longest running AAA light?
So what was the run time for the copper version?
200 hours 1.16V of light out of the Manker E01, test over. The light was still usable in the middle of the night for navigating around a dark house. I don’t want to keep discharging the eneloop, and also want to start investigating the current vs voltage profile. I put a new alkaline in it today and found that it is as bright as the AA Archer which also claims 1 lumen on moonlight. The eneloop was never that bright, so it seems that the output is not regulated on moonlight is the E01. Plan to upload some pictures now that this phase is over.
It lasted between 28-29.5 hrs until dead, so actually not a whole lot longer.
I tried the IYP head on the Tool over the weekend but it was dead by the time I checked it today, so all I know is that it’s less than 63 hrs. I like the mode spacing quite a lot, I’m tempted to keep it this way
Impressive time for the E01, I’m partial to click switches but that has me interested
Thanks for the info, I updated the first post accordingly.
The Manker E01 was $10 on Amazon open box. It was a bit finicky at first, but after I cleaned it and put some teflon tape on the threads it has worked fine.
As far as uploading pictures goes, do they all need to be hosted on photobucket or some such place first?
Yes.
Here's a guide:
https://budgetlightforum.com/t/-/15452
Ok, someday I will do that, such a pita though.
I did a couple of tests on current draw at low on the Manker E01. 3 batteries, 3 different current draws. The voltage shown below is without load, I don’t have a convenient way right now to measure under load unfortunately.
fresh Duracell,V=1.61V, E01 draws 5.4mA on low, impedance 298 ohms
Fresh eneloop, V=1.41V, E01 draws 4.5mA on low, impedance 313 ohms
old kirkland, V=1.26V, E01 draws 3.6mA on low, impedance 350 ohms
old Duracell, V=1.22V, E01 draws 3.5mA on low, impedance 349 ohms
I am not sure if this is some sort of joule thief type circuit, some other PWM, or just an interesting boost that saves current as the battery voltage drops. Pretty easy to see how a 750mAHr eneloop that stores more than 800mA hr could last for 200 hours. If the roughly 320 ohm impedance holds, when the battery is in that 1.27V range the current is 4mA, or 200 hours worth of storage. Would love to see the circuit and understand how the driver works.
Repeated the test on medium level. I calculated impedance here but I think it is meaningless without knowing the actual battery voltage under these heavier loads, especially for the “softer” alkaline batteries.
fresh Duracell,V=1.61V, E01 draws 105mA on medium, impedance 15.3 ohms
Fresh eneloop, V=1.41V, E01 draws 097mA on medium, impedance 14.5 ohms
old kirkland, V=1.26V, E01 draws 077mA on medium, impedance 16.3 ohms
old Duracell, V=1.22V, E01 draws 077mA on medium, impedance 15.8 ohms
All in all, a fun way to spend part of a Monday evening. I think I can scrounge up another DVM, but in reality I learned what I wanted to learn, that is the current is as low on the low setting as I imagined, and it is not trying to regulate constant voltage/current on the LED on any setting, but looks more like a fixed impedance.
Finished a run with my new brass Lumintop Worm today on low, 31 hours. I am wondering if my eneloop was fully charged or not for this, so I will be repeating it, and will also run an alkaline to see how that compares. Tried to measure the current the light draws but for some reason I could never get the light to turn on or change modes away from Medium.
Second test complete on the worm. 34.5 hours on a 4 year old alkaline battery, same vintage and starting voltage (1.53V) as used in the fenix LD01 test. Fenix made it 38.5 hours, I was hoping the worm would match it. I am confident with a new alkaline it would meet or beat the vendor specified 36 hours.
Here is one thing I love about alkaline batteries. My worm was off, dead off after a 34 hour run on an alkaline on low. When I tried to turn it on a several minutes later, nothing. Let the battery sit a couple hours, it started working again. I used the light this evening a few times during a walk with my wife, including a few times on medium. I turned it on low to see how much more I could get out of the battery, 60 minutes later it is still shining at full illumination on low mode (3 lumens).
This aspect did beat the Fenix, as the LD01 only ran 40 minutes after it shut off due to first end of alkaline battery life. This is making me wonder if part of the reason the worm had less life is it was in a cold room most of the last 10 hours of life, then outside on a cold morning. The fenix was in my pocket nice and warm at the end of its life.
For low power use, alkalines can deliver as well as and sometimes better than rechargables or lithium primaries. No worry about damaging it, as you will throw it away anyway. And the price is hard to beat in decent quantity. Yes, the rechargable will get more uses, they have their place for sure, especially higher power levels.
I definitely would not perform brain surgery with 3 lumens of light, but it will get you where you need to go if you are walking or looking for something under a piece of furniture, or many other simple tasks I use flashlight. I like rechargables also, but alkalines definitely have a place in my flashlight power cache. And no, I have not had an alkaline leak and ruin a light or other electronic device in the past 20 years. I know it happens, but not in 805 . . . (yet . . .)
Final update for this battery, got 45 minutes this morning, then another 30 minutes in the early afternoon. It just keeps on giving . . .
Motivated by another thread I did another run time test, this time with alkaleak batteries. One light was the long run standby my Manker E01, and the other my E02. They both got cells that were a few years old and measuring 1.58V. Both lights were measuring about 4mA of current draw from the cells at the beginning of the tes.
The E02 lasted 8 days, 6 hours plus before it gave up. It ran regulated the whole time, and was at level 7 in moonlight mode. It died somewhere in the next 8 hours. The last time I measured the battery it was at 0.86V. 198 hrs of observed performance off an older alkileak. Not bad.
The E01 went well beyond. It is not regulated in moonlight mode, but ran 12 days plus, nearly 300 hours. Last time I measured the cell before it quit was about 0.9V.
And another data point, while likely not a super long run time, the Sofirn C01 is currently running off a cell measuring less than 0.6V and putting out as much light as either Manker above. We’ll see if that one is still running in the morning.
Some good info, I may sacrifice some primary and test some of my lows
thanks for all your info
yes, temperature matters
and when you say E01 above, do you mean Manker or Fenix, and if manker E01 is that stock or modified inductor?
maybe at some point you can summarize your data for each light… Im getting very confused sorting through the text
the light I have is the Manker E01
Manker E01 ran for ~294 hours on a AAA battery that had a starting voltage of 1.58V. The battery was about 3 years old, but not used. The test was on the lowest mode, called firefly by Manker on the page linked above. IMO, the light output was sufficient to navigate around a dark house until it went out.
Manker E02 ran for ~ on 198 hours a AAA battery that had a starting voltage of 1.58V. The battery was about 3 years old, but not used. The test was on the lowest mode, called moonlight by Manker on their product page. The moonlight mode has 14 sub levels within moonlight mode, mine was set at level 7.
I did not go back and research my older run time tests, sorry about that. None of those approached the run time of these two tests. Both lights were inside my home the entire time, ambient temperature between high 50s and low 70s Fahrenheit.
Sorry for any confusion my post caused, hope this is more clear.
DITTO.
Thanks for the test.
Jerry
After reading through this I can see the data is likely a bit confusing. Some the data in the OP was from other folks posting in the thread, and they did not specify a battery type.
Alkileak batteries give more life in general in the lights tested, as they can run down to lower voltage and not kill the cell. They also have more capacity than eneloop of the same form factor (AAA for this thread).
Listed in longest running light to shortest on alkileak tested by me. Tested on the lowest mode. for the Manker E02, see my note above regarding sub levels in the lowest mode.
Manker E01, 294 hours
Manker E02, 196 hours
Fenix LD01 32 hours
Measured on eneloop AAA
Manker E01 200 hours
Fenix LD01 ~34 hours
Lumintop brass worm 31 hours on eneloop
Thorefire PF03 with 750mAh eneloop, between 26 and 27 hours
Hope that helps.
thanks!:slight_smile:
so, at the end of both tests the light went completely dark, correct?
and, what was the voltage on each battery when the light went dark?
Hmm, not quite. I ended the eneloop test at 200 hours because the eneloop voltage got down to 1.16V. I did not want to damage the eneloop. I could redo the test and see, as I have a few spares presently
The alkileak test, that last time I measured the voltage it was 0.94V. When I got up the next day the light was out, so I don’t know what voltage the light cut out at.
Just to add to the confusion, I recently put one of those dead alkileaks in my C01, and it ran for another 4 hours +. The battery measured 1V when I put it in. When I removed the battery in the morning (went to bed after 4 hours of the light being on) the voltage was less than 0.6V and slowly rising. The C01 is a battery vampire for sure!!
thanks for sharing info :slight_smile:
enjoy your lights!
The Manker E01 is the same flashlight as the Astrolux/BLF A01 with the old Manker driver (NoPWM version), isn’t it?
(new Astrolux A01 use a different driver that uses PWM on medium mode)
