if this is the best thread for tech questions/discussions on this driver. But if you could summarize as brief as you can the basics of CC drivers. I know there's no PWM's and therefore very efficient. But I thought heat is a problem when running at lower than max output. Also don't know whether resistance is still an enemy since it doesn't boost voltage, or does it?
For the UI I'll cover the basics:
my priority is always 1 click ON, 1 click OFF with no delays, and press&hold for ramping. Whether ramp levels are only 2-7 or a smooth 200+ (maybe 100+) would be configurable/switchable some how. Ramp direction can be switched based on timing since the last ramp. It's important to have last level memory, but be able to override memory with easy access to lowest and highest levels.
This is basically what Anduril does, based on Narsil, but we are seeing more and more commercial lights operate this way, and I like to think BLF has been an influence on this trend.
There’s no where else to ask, plenty of technical questions in here already, ask away
I described the use of these in the OP, but in short the regulators on these drivers use current sense resistors from 1,2 K ohm and up. That’s a handy resistance value, so on one of them I use a 256 step 10K digital potentiometer instead of a fixed resistor which makes it fully adjustable. When it reaches it’s max current I turn on another regulator with fixed current and reset the adjustable one back to lowest current setting. The CN5710 is rated up to 1 amp, the larger CN5711 is rated to 1,5 amps. I’ve also “converted” the 256 step 10K digipot into a 768 step 30K digipot which makes the regulator adjustable from max down to about 0.05 ~ 0.06 amps in 768 steps.
I have to ask about this. When exactly does the light turn on? As soon as you press the button? Or as soon as you release it? Currently I have short cuts from off and I don’t want the light to cycle through modes when entering the short cuts from off, so I have a very slight delay for multiple press detection. Narsil and Anduril don’t have this delay? Does that mean they don’t have multiple press short cuts from off, or they cycle through the modes when entering these shortcuts?
For NarsilM, I do it on button release for both 1 click ON, and the 1 click OFF. Anduril does it differently - I think for going ON, it uses the button press, but for going OFF, she does have a noticeable delay but I believe she's trying to fix that.
NarsilM will have small delays for multi click sequences, so for example: a dbl click goes to turbo, but for a triple click I don't want the user to get a blinding flash, so I delay to properly detect when the multi click sequence has ended. My earlier versions did not have that detection/delay and I got complaints.
Ok, just read that post bout doing the thermal test - Wow! That's pretty cool. We'll have to see how that plays out in the real world I guess, unless you already know or you know what to expect. I don't understand everything though, bit I assume this driver will be capable of true smooth ramping? If so, could we still apply the non-linear intensity ramping TK came up with and is used in both NarsilM and Naduril? We use a python script that TK wrote to generate the tables, parameter driven.
I do smooth ramping with these drivers. The actual mode values used in my firmware (and stored in eeprom) are current values in mA. For example for 3 amps the mode value is 3000. I use the current sense formula in the datasheet to calculate the digipot position and how many additional regulators need to be turned on to meet the entered current. My ramping is an algorithm that increases/decreases the LED current exponentially based on the current value, and it’s rather smooth. I haven’t settled on the final algorithm yet but it’s good enough to continue on with other things.
I could even go one step further and have lumens values instead of current, but that would mean separate formulas for each LED type. I know, it’s absolutely unnecessary, but this kind of stuff is the fun part of the hobby for me
OK, that's all cool for what sounds like a pretty good smooth ramping, maybe even better than ours because switching channels on ours isn't the greatest, least in NarsilM for a triple channel.
Progress is slowly moving forward. I had a break from firmware development and spent some time designing drivers, among others a driver with a micro USB port that I’ll use for flashing the driver, so no need to even unscrew the head… if it works… But that’s done and OSH Park have the ball on that project, so back to firmware again.
Okidoki, I finally have basic firmware functionality including configuration system for all switch types. I can finally get down to the details some of you have posted. I hope those of you that have posted haven’t lost interest yet and can answer a few inquiries I have about some suggestions. I’ll be asking every now and then.
I’ve only once had a flashlight with forward clicky and I didn’t like it at all so I’ve not used forward clicky since then. Because of that my firmware isn’t really written with forward clicky in mind. However, I’m interested to see if I can make it work. You state that with FC on guppy3drv you can double click for turbo. Does this shortcut only work from cold start? Or can you do two short offs and go to turbo at any time? I am kind of curious on how this double click short cut with clicky switches work, doesn’t it interfere with normal mode changing? If you turn the light on and want to switch modes instantly, isn’t the short cut to turbo going to kick in instead of fast mode cycle? Or dose guppy3drv assume you don’t change modes rapidly? I have support for clicky switch short cuts but having a double click short cut really interferes with normal mode changing. That’s ok if you only have three modes, but then the double click short cut is useless.
Just thinking that if the light is started in lowest mode and you want to step up only one mode brighter but not to turbo/boost, how would you do that? To me it seems the same press sequence would be used.
Aha, ok thanks. You basically have to wait for a “multi press detection timeout” before the next press. I have multiple off press detection, but as being a reverse clicky guy it would be fairly annoying to have to wait between off presses with a 4 to 5 mode light. Out of curiosity, do you know exactly how long the timeout is on H17f or guppy3drv? I’ve set mine to half a second.
With H17f and possible guppy3drv there is no waiting on the off presses to change modes. IF you do wait you will either go back to mode memory, or reset to beginning of mode sequence.
Sorry, but now I’m confused… you wrote “Leave on just a little bit longer before release”. This means waiting a little bit. Now you write there is no waiting
That youtube link just brings me to youtube.com, not an actual video… I used search function though, I found a few to look at.
Reverse clicky— there is no waiting while off to change modes. Very brief off presses with cycle through the modes.
With a forward clicky, you have wait just a bit when you first press—let the light know its on in low before you release/press to switch to med. If you press-release/press to fast on H17f (possible guppy3drv). It will read inputs as double tap and go to Turbo or what ever the double tap is.
The “some time” is time on.
Edit, I don’t know why video link is not working.
Search—- H17F driver run down with mistakes. 1 cut Chad.
Hi Mike!
I don’t have the light with me right now! Later today I will check how it behaves both with RC and FC switches and will tell you as now I have some doubts, specially when using FC clicky.
I’ll try to make a video with both kind of switches and will link it!
In the meantime…I’m out of the GAW. I intended to use it with White Flat in Emisar D1. This combination doesn’t work well. Now I don’t have a combination of host and LED where this driver would really shine…I waited a bit with retiring because I thought that maybe I’ll think about some good combo. Well, it didn’t happen.
Thanks anyway!
