I chose the NW option and the tint didn’t dissapoint, no equipment to measure but by comparison to known bin emitters it should be around 5000-5200k. The beams from the dual reflector cups converge within a few feet and the spot on a white wall from anything more than arms reach is perfectly round. I actually find it better than the nitecore CR6 reflector from which the 2 beams never fully converge into a single circle (but the nitecore isn’t designed or intended to do so).
My phone is to old & cheap to take beam shots and it’s near zero after the sun sets for the next week anyway however if I get around to it I will setup my real camera and try to take a few white wall shots sometime before taking it apart for its build (itll be getting much more interesting emitters than crees)
I gót it too and all important is poste on banggood eshop. Also ui. Before tailcap was blue. Now shitty Red… But its amazing Light. Very bright. Gót nw too. Sadly no USB board… But so small thats sure one of the shortest. Thanks for the review.its very floody.
Here’s my mod:
Used a 22mm TA driver, it’s slightly small but pressure from the tube holds it in place.
Grab the wear ring off the factory driver. I also recycled the FET and 7135 and caps off the factory driver too (reusing 0.1¢ resistors isn’t worth it to me).
Cut a couple Cu disks from 22Ga sheet
Triple Luxeon V2 5000k’s and a red Olson SSL-80 for super moonlight (from the single 7135).
Probably need to swap to a red Cree or something, the red spot from this guy is a freaking pencil beam. The SSL-80 is the most efficient throwing emitter you can get when used behind a TIR (killing even the flat black)!
Sorry, is this question for me? If so, the main thing is the nice UI in NarsilM. I'm not sure if I got more power or not, but at least I'm using a known good FET and can update the firmware as I like for this light, etc. Also, probably could update to Anduril but may have to tweak the FET+1 I/O pin settings, not sure.
Actually the same applies to CK's mods, except he took it further with support for 2 independent outputs - 3 white LED's or 1 red.
For my mod, I don't have beamshots, but for a dual XPL HI, you have to be closer than about 12 inches to see a slight oblong shape, closer in, like 1 inch, there's 2 distinct hot spots, but further than 12 inches, looks like a nice single, fairly large hot spot of perfect tint. These are tiny reflectors, so you are not gonna get great throw from it. Sorry, I did take lumens/throw #'s but don't have them with me.
I really like it with the dual reflectors, and overall modability (is that a word?), compact size, etc. Yes, the switch protrudes - good thing and bad thing: good in easy to locate by feel. I'd say moderate activation - not soft, not hard. The hard plastic switch cover is kind of different but has a good solid feel to it, least to my liking, but I'm not a fan of the wishy/washy feel like some even metal switches have.
Wish it had an AUX led though in the switch, by the switch, or in in the head. The machining doesn't lend itself to a light pipe with the moderate fins, but you could probably flatten out a surface to mount one with the right skill and tools.
