CRX Bolt Action Triple
Something a little different for you today, a bolt action operated triple output flashlight incorporating white, red and 365nm UV emitters.
CRX Bolt Action Luxeon V2, XP-E2 Red, Seoul Viosys 365nm UV - KD I3N - 18350 - Bolt Acion Sw - 420lm.Hand made.
Brass construction.
Lumileds Luxeon V2-5070
Cree XP-E2 R2 N4 620nm Red
Seoul Viosys 365nm UV Z5
20mm triple Noctigon MCPCB
8mm thick aluminium heatsink
22mm x 1.5mm ARC glass
Dual TIR/ Reflector optics
Diffuser film
KD I3N 3 channel 2 mode driver (Max 1500mA)
6mm x 1.5mm green tritium vial
17mm glass tail
Bayonet sprung body lock
Felt lined battery tube
Momentary on switch
Bolt action locking tail switch
Max - 420lm OTF (White)
Length ā€“ 95mm
Width ā€“ 25mm
Weight ā€“ 176g (with 18350 cell)
I drilled out & replaced one of the TIR wells with a small reflector filed down to size as the plastic does not allow UV light to pass through, also a disc of diffusion film was added.
Sprung bayonet head to body locking system. Glass covered tritium vial.
KD I3N three channel two mode driver, simple operation:
LED 1 On (High) > LED 1 On (Low) >
LED 2 On (High) > LED 2 On (Low) >
LED 3 On (High) > LED 3 On ( Low)
The light works by the side bolt in the tail, momentary On and a locked On position is available by pressing the bolt down and across in the channel. It has a very smooth natural feel to it operating by thumb :THUMBS-UP:
Nice optic mod!
Nice light overall too but know what that optic took. Whatā€™s the reflector out of?
Thanks. I filed down one of these.
Yeah it took a while to doā€¦
Iā€™ll send you some brass tubes :laughing:
Very nice as usual. Just when I think I have seen your best work, you just keep out doing yourself. Well done sir.
:beer:
This is a really nice build, I like the different emitters and the materials used.
Youā€™re definitely the chief. Your injunuity knows no boundsā€¦ :slight_smile:
Love that bolt action switch, great work.
You went all out again on this one, very nice flashlight!
Cool brass :beer:
Certainly something different! Extremely cool! Right up there with the pucks :slight_smile:
Yeah I wanted to make a multi output light and I already had the brass soā€¦ :slight_smile:
:laughing:
Thanks. Took some work to get a working version but itā€™s great for firing through the six modes :slight_smile:
:+1:
I have no idea how you manage to build things so intricate and flawless. Love it. :heart_eyes:
so when do I have this in my mail box?
:wink: :+1:
Iā€™d like to see that implemented as a physical lockout, like a safety on a firearm.
Interesting idea.
Amazing! You are the king! From the ā€œKnuckleheadā€. :smiley:
:smiley:
