Yes, that is exactly what Ryzbor was showing. On request to turn off the aux LED board, Fireflies disconnected the aux LED board.
This was probably done because there is no other way to turn it off. Later models like the E07 switched to a 3-wire setup which allows the MCU to turn the board on and off, but on the ROT66, it’s wired directly to power.
Would it be possible for one of you to post a graphic illustrating where the potentiometers are and how to adjust them? I’d love to be able to ramp mine up a bit. I love the aux leds.
They are labeled POT_D1, POT_D2 and POT_LVP. There are 3 of them and they have the Philips head adjustor so you can turn them with a screwdriver. D1 looks to adjust the outer ring, D2 the middle ring and LVP adjusts the inner ring.
Look at the 1 o’clock, 2 o’clock + 7 o’clock position
after receiving the E07, I realized that my ROT66 somehow has different programming? I can’t get to turbo, only to the top of the ramp.
For example, it should to go the top of the ramp when I double click, then another 2x click to turbo. But on the ROT66, it goes to strobe when I do the 2nd double click, not turbo.
